Fog Light Switch
Discussion in 'Lighting' started by kirkdbjl, Aug 23, 2009.
  1. Aug 23, 2009 at 1:58 PM
    kirkdbjl
    kirkdbjl [OP] Member
    Duane
    Cibolo, Texas
    2009 Tacoma TRD
    Vent Shades, Bull Bar, bed mat,fog lights (pending)
    I just purchased my new 09 Tacoma and want to install some auxilary fog lamps 0n my Bull Bar in addition to the factory lamps.
    I am trying to find a switch that will replace one of the blanks in the dash that will look factory with an on indicator light.
    I have found the following FJ switch PT297-35070-AS, but am not sure if it will work. Does anyone out there know?
  2. Aug 23, 2009 at 2:41 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Not sure if thats the right one, but they sell OEM switches on Ebay.
  3. Aug 23, 2009 at 3:00 PM
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    Radio shack has a ton of differnet styles just buy which ever one you like and cut the blank off plates to fit.
  4. Aug 23, 2009 at 3:21 PM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    i got an oem switch off ebay for about 20 bucks shipped.
  5. Aug 24, 2009 at 4:35 AM
    kirkdbjl
    Duane
    Cibolo, Texas
    2009 Tacoma TRD
    Thanks for the info but I am new to this type of thing and do not know what OEM is?
    I take it from the replies there isn't a switch made you can take the blank out and replace it with except a factory toyota fog light switch($60.00)that you simply need to find a switch that will work and install it on the blank after some modification?
  6. Aug 24, 2009 at 4:52 AM
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
  7. Aug 24, 2009 at 11:06 AM
    monrad
    monrad Coprolite
    B'wood, SC
    09 DC short box TRD Sport, TM
    Avid light bar+RBG, Lightforce 140s, fog mod, FSM badges, Bobcatoshi grille + Stampede, JDM DRLs, TRD cat-back, rear spring TSB, AccessLE
    See thread:
    <http://www.tacomaworld.com/forum/2nd-gen-tacomas/15476-oem-style-switch.html>
    Part No. 0055035976 can be had at the dealer for about $12 or less.
  8. Aug 24, 2009 at 12:10 PM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    You can go this route, $8 each at the stealership, or e-bay I believe.
  9. Aug 24, 2009 at 5:52 PM
    Plain Jane Taco
    Plain Jane Taco ALL human beings deserve equal treatment
    USA
    I went with the same switch. $10 at my local dealer.
  10. Aug 24, 2009 at 5:53 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    got this one off Amazon i believe....its made by daystar...got green to go w/ the truck...kinda big and gnarly rocker...
  11. Sep 3, 2009 at 2:16 PM
    brandob9
    brandob9 Well-Known Member
    Brandon
    Portland, OR
    09 DC Long Bed
    Soundproofed cab, beeps purged, bed lights, extra bed tie-downs and TSB springs.
    Did yours require any magic to fit? I'm reluctant to use too much force here.
  12. Jan 10, 2010 at 3:52 PM
    2007TacBorla4X4
    2007TacBorla4X4 Well-Known Member
    Bob
    Jax, FL
    TRD Sport 4X4 Short Bed
    Borla cat back, K&N cold air, Silver star bulbs, Nerf bars,NEW BFG, Weather teck windows, Flash light on the drivers seat, TRD off Road ft tow hook, Rear driving lights on bumper, Weather teck windows & ft bug guard, 4X4 switch glows, Windows tinted 20% sun shade
  13. Jan 14, 2010 at 8:46 AM
    Fish Head
    Fish Head Active Member
    Seriously...........I went & bought 3 through my local dealership, just shy of $100.00 for all 3 after I was taxes in - brutal considering the price point you guys are scooping them at.
    They'll be going in shortly, as all my other lighting components are finally here.
  14. Jan 14, 2010 at 2:29 PM
    Fish Head
    Quick question now that my hands are scratched to crap from burrowing around blindly up in behind my dash - how does one access the area behind the upper 3 switches ? The lower 3 is a simple remove the tray and pop 'em out from behind.........the upper 3 are shielded from below it seems.
    I'm wanting to move (re locate) the factory alarm light/sensor from the lower middle slot to the upper middle slot, leaving the lower 3 for the new auxillary lighting switches.
    Any way to do this simply without yarding half the dash out ?? I've looked around a bit for links but haven't hit on the right one yet.
  15. Jan 15, 2010 at 11:03 AM
    drmadron
    drmadron Member
    don
    md
    2010 toyota tacoma
    well l just found out my 2010 tacoma v6 4x4 did not come with wiring for fog light so l have to buy aftermarket fog lights and wiring any know where to buy a nice set of aftermarket fog lights.
  16. Jan 15, 2010 at 11:39 AM
    AZCOMA
    AZCOMA where can't I go?
    Kacey
    Laveen
    05 Preunner sr5
    2.5 saw co's, n-fab bed cage rear tire mount,new head unit and 10"sub,285/75/16 nittos on M/T wheels,H.I.D.'s...The next mod is T.C. long travle kit,Deavers and glass all the way around.
    I just taped in to the wire on the fogs for signal to turn on my hellas.I have a seperate power source and a relay. Works good cause I dant use the fogs any ways.
  17. Jan 15, 2010 at 11:51 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    true definition of stealership right there....
    Justinlhc likes this.
  18. Feb 7, 2011 at 12:49 PM
    DanT
    DanT Old Member
    Dan
    Richland, WA
    4WD 2.7L SR5
    Did anyone ever answer your question about accessing the upper switch area to add a fog light switch? I have the same question.
  19. Feb 7, 2011 at 12:59 PM
    01GREENTACO
    01GREENTACO Not all who wander are lost
    Germantown, TN
    01 4WD
    Lost track many, many mods ago.
    Holy thread revival Batman!
  20. Feb 7, 2011 at 4:59 PM
    Fish Head
    You've got mail......
