Hella 700ff HID conversion.
Discussion in 'Lighting' started by Dellosa89, Nov 12, 2009.
  1. Sep 21, 2011 at 6:29 PM
    #61
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Ventura, CA
    2022 Toyota Tacoma SR5 DCSB 4x4
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    Looks great! Sweet Access Cab BTW.
  2. Jan 31, 2012 at 8:29 AM
    #62
    Taco Man in HD
    Taco Man in HD DC TRD MallRunner
    Ohio
    2004 DC Tacoma PreRunner
    Methods, Red Labels, and other bro stuff.
    i just got a free DDM HID kit from my buddy (35w high/low) who is upgrading...
    is it possible put this kit in hellas and get the "high" output somehow, or am I stuck with low?
  3. Jan 31, 2012 at 11:12 AM
    #63
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Should be able to select hi or low..
  4. Jan 31, 2012 at 6:00 PM
    #64
    Taco Man in HD
    Ohio
    I mean if I hook them up like regular aux lights (to the battery and a rocker switch) would I get full light (bright mode) output?
  5. Mar 1, 2012 at 1:39 PM
    #65
    jdmdcfan
    jdmdcfan Well-Known Member
    east WA
    dcsb
    also curious.
  6. Apr 4, 2012 at 6:38 AM
    #66
    Hydrolai
    Hydrolai Well-Known Member
    Johnny
    friendswood
    trd off road 4x4
    Firestick NGP Uniden 520 PROXL BadaBling! 6k Hid Plasti-Dip Wheels/Badges Leds Bed Lights
    to my knowledge if you did that, its possible to choose. youd need a switch 3 position switch. its like double pull single throw ? not sure, but the 3 wires on the kit is 1 positive for low beam and 1 positive for high beam, leaving the last wire for ground. just have to play with it and see which wire is which.
  7. Apr 9, 2012 at 8:29 PM
    #67
    thegame
    thegame Well-Known Member
    Brian
    Folsom, CA
    Has anyone had problems with their lights cutting out when driving? Sometimes I'll have them on on a dark road and the lights will just shut off. If I leave them off for 10min or so, they will turn back on again. Maybe something is wrong with the ballasts? I just tried to mimic whats happening in the driveway but they wouldn't turn off, it's only when I'm driving. It couldn't be the alternator because other stuff would shut off too, not just the Hellas.
  8. Apr 13, 2012 at 2:39 PM
    #68
    mudthedoor
    mudthedoor Sconnie
    Alex
    Forestville, WI
    00 4Runner
    what light bar do you have?
  9. May 21, 2012 at 9:05 PM
    #69
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    you guys think this would be possible with hella 500s without overheating?
  10. May 21, 2012 at 9:10 PM
    #70
    desert guy
    desert guy Well-Known Member
    Bryan Blagg
    o.c.
    toyota offroad truck
    FiberWerx Tacoma front fiberglass clip, currie rear 9 inch, 35 Spline axles, sick nicks fab steering, Beard Seats, King Coilovers, Bypass, & Hydraulic Bumpstops, DEAVER Springs
    It works fine with hella 500's. I have 5 across my light rack on my toyota. It will be the same bulb and same external ballast. The 500 is just a little smaller
  11. Nov 18, 2012 at 9:50 PM
    #71
    themuffinman619
    themuffinman619 Play stupid games, win stupid prizes
    themuffinman
    Your moms house
    Got three hella 700's. Def need to convert them to hid's.
  12. Nov 19, 2012 at 6:25 AM
    #72
    T@co_Pr3runn3r
    T@co_Pr3runn3r XXXXXXXXXXXXXXXXXXX
    08 RC Prerunner SR5
    Finally got around to doing the conversion on my 500s. Went with 35w 3000k in them to have some nice fogs. The actual fogs in the bumper are already 5000k. Not done with all the wiring but did test last night and the lighting is pretty good. One of the bulbs had a loose wire on one side so ordered another pr of bulbs so I'll end up with a spare bulb after all said and done. Both ballasts good. Running wiring to 2nd oem switch. Going to auto parts to get some loom and other bits to tidy up install. Pics later when done.
  13. Jan 28, 2013 at 11:29 PM
    #73
    ornithology
    ornithology Active Member
    Wow that looks great! I might actually do this...
  14. Jan 29, 2013 at 6:07 AM
    #74
    T@co_Pr3runn3r
    08 RC Prerunner SR5
  15. Feb 21, 2013 at 12:15 PM
    #75
    eric3187
    eric3187 Well-Known Member
    when ordering the HID kit from the mentioned website on the first post.
    are any of the other items needed? or are those just "extras"? mainly the HID Harness... ?? is that just a wiring harness for hooking up the lights?
    I plan to wire up 4 700FF hid converted lights and do not want to order something i dont need.
  16. Feb 26, 2013 at 10:41 AM
    #76
    Hellfish1066
    Hellfish1066 New Member
    Greg
    CT
    06 Toyota Tacoma
    I was also curious about the "extras" , do you need to order the wiring harness?
  17. Mar 15, 2013 at 9:26 AM
    #77
    12thmanhawkfan
    12thmanhawkfan Well-Known Member
    Robby
    Bellingham, WA
    Access Cab 6-speed
    It's got some Mods
    I just converted two 700ff's over to HID a few weeks ago. Man they are bright! All you need to order from DDM is the HID Kit. It comes with the bulbs and ballast. No need to buy the harness, brackets, or anything else.
  18. Mar 15, 2013 at 10:50 AM
    #78
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    You do need a switch & wiring/relay to get wiring from switch out to bumper area to hook the ballasts up to & to the battery or fuse panel but yeah, don't need anything else from DDM but the kit with ballasts and bulbs.
  19. Mar 17, 2013 at 4:34 PM
    #79
    RyanC
    RyanC Well-Known Member
    Puyallup WA
    95 Tacoma 4x4
    Lifted, 33/1250/15's, canopy.
    Anyone have the 700's mounted on a first gen with the factory bumper and no light bar? I am about to order some but am worried they may be too large to make it work...if they are then ill have to do the 500ff's..
  20. Apr 14, 2013 at 6:42 PM
    #80
    NorthWoods
    NorthWoods Well-Known Member
    Seacoast NH
    '15 TRD OR SW
    Just ordered an HID kit to do these to my 500ff's if there is ever an nice weekend to install them after I change my grill, been nothing but rain and cold lately. If these work well, I might just order another pair of 500ff's and HIDs to have 4. (BAMF Light bar)
