considering 05-10 Tacoma LED Strip Projector Headlights - Black (R8 Style)
Discussion in 'Lighting' started by AtlanticTubes, Feb 22, 2010.
  1. Feb 22, 2010 at 5:37 AM
    AtlanticTubes
    AtlanticTubes [OP] Member
    Sag Harbor
    2018 TRD Sport DCSB Cement
    265/70/R17 BFG all terrains, American Racing AR172, Icon Stage 2 Lift kit, bed mat, sill protectors, Pro Grill, Pro Skid Plate
    Has anybody seen these headlights yet?
    05-10 Toyota Tacoma LED Strip Projector Headlights - Black (R8 Style)
    from DashZracing
    if so and have pics...lets see them.
  2. Feb 22, 2010 at 5:41 AM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    20 Gladiator Rubicon
    Steersmarts Draglink, Tie rod, Track Bar
  3. Feb 22, 2010 at 5:42 AM
    Jigzor
    Pennsylvania
    Oh, and welcome to TW.
  4. Feb 22, 2010 at 5:12 PM
    AtlanticTubes
    Sag Harbor
    thnx for the quick response.
    but does anybody have these installed on their tacoma?
    pics>
  5. Feb 22, 2010 at 5:36 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
  6. Feb 25, 2010 at 12:10 PM
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    stop considering....;)
  7. Mar 2, 2010 at 9:12 AM
    RDAY
    RDAY Well-Known Member
    NY
    07 Tacoma SR5 4x4
    still gonna be nothing like a retro tho
  8. Mar 2, 2010 at 9:14 AM
    TacoTron
    TacoTron Tacotronn
    Anthony
    Denver, CO
    07 Toyota Tacoma
    I had one type of the projector headslights and im probably gonna go back to stock and retro fit them this would be the best picture i would have [​IMG]
  9. Jun 26, 2012 at 5:47 PM
    Techoma
    Techoma This is the Wild, Wild, West!
    John
    Alta Mesa, AZ
    Extreme Expo 05 PreRunner
    Dirty fives on Level 8s, 4.88 gears and Harrod Locker on rear. Cab Chop x2, MBRP Cat Back Dual Exhaust w Flowmaster 44 for punch, cut off at rear axle, Throttle Body spacer, Camburg UCA and Coil-Overs, Matrix Spindle lift up front ProComp extended travel on rear w\ Dakar leafs +, Panasonic HU w Front x2 and rear x1 camera, kicker 500 powering 2 JL Audio 10" subs, JL component speakers in front doors and JL audio coaxials in rear doors powered by alpine 600 amp. Cobra all in one CB, Easy Lift hood, and Easy Down Tailgate, Pop N Lock, Dual RGB Halo Projectors, Blacked out tails with HI intensity LED's, Scanguage II, AVID Custom sliders and Hybrid rear bumper, Pelfreybilt Hybrid front, Glock Steering Column Holster, 2 Hella's behind Satoshi on Avid light Bar, Decepticon Badges, 2x 24" LED ropes and 2X 4" HI LEDs to fire up Satoshi w Super Bright green Halo's. Under Hood lighting as well as RGB rock lights. PrinSu Cab/Shell Rack with FreeSpirit hard shell RTT, 28", 2x 20", and 50" LED Bars all controlled by SwitchPros and Weathertechs front and rear.
    i like mine! Changed out the 194s with high intensity 194 stubby leds! :D
  10. Jun 26, 2012 at 6:05 PM
    Johns Taco
    Johns Taco I'm not 4x4, and have an open diff. So i'm 4x1
    John
    Albuquerque, NM
    05 DSM Base SR5 Slug Taco
    Full custom stereo, onboard air compressor, train horns, spacer lift, 30" tires, optima yellow top, rear slider window & tailgate anti-theft mod, pop & lock, class 3 tow hitch, lights in bed, Ultra Gauge, Weather Tech mats, yellow fog lights, camper top, air lift rear airbags, rear diff breather mod, soon to be more...
    John, the front of your truck looks awesome! John
  11. Jun 26, 2012 at 6:18 PM
    Johns Taco
    John
    Albuquerque, NM
  12. Jun 27, 2012 at 5:34 AM
    Techoma
    John
    Alta Mesa, AZ
  13. Jun 27, 2012 at 5:52 AM
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    I have the black ones!!! I love them csjumper and I put HID's in them and wired all of it up. Fairly easy to wire.
  14. Jun 27, 2012 at 5:55 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    The projector performance on those is horrible. I don't recommend looks over performance when it comes to lighting. There just is too much to risk.
  15. Jun 28, 2012 at 7:00 AM
    Techoma
    John
    Alta Mesa, AZ
    They look good, YES. The projector top line looks to have an almost "eyelash" effect which is nowhere as clean (perfect horizontal line) as my 2012 Highlander stock projectors. With that being said... with HID's installed, there is PLENTY of light, and MUCH better than stock or the brightest non HID bulbs in a non projector housing. I've been through literally 8 or 9 combinations of housings and bulbs up to this point. I can see great... and I never get "flashed" anymore. With my OEM's with BLHM and 55W HID's... people flashed me all the time. I may have had better side light... but that is it. If I need more light for off road... well a click of a toggle switch will cure that! :D
  16. Jun 28, 2012 at 7:14 AM
    Techoma
    John
    Alta Mesa, AZ
    I'm contemplating opening mine up and going BHLM. If I do, I want to turn the "BMW"rings green. I was trying to find the bulb to change it a couple weeks ago... but it appears they are internal.
  17. Jun 28, 2012 at 9:02 AM
    yosh2000
    CO
    '17 Tundra CM 5.7
    my OEM reflector w/ 85w bulbs and upgraded wiring would blow those projectors away...just sayin...even if you installed a cheap PNP kit....
  18. Jun 29, 2012 at 6:46 AM
    Techoma
    John
    Alta Mesa, AZ
    Focused light... being able to see far enough to dive with just the headlights and not blinding oncoming traffic... It works for me. Got Glare? Yup... and I only use it off road. I prefer my HID's in Projectors.... Had em in the stock reflectors... and can see just as far... but I'm sure your OEM reflectors are much better than my OEM reflectors were.
  19. Jul 15, 2012 at 6:11 PM
    Rascal737
    Rascal737 Well-Known Member
    Oliver
    Abbotsford, BC
    09 Silver DCLB TRD Sport 4X4
    Python 574 Remote start/Security system, reusable cabin air filter, led map and dome lights, led bed lights, switchback dtrl's, aftermarket dual halo projector headlights retrofitted with TRS goodies, foglights on anytime, Illuminated 4X4 switch, Redline hood struts and EZ down tailgate, Weathertech front and rear floor liners, Black Westin 4" oval step bars
    NFS257, how did you wire up the HID's....our trucks only have the one connector for the hi/low beams and your aftermarket lights have the hi and low beams seperate??
    reason I'm asking is that I just got the same lights and want to put HID's in them but can't seem to figure out the wiring so that my hi beams still work (not HID's)
  20. Jul 15, 2012 at 6:33 PM
    Rascal737
    Oliver
    Abbotsford, BC
    These are the one's I just put in a couple of days ago
