BHLM HELp..
Discussion in 'Lighting' started by sandman427, Nov 7, 2009.
  1. Nov 7, 2009 at 10:41 AM
    sandman427
    sandman427 [OP] KR FAB
    Amir
    WAY THE HELL OUT THERE, So Cal
    BAMF TACO!!
    2 ten inch kicker cvt subs, pioneer deck and alpine 1000 watt class D amp, and flowmaster exhaust, 4 inch camburg lift spindles and my coilover is adjusted to 1" (5inch total) in front and 3" All Pro leafs, KING off road racing reservoir shocks and coil-overs, KR FAB CUSTOM BUMPER with three 9" HELLA 4000 Race LIGHTS , HID headlights with rigid amber LEDs , "KR Fabrication" custom built bumper, sliders and tiregate, Full size spare with matching rim, custom bed bar with two amber off road lights, cb radio, also BHLM (thanks Ray), and debagged
    AY i was wondering how long it took u guys to do the BHLM..?? THe reason y i ask is cuz i wanna do it on SCMD..?? If i could do it there that would be bad ass... i just dont want it to take more than a day cuz i dont wanna drive with no LIGHTS HAHA... Thanks
  2. Nov 7, 2009 at 11:02 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Took me about 2.5 hours. but I have done the BHLM on all my cars and on some of my friends' cars so I'm pretty good at it.
  3. Nov 7, 2009 at 11:08 AM
    sandman427
    Amir
    BAMF TACO!!
    for sure... thanks broo... do u have any pics of the install..??
  4. Nov 7, 2009 at 11:15 AM
    macgyver
    Brad
    Canton, GA
    nope only the finished product
  5. Nov 7, 2009 at 11:52 AM
    DTacoms
    DTacoms Well-Known Member
    Frisco, Texas
    05 4x4 DC LB BSP
    I did mine in 6 hours. What took too long was the trial and error of oven heat and messing up with the paint when putting the lens back.
    Most of the guys in the mod day have done it, so it will not take the whole day.
  6. Nov 7, 2009 at 11:57 AM
    tim920
    tim920 Never seen Forest Gump
    Tim
    Boston, MA
    2005 4Runner Limited V6
    Took me about 6 hours too because I know nothing about about how to take anything apart. I'm a newbie at all the modding. The most frustrating part is taking the lights out of the truck. Since you're going to a meet, people there should help you out. It doesn't take that long. I used krylon fusion and waited 15 minutes between each coat. I did 4 coats. I DID NOT sand, primer, clear or anything else.
  7. Nov 7, 2009 at 11:59 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    I'm doing mine today...wish me luck lol
  8. Nov 7, 2009 at 12:05 PM
    ColtsTRD
    Scott
    AZ
    I got some clear silicone to seal the edges up nice and tight just in case. So I guess we preheat the oven at 300, pop the head light in and turn the oven off. Leave it in for 8 min. and pop er off :) Chris4x4 told me to watch out for the heated sealant because it gets all stringy and I guess its a bitch to get off the lense
  9. Nov 7, 2009 at 12:11 PM
    macgyver
    Brad
    Canton, GA
    I have always done 250 degrees for 7 minutes. pry them a little, pop them back in for 5 more minutes, then pry them open the rest of the way.
    Make sure you seal them up with silicon around all the seams. I got some condensation in mine the first time I did them which is weird because all of the cars I have done over the years the factory glue resealed fine. I had to take them back off and put them in the oven to evaporate the condensation. Since I siliconed them I havent had any condensation.
  10. Nov 7, 2009 at 12:36 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    That's what worked for me... my oven isn't very accurate so I ended up leaving mine in for about 12 min total. Tried getting them apart at 10 minutes, but needed more time. If you read all the BHLM threads/responses everyone just about used a different temp (from 200 - 300) and "bake" times.
    Yes it is a pain to get the sealant off the lense :eek:
    Good luck ;)
  11. Nov 7, 2009 at 12:56 PM
    DTacoms
    Frisco, Texas
    05 4x4 DC LB BSP
    Make sure to use something non-heat conducting material between the tray and lights, like cardboard or plywood. I used aluminum foil first since that is what the DIY said, the plastic housing melted.:(
  12. Nov 7, 2009 at 1:44 PM
    ColtsTRD
    Scott
    AZ
    so what about the black weather strip on the top of the head light? Should I peel that off??
  13. Nov 7, 2009 at 1:54 PM
    DTacoms
    Frisco, Texas
    05 4x4 DC LB BSP
    You don't need to.
    I also recommend removing the screws and take the tabs out before putting in the oven.
  14. Nov 7, 2009 at 1:56 PM
    THXEY
    THXEY Panda Jerk
    Jacob
    San Diego
    2013 Subaru WRX
    STi Short Shifter.OEM floor illumination kit. Rally Armor Mud Flaps. BC BR Coilovers. Invidia N1 Exhaust
    ive always wanted to do this but im so nervous
  15. Nov 7, 2009 at 2:56 PM
    ImpulseRed008
    Susan
    SC
    You're afraid of this and you did the satoshi??? The headlights are a pain to peel apart, but just read the "original" instructions and you won't have any problems....
    http://www.tacomaworld.com/forum/technical-chat/2327-blacking-out-headlights-how.html
    http://www.toyotanation.com/forum/showthread.php?t=106329
    Just read through the threads.... learn from others' mistakes. I copied the instructions (parts of them I wanted) into MS Word and printed up the instructions and read them over several times before I even went near my truck.
    If you can do the satoshi, you can do the lights :thumbsup:
  16. Nov 7, 2009 at 4:45 PM
    sandman427
    Amir
    BAMF TACO!!
    Me too that's y I'm waiting till mode haha... So if I get this right some krylon paint and clear coat an oven should do the tric..?? Haha.. Thanks again for all the help fellas....
  17. Nov 7, 2009 at 11:08 PM
    sandman427
    Amir
    BAMF TACO!!
    ill see about this oven... dont know how its gonna work at SCMD..?? but thanks for the help...
  18. Nov 7, 2009 at 11:36 PM
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    :eek:
    aluminum foil! wow, i never noticed than in the dyi. that shit needs to be corrected asap! but again... the material doesnt really matter, just the temp of the oven. pre heat first. throw them in. 5 min. peal. paint. repeat.
  19. Nov 7, 2009 at 11:40 PM
    sandman427
    Amir
    BAMF TACO!!
  20. Nov 7, 2009 at 11:53 PM
    AlexForbesR6
    AlexForbesR6 My R6 Eats Me
    Alex
    Houston, TX
    07 4x4 6-Spd
    cardboard ftw!!!
    i did this a while back and i LOVE it...it wasnt too hard...in fact the hardest part was putting my headlight in my oven without touching the sides!
