Anytime Foglight mod explained electrical (diagrams)
Old 05-26-2013, 11:30 PM   #182
Torkt is on a distinguished road
Torkt's Avatar
Torkt's Tacoma Gallery
Thanks for all the great write-ups. Got a question for those of you much smarter than I.
How would I make it so my fog lights work exactly like stock except for they stay on with my high beams? I still want my toggle switch to function and I don't want them on with the DTL. Is there an easy variation of the mods listed here?
Thank you.
Old 11-02-2013, 11:37 AM   #184
2006 Access Cab
ALS2000 is on a distinguished road
ALS2000's Tacoma Gallery
The "Foglights on anytime" mod disabled the DRL mod. Is there a way to have both work together?
Old 11-02-2013, 11:52 AM   #185
My drinking team has a wheeling problem
V5ioV is one of the sharper tools in the shedV5ioV is one of the sharper tools in the shedV5ioV is one of the sharper tools in the shedV5ioV is one of the sharper tools in the shedV5ioV is one of the sharper tools in the shedV5ioV is one of the sharper tools in the shedV5ioV is one of the sharper tools in the shedV5ioV is one of the sharper tools in the shedV5ioV is one of the sharper tools in the shedV5ioV is one of the sharper tools in the shedV5ioV is one of the sharper tools in the shed
V5ioV's Avatar
V5ioV's Tacoma Gallery
it does NOT disable it! read the last few post here… this may be what's happening…
http://www.tacomaworld.com/forum/2nd...ml#post7650974
Old 11-02-2013, 12:17 PM   #186
2006 Access Cab
Thank you for your reply - both DRL and Fog Lights do work.
Old 11-05-2013, 09:27 AM   #188
2006 Access Cab
Old 11-17-2013, 09:59 AM   #189
SpeedwayTaco160 is just really niceSpeedwayTaco160 is just really niceSpeedwayTaco160 is just really niceSpeedwayTaco160 is just really niceSpeedwayTaco160 is just really nice
SpeedwayTaco160's Avatar
SpeedwayTaco160's Tacoma Gallery
How do I tap into the green wire without the radio pin and cutting into the wire for my 2010 Tacoma??? thanks im sure I missed it.
Old 11-24-2013, 12:50 PM   #190
zk6760 is on a distinguished road
zk6760's Tacoma Gallery
I used JiveWalkers method on my 2010 OR and it works as expecte.
My only question is: the male connection that I stuff into the ignition port isn't very secure/tight. I can easily pull it out myself. Should I be concerned about this and is it a fire hazard if it were to somehow slip out while driving?
The dividers within the box itself press on the wiring between the fog relay and the ignition area so that should hold it relatively in place, but wanted to ask the question.
Thanks!
Old 11-25-2013, 07:34 PM   #191
ndcmack is one of the sharper tools in the shedndcmack is one of the sharper tools in the shedndcmack is one of the sharper tools in the shedndcmack is one of the sharper tools in the shedndcmack is one of the sharper tools in the shedndcmack is one of the sharper tools in the shedndcmack is one of the sharper tools in the shedndcmack is one of the sharper tools in the shedndcmack is one of the sharper tools in the shedndcmack is one of the sharper tools in the shedndcmack is one of the sharper tools in the shed
ndcmack's Avatar
ndcmack's Tacoma Gallery
Originally Posted by Crom View Post
It's so simple that some people make it out to be harder than it is.
Here is my version:
Pop the fuse and bend the leg. ( It may take some gentle wriggling with the needle-nose pliers, and some heft to pull the fuse out. )
Route and attach the wire using the quick splice
Your done!
Your welcome. Me too!
What gauge wire are you all running for this? I've already done teh mod and love it, but was just wondering...
Old 12-28-2013, 05:32 PM   #192
baurat88 is on a distinguished road
baurat88's Tacoma Gallery
Is it bad to tap into that green ignition wire twice with two sets of lights? I have my anytime fog mod, but just put in an LED bar i want powered only when the ignition is on. Would it overload that wire to have both sets of lights tapped in?
Old 02-10-2014, 12:34 AM   #193
808 Zombie Outbreak Tactical Response Team K9 Unit
DJSPEC is one of the sharper tools in the shedDJSPEC is one of the sharper tools in the shedDJSPEC is one of the sharper tools in the shedDJSPEC is one of the sharper tools in the shedDJSPEC is one of the sharper tools in the shedDJSPEC is one of the sharper tools in the shedDJSPEC is one of the sharper tools in the shedDJSPEC is one of the sharper tools in the shedDJSPEC is one of the sharper tools in the shedDJSPEC is one of the sharper tools in the shedDJSPEC is one of the sharper tools in the shed
DJSPEC's Avatar
DJSPEC's Tacoma Gallery
Originally Posted by jivewalker View Post
I did this on my 2011. 2012 and 2013 may be different.
Done with fog light mod in 10 minutes! I used a male thin profile blade connector from a stereo harness and slid it into the factory harness behind the ignition wire. Didn't like the idea of cutting into the factory wire, and this is a super tight connection. Anyway, pics below and thanks for all the info! Cmatt, glad you figured it out man!
Crom, BTW, probed the block and all are hot +12v unswitched
Not to bring this back from the dead, but this method worked awesome for me. I used a connector from a left over 9004 HID harness that I had. Then zipped tied that wire to the other wires going into that harness to secure it in. Fogs lights work great, and I feel better about this method than the fuel pump relay method. Thanks!!
Old 02-10-2014, 09:23 AM   #194
Crom [OP] Crom is online now
Time is precious; use it wisely
Crom is one of the sharper tools in the shedCrom is one of the sharper tools in the shedCrom is one of the sharper tools in the shedCrom is one of the sharper tools in the shedCrom is one of the sharper tools in the shedCrom is one of the sharper tools in the shedCrom is one of the sharper tools in the shedCrom is one of the sharper tools in the shedCrom is one of the sharper tools in the shedCrom is one of the sharper tools in the shedCrom is one of the sharper tools in the shed
Crom's Avatar
Crom's Tacoma Gallery
Don't remember, 24 AWG?
Old 02-13-2015, 05:26 PM   #195
rocky100370 is on a distinguished road
rocky100370's Tacoma Gallery
Will this work on the 2014 as well? Fuse panel looked a little bit different.
THANKS!
Old 02-14-2015, 02:51 AM   #197
Originally Posted by SpruceTaco View Post
Worked on my '12, should be the same.
Look at post #133 in this thread.
Thanks Mike. Going to do this today and will post results.
Old 02-15-2015, 10:15 PM   #198
Johnny E is a name known to allJohnny E is a name known to allJohnny E is a name known to allJohnny E is a name known to allJohnny E is a name known to allJohnny E is a name known to all
Johnny E's Avatar
Johnny E's Tacoma Gallery
Talking
Follow-up
Nothing but success, mod is almost 3 years old and never caused any issue. Just on an off when I want them, which is all the time. Come to think of it the bulbs have been good too considering the have been on for 36000 km
Old 02-21-2015, 01:12 PM   #200
IRoniKdiMension
scott96929 is on a distinguished road
scott96929's Avatar
scott96929's Tacoma Gallery
Completed Foglight Anytime Mod
This mod was so easy. I believe a fifth grader could do it........LOL
All it took was wiring the fog light relay to the ignition wire. See the RED wire.
Fog lights whenever you want them.
2012 foglight anytime mod ? Hydrolai Lighting 117 12-15-2014 09:23 AM
2010 Electrical Diagrams Nick54 2nd Gen. Tacomas 1 04-25-2011 08:32 PM
Foglight on anytime mod for 2010? j0sh Lighting 9 07-12-2010 05:16 PM
electrical diagrams here mudduck Technical Chat 1 03-03-2009 07:11 PM
foglight mod Johnson8537 2nd Gen. Tacomas 17 07-16-2008 08:03 PM
