HID Fogs and relays
Old 11-21-2009, 03:50 AM   #1
emerson [OP] emerson is offline
emerson has a spectacular aura aboutemerson has a spectacular aura about
emerson's Tacoma Gallery
HID Fogs and relays
hi names pete just picked up a 2010 dc off road. 1st post, been trolling for awhile.
Quick question, getting ready to install ddm 3k'sh into my factory fog lights. I was wondering if you needed a relay or not? Searched didnt come up with too much. Does the factory fogs already come with a relay installed? If i dont need a relay for the fogs could you please explain? thanks!!!
Old 11-21-2009, 09:34 AM   #2
Viet2100 is one of the sharper tools in the shedViet2100 is one of the sharper tools in the shedViet2100 is one of the sharper tools in the shedViet2100 is one of the sharper tools in the shedViet2100 is one of the sharper tools in the shedViet2100 is one of the sharper tools in the shedViet2100 is one of the sharper tools in the shedViet2100 is one of the sharper tools in the shedViet2100 is one of the sharper tools in the shedViet2100 is one of the sharper tools in the shedViet2100 is one of the sharper tools in the shed
Viet2100's Avatar
Viet2100's Tacoma Gallery
Send a message via Skype™ to Viet2100
There IS a relay in the engine bay for the fog lights. But, I do recommend using an additional relay harness just to be safe. Post pics when you're done!
Old 11-21-2009, 04:14 PM   #3
Hey thanks viet. Yeah i ll take some pictures when im done.
Old 11-21-2009, 05:39 PM   #4
taken with a camra phone
The headlights are ddm 5k and the fogs are the 3k's.
Old 11-21-2009, 09:09 PM   #5
Viet2100's Avatar
Nice!
Old 11-23-2009, 08:51 AM   #6
chaztoy is on a distinguished road
chaztoy's Tacoma Gallery
need help fog ligths
Hi this is chaztoy, having trouble with left fog light. not working. checked fuse and relay no luck
Old 11-23-2009, 09:16 AM   #7
XXXXXXXXXXXXXXXXXXXX
T@co_Pr3runn3r is one of the sharper tools in the shedT@co_Pr3runn3r is one of the sharper tools in the shedT@co_Pr3runn3r is one of the sharper tools in the shedT@co_Pr3runn3r is one of the sharper tools in the shedT@co_Pr3runn3r is one of the sharper tools in the shedT@co_Pr3runn3r is one of the sharper tools in the shedT@co_Pr3runn3r is one of the sharper tools in the shedT@co_Pr3runn3r is one of the sharper tools in the shedT@co_Pr3runn3r is one of the sharper tools in the shedT@co_Pr3runn3r is one of the sharper tools in the shedT@co_Pr3runn3r is one of the sharper tools in the shed
T@co_Pr3runn3r's Avatar
T@co_Pr3runn3r's Tacoma Gallery
My fogs are aftermarket wiring harness with oem switch since was base model & had no wiring. The harness I got with the lights has a relay & wired to the battery so would you really need extra wiring for 35w h10 HIDs in the fogs?
Old 11-23-2009, 05:05 PM   #8
Try switching around the power plug. Green is positive and the white with black stripe wire is negitive ground.
Old 01-02-2010, 06:19 PM   #9
Hahaha a month later and im having the exact same problem you are now. Did you ever find the fix?
Old 02-03-2010, 02:19 PM   #10
jus10 is on a distinguished road
jus10's Tacoma Gallery
hey guys, i just purchased some an HID kit 6k for my headlights on my 2010 taco sport and installed it. it was working fine for a couple hours and now they flicker and one side even goes out after flickering, is it because i need a relay? did you have to put in a relay for yours? thanks.
Old 02-03-2010, 02:23 PM   #11
mmmmmmbourbon.
xodeuce is one of the sharper tools in the shedxodeuce is one of the sharper tools in the shedxodeuce is one of the sharper tools in the shedxodeuce is one of the sharper tools in the shedxodeuce is one of the sharper tools in the shedxodeuce is one of the sharper tools in the shedxodeuce is one of the sharper tools in the shedxodeuce is one of the sharper tools in the shedxodeuce is one of the sharper tools in the shedxodeuce is one of the sharper tools in the shedxodeuce is one of the sharper tools in the shed
xodeuce's Avatar
xodeuce's Tacoma Gallery
The factory relay for the headlights should be perfectly capable of handling the current that the HID kit draws. The only purpose of the relay is because the switch that is in the stalk on your steering column can't handle the current, so instead the relay completes the headlamp circuit and will allow the higher current to flow safely without heating up. If you look at the specs on the HIDs they should actually draw less current than your stock lights.
Old 02-03-2010, 05:06 PM   #12
I ran a relay for the headlights just to be on the safe side. Theres a lot of people who run HID without a relay on their hondas without issue. I have hids on my bike and its been 2 years without any problems.
The flicker problem might be a bad ballast. Passenger side fog did the same thing would struggle to ignite, and then blow the fuse.
Old 02-04-2010, 11:46 AM   #13
thanks everyone, gonna try and exchange it
Old 02-28-2010, 06:01 PM   #14
blazze2005 is one of the sharper tools in the shedblazze2005 is one of the sharper tools in the shedblazze2005 is one of the sharper tools in the shedblazze2005 is one of the sharper tools in the shedblazze2005 is one of the sharper tools in the shedblazze2005 is one of the sharper tools in the shedblazze2005 is one of the sharper tools in the shedblazze2005 is one of the sharper tools in the shedblazze2005 is one of the sharper tools in the shedblazze2005 is one of the sharper tools in the shedblazze2005 is one of the sharper tools in the shed
blazze2005's Avatar
blazze2005's Tacoma Gallery
I want to do a HID kit to my oem fogs on my 05 tacoma...
Can someone please tell me how I would include the extra relay into the mix?
Anyone have a diagram how to include the extra relay into the fog kit from DDM?
thanks for any info...
Old 02-28-2010, 08:14 PM   #15
From what I was told theres a factory relay for the fogs already.
Old 02-28-2010, 10:54 PM   #16
Viet2100's Avatar
There is... to draw power from the source. You want to draw power from the battery.
55W HID in fogs Chachie Lighting 17 07-12-2010 11:57 AM
HID head/fogs TRDMEDIC Buy / Sell / Trade 10 06-22-2010 09:20 AM
HID smoked fogs gusher Lighting 3 04-14-2010 10:08 AM
HID Fogs, any issues? brian 2nd Gen. Tacomas 8 12-01-2009 01:48 PM
Those with HID fogs TRDMEDIC 2nd Gen. Tacomas 4 11-09-2009 07:58 PM
