2007 PreRunner HID Install
Old 08-24-2009, 05:32 PM   #1
Xclutch87x [OP] Xclutch87x is offline
Xclutch87x is on a distinguished road
Xclutch87x's Tacoma Gallery
I have browsed the majority of forums regarding the HID lights for my 07 Tacoma but cannot locate a solution to my problem. I recently purchased a set HID lights from Retro Solutions and tried to install it with no luck. I had everything installed as shown in the instructions but the lights would not fire up. The FAQ on the instructions says to reverse the polarity to the ballast, tried that and it did not work. Some websites say I need to disable my daytime running lights because they take away from the power needed to fire up the lights. Has anyone done this with success? Could anyone give me some advice on options that I could try to get these to work. Anything would be helpful.
Old 08-24-2009, 05:41 PM   #2
Kenny Fuckin Powers
jtav2002 is one of the sharper tools in the shedjtav2002 is one of the sharper tools in the shedjtav2002 is one of the sharper tools in the shedjtav2002 is one of the sharper tools in the shedjtav2002 is one of the sharper tools in the shedjtav2002 is one of the sharper tools in the shedjtav2002 is one of the sharper tools in the shedjtav2002 is one of the sharper tools in the shedjtav2002 is one of the sharper tools in the shedjtav2002 is one of the sharper tools in the shedjtav2002 is one of the sharper tools in the shed
jtav2002's Avatar
jtav2002's Tacoma Gallery
You using a relay harness?
Old 08-24-2009, 05:45 PM   #3
I am not sure. I just got the HID kit today. It came with a harness if that is what you are referring to. I did not do anything to the daytime running light wiring. I'm sorry, I am new to the electrical side of trucks. Thanks for you help.
Old 08-25-2009, 02:11 PM   #4
Anyone else have any ideas, what I could try to get this kit working. Is there a relay harness that is required in additional to the one provided with the kit to get it to work. Any help would be appreciated. Thanks.
Old 08-25-2009, 02:25 PM   #5
Bangers Runner
GotLift37 is one of the sharper tools in the shedGotLift37 is one of the sharper tools in the shedGotLift37 is one of the sharper tools in the shedGotLift37 is one of the sharper tools in the shedGotLift37 is one of the sharper tools in the shedGotLift37 is one of the sharper tools in the shedGotLift37 is one of the sharper tools in the shedGotLift37 is one of the sharper tools in the shedGotLift37 is one of the sharper tools in the shedGotLift37 is one of the sharper tools in the shedGotLift37 is one of the sharper tools in the shed
GotLift37's Avatar
GotLift37's Tacoma Gallery
is it hooked up something like that?
Old 08-25-2009, 02:27 PM   #6
Bangers Runner
GotLift37's Avatar
oh yea.. dont mind the H7 thing...
Old 08-25-2009, 02:30 PM   #7
Lieutenant Dan.
DeeKay21's Avatar
Firefighter: Lieutenant
DeeKay21's Tacoma Gallery
I have an HID kit and also have DTRL's and everything works just fine.
Old 08-25-2009, 02:34 PM   #8
Thanks guys for your help. It does look very similar to that wiring harness. There are a couple more plugs that I have on my kit. Additional grounds for each bulb, as well as 2 other connectors at each bulb. It seems light i should not need additional equipment, maybe I have defective equipment. Any other ideas would be appreciated. Thanks.
Old 08-25-2009, 02:39 PM   #9
Bangers Runner
GotLift37's Avatar
take a pic of your harness and we'll help you match up where everything needs to go.
Old 08-25-2009, 02:51 PM   #10
Here is a picture. The open connections are at the bottom. One positive side of the battery. 2 Grounds (one for each lamp) and the mating connector which goes to the with the stock plug for the truck. Everything else has a match.
Old 08-25-2009, 03:13 PM   #11
Bangers Runner
GotLift37's Avatar
It should work. I dont see why it shouldnt. As long as everything is hooked up correctly and connections are tight aka snapped in. If you were close by, i'd come hook it up and help a fellow yota person out. On the ballasts (shiny box things) Check the polarity on them and make sure if you did switch them around that they are snapped in place.
Old 08-25-2009, 03:43 PM   #12
Lieutenant Dan.
DeeKay21's Avatar
That looks like the same exact kit I have. Mine went in with no problems. Hmm, I wonder whats going on?
Old 08-25-2009, 04:05 PM   #13
Thank you for all your help. I found out that I had faulty ground locations. It would spark so I though it was ok but I guess it wasn't. I relocated and it looks great. Thanks again guys. I appreciate it.
Old 08-25-2009, 04:28 PM   #14
Bangers Runner
GotLift37's Avatar
no problem. sometimes all it takes is a little back tracking.
Old 08-25-2009, 05:47 PM   #15
Lieutenant Dan.
DeeKay21's Avatar
X2!! Glad you got them working!
Maybe some concerns with my 2007 Prerunner GT88 2nd Gen. Tacomas 43 11-16-2013 07:45 PM
= => 2009 Rear Back Up CAMERA Install on 2007? EASY INSTALL? <= = RAD 2nd Gen. Tacomas 33 04-25-2011 10:49 AM
2007 BSP PreRunner thai fyter Buy / Sell / Trade 3 08-06-2010 10:24 PM
which tires for 2007 Prerunner 4 dr Robert Smith Wheels & Tires 0 04-26-2010 05:04 PM
2007 Prerunner tires kevinklk97 Wheels & Tires 3 02-16-2008 01:29 PM
