Light bar
sets of screws on back one on each side.
Thanks for the help!
#1 |
How do I install piaa lights with light bar?
I just installed a new bull bar. I have not had one before, My trouble is that I expected to see vertical holes drilled into the bar to install lights down through but the light bar has small 1/2 holes on the back and I cannot figure out how to use those to install piaa lights.. Anyone have some suggestions or is there a mount that is designed to utilize these?
Light bar ![]() sets of screws on back one on each side. ![]() Thanks for the help! |
#2 |
PUSH MY EASY BUTTON
you won't be able to run the wires inside the bull bar which you have figured out already, what i did when i had a bar was tape them with black duct tape or electrical tape to the bar where it goes inside the bumper so it will look clean. i would not drill a hole in the bull bar other wise it will rust out. hope that helps
__________________
#3 |
#4 |
PUSH MY EASY BUTTON
i would contact the company that made your bull bar or let me see what i can find. what brand is it if you know.
__________________
#5 |
![]() Damn that truck looks sick!!! wish it was 4x4 though. anyone know who's it is? sorry to thread jack
__________________
#6 |
Guitarred and Feathered
most light mounts are welded to the bar..well all the ones ive seen are. I hope you can find some brackets to bolt on though, good luck!
__________________
A hard punch can often be used as a secret weapon to secure victory in an intellectual debate. |
#7 |
called the seller and the dealer told me it should have been in the box. They are going to send the mounts so that is what a deal! Pending delivery
| Display Modes | |
| new light bar with lights !!!!!!!!! | timbo805 | 2nd Gen. Tacomas | 14 | 09-27-2009 09:52 AM |
| PIAA driving light install | GeoTaco | 2nd Gen. Tacomas | 14 | 07-10-2009 09:20 AM |
| Piaa 510s, flood and spot lights and TRX450R bar mount. | razr | Buy / Sell / Trade | 6 | 04-11-2009 06:26 PM |
| N-Fab light bar and lights | jrobson | 2nd Gen. Tacomas | 18 | 03-26-2009 02:20 PM |
| Install Help - Recon LED Light Bar | pskubota | 2nd Gen. Tacomas | 1 | 05-14-2008 03:54 AM |
