06 Instrument panel dimmer switch
Old 01-10-2010, 10:36 AM   #1
Eazyrider [OP] Eazyrider is offline
Eazyrider is on a distinguished road
Navy: Retired
Eazyrider's Tacoma Gallery
How do you remove the instrument dash board dimmer switch on a 2006 Tacoma. Once I remove it, how do I check to see if it is working properly with a tester. I've already checked all the fuses and all look ok.
Old 01-10-2010, 11:07 AM   #2
DDD DDD is offline
Shine bright like a hymen
DDD is one of the sharper tools in the shedDDD is one of the sharper tools in the shedDDD is one of the sharper tools in the shedDDD is one of the sharper tools in the shedDDD is one of the sharper tools in the shedDDD is one of the sharper tools in the shedDDD is one of the sharper tools in the shedDDD is one of the sharper tools in the shedDDD is one of the sharper tools in the shedDDD is one of the sharper tools in the shedDDD is one of the sharper tools in the shed
DDD's Avatar
DDD's Tacoma Gallery
What is wrong with your instrument cluster? Doesn't light up? No gauges working? Won't dim / brighten? Here is a troubleshooting guide.
If you just want to test the "Light Control Rheostat" (dimmer switch) then read this guide. You will need a multi meter to test the voltage.
Old 01-15-2010, 09:28 PM   #3
Navy: Retired
Unhappy 06 instrument panel dimmer switch
The tach, speedometer, temp, oil, clock, radio all work fine. What is happening is the illumination bulbs aren't working (temp control dials, radio controls). All the small bulbs on the center console are out. Checked all the fuses (good), dimmer switch works fine on the speedometer and stuff, just not the center console. Hope my explanation isn't too confusing. Looking at the wiring diagram, it seems that the dash dimmer switch has two different functions. One for the speedometer area and one for the center dash area. How do I remove the dimmer switch to test it without scratching my dash up. HELP ME PLEEEZE!
Old 01-15-2010, 09:39 PM   #4
DDD DDD is offline
DDD's Avatar
Here is the factory service manual.
You can read how to take apart almost everything.
Old 01-16-2010, 07:49 PM   #5
Navy: Retired
Thanks "db67fm"...this will help out a heap and I've got the answer to my question.
Does anyone actually use their dimmer switch? sporttracguy 2nd Gen. Tacomas 58 01-29-2012 03:47 PM
Dash Dimmer Switch Rellik01 Lighting 0 10-21-2011 03:52 AM
Light switch dimmer majinbu32 1st Gen. Tacomas 0 10-08-2011 09:13 AM
instrument panel williamss 2nd Gen. Tacomas 6 04-02-2009 09:48 AM
Instrument dimmer rheostat question. RaiderSix 1st Gen. Tacomas 1 03-30-2008 07:34 AM
