Hella 700ff HID conversion.
Discussion in 'Lighting' started by Dellosa89, Nov 12, 2009.
  1. Nov 12, 2009 at 3:23 PM
    Dellosa89
    Dellosa89 [OP] Love peace and Taco Grease
    Brian
    Murrieta CA
    07 Prerunner TRD Off Road
    Fox 2.5 Coilovers, Camburg 1.25" UCA's, Icon RR, Icon aal,EVS foam bump stops, Borla Catback, HID Headlights and fogs, Defiant light bar, 3 hella 700 hid, Satellite Radio, Sony hu with 10'' sub, custom jetski rack, TRD seat covers, secondary air filter removed.
    I have gotten a couple Pm's about how i converted my Hella 700ff to HID, So i decided to do a write up to help anyone out that wants more visibility with there Hella 700ff or hella 500. I want to thank rzimmer001 who showed me how to originally do it.
    Ok the bulb in a hella 700/500 is a h3 bulb. Here is a site to buy the HIDs for only $40 a pair.
    Edited: New link. http://www.ddmtuning.com/index.php?p=catalog&parent=85&pg=1
    First off take the plastic housing off, then cut a 1" diameter hole in the back, this is for the rubber boot around the wires for the hid bulbs.
    Now take the halogen bulb out along with the ground piece. so all there should be is two black prongs. Now the HID bulb does not fit right in so you are going to trim the two black prongs. Its really hard to tell you how much to trim, but just trim the sides and the height of the prongs tell you can fit the bulb in, just dont trim too much.
    Now once you got the bulb in, bend the black prongs flat to secure the bulb in. I suggest using some hot glue around the base of the HID bulb to completely seal the light.
    Now put the light back together, and place the rubber boot into the plastic back cover of the offroad light.
    so now the wires come out directly back.
    Ok now to mount the ballast, this is where i mounted mine, you may have a different place to mount them depending on where you mounted your off road light. Mine are zip tied to the plastic support under the top of the bumper.
    Feel free to PM me for any questions.
    Pyrotechnika likes this.
  2. Nov 12, 2009 at 3:44 PM
    Capita
    Capita Well-Known Member
    Corner Brook, Newfoundland, Canada
    09 TRD Sport Double Cab
    That is awesome! Thanks for the write-up and great photos. Do the wires have to be upgraded to do this mod?
  3. Nov 12, 2009 at 3:52 PM
    Dellosa89
    Brian
    Murrieta CA
    Nope the HID actually use less power because they are more efficient than the halogen bulbs.
  4. Nov 12, 2009 at 3:56 PM
    Capita
    Awesome! Thanks man. I really want to do this in the near future.
  5. Nov 12, 2009 at 5:03 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    sweeeeet, ill be doing this next payday:D
  6. Nov 12, 2009 at 9:26 PM
    Dellosa89
    Brian
    Murrieta CA
    No problem.
    Nice. you will love the light power.
  7. Nov 13, 2009 at 8:46 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    this should be a sticky!
  8. Nov 16, 2009 at 5:04 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Great mod. Dellosa89, Where did you get that light bar?
  9. Nov 16, 2009 at 6:11 PM
    RelentlessFab
    Eric
    Sparks, NV
    nice. I think I might try and do a HID conversion with my 500FF's. Now that I have 6000K HIDs in my regular lights, the hellas are pretty much worthless anymore.
    KillerHoyt likes this.
  10. Nov 17, 2009 at 4:36 PM
    Timicha
    Timicha Timicha
    TIM
    Tillamook / Portland , Oregon
    04 White Tacoma
    Fabtech 4 inch lift, tinted windows, diff drop, 33 inch MTZ tires on Raceline Raptor wheels, ELITE OFF-ROAD bumpers and sliders
    how hot do the HID's get cause i may also try this with my 500ff
  11. Nov 20, 2009 at 8:53 PM
    Dellosa89
    Brian
    Murrieta CA
    They are the same if not a little cooler running than the stock halogen light bulb. The HID will be fine on the hella 500 housing.
  12. Nov 20, 2009 at 9:44 PM
    Timicha
    Timicha Timicha
    TIM
    04 White Tacoma
    awesome ill be ordering hid's for my headlights and hella's next week then. how come everyone doesn't buy there HID's from these people instead of paying 145 or somthing in the group buys???
  13. Nov 22, 2009 at 11:18 AM
    MotoXXX
    MotoXXX Well-Known Member
    San Jose
    02 Pre-Runner
    Nice write up! I have the 500ff, do you use the relay and stock wiring on the HIDs?
  14. Nov 22, 2009 at 11:25 AM
    MotoXXX
    San Jose
    02 Pre-Runner
    What color temp woulb be the best? Also they have a 55w now for 10$ more. Should work yes?
  15. Nov 22, 2009 at 12:21 PM
    Dellosa89
    Brian
    Murrieta CA
    Yep it works just fine with the stock wiring harness.
    I recomend going with 4500k to 6k since they are going to be for offroading you need the best visibility. and yes i would get the 55w it will be even better the only reason i didn't get them cause i bought the HIDs from a friend for dirt cheap cause he didn't need them anymore.
  16. Nov 22, 2009 at 4:58 PM
    MotoXXX
    San Jose
    02 Pre-Runner
    Great, thanks! Last questions before I order, I need the H3 ones correct? What would the brightest ones be? 5k?
  17. Nov 22, 2009 at 5:46 PM
    Timicha
    Timicha Timicha
    TIM
    04 White Tacoma
    most people say between 4500 and 6k are the best, im gonna go 6k when i get mine, both my room mates got 6k and they are amazingly bright
  18. Nov 22, 2009 at 6:44 PM
    Dellosa89
    Brian
    Murrieta CA
    Yea get the H3 for the hellas, i have the 5k cause i really like a pure white look in the dirt.
    Gatordawg likes this.
  19. Nov 22, 2009 at 7:53 PM
    RelentlessFab
    Eric
    Sparks, NV
    Well, if he goes with the 6000K 55w's then they'll probably be comparable. The 55w's bleach out some of the color vs the 35w's
  20. Nov 22, 2009 at 8:21 PM
    Dellosa89
    Brian
    Murrieta CA
    Yea ive seen the 6k 55w they are almost identical to the 35w 5k in color.
