Hella 500 HID Conversion & Mount Behind Satoshi *How To* w/ pics
Old 10-06-2013, 09:32 PM   #361
REDNICK is on a distinguished road
REDNICK's Avatar
REDNICK's Tacoma Gallery
Originally Posted by Kavik View Post
Don't do 55w Ballasts, you will melt your lenses.
55w ballasts won't melt your lenses. The stock lights that come with the Hella's are 55w bulbs so there is absolutely no additional heat being produced from the 55w HID kit. Look online and some people actually put 100w bulbs in their Hella's with no melting occurring (most people also upgrade to heavier wiring if they choose to do this).
Old 10-07-2013, 06:20 AM   #362
Gus 524 is one of the sharper tools in the shedGus 524 is one of the sharper tools in the shedGus 524 is one of the sharper tools in the shedGus 524 is one of the sharper tools in the shedGus 524 is one of the sharper tools in the shedGus 524 is one of the sharper tools in the shedGus 524 is one of the sharper tools in the shedGus 524 is one of the sharper tools in the shedGus 524 is one of the sharper tools in the shedGus 524 is one of the sharper tools in the shedGus 524 is one of the sharper tools in the shed
Gus 524's Avatar
Gus 524's Tacoma Gallery
Good to hear. Thanks for sharing.
Old 10-23-2013, 08:56 AM   #363
Gonzo714 is on a distinguished road
Gonzo714's Tacoma Gallery
JUST CURIOUS, DO I NEED AN HID HARNESS WITH THE 55W/6000K FROM DDM WITH THE HELLA 500? OR JUST LIGHTS AND HID KIT?
THANKS
Old 10-28-2013, 06:50 PM   #364
REDNICK's Avatar
I believe you can get away with just using the harness that comes with the Hellas. Personally I decided to go ahead and buy the harness with my VVME HIDs.
Old 10-31-2013, 10:04 PM   #365
Are your lights close to your grill craft? I have the same and want to be able to see the lights when not turned on during the day.
Cheers
Old 11-02-2013, 07:24 AM   #366
Eat right, be fit, die anyway
zacharypaul89 is one of the sharper tools in the shedzacharypaul89 is one of the sharper tools in the shedzacharypaul89 is one of the sharper tools in the shedzacharypaul89 is one of the sharper tools in the shedzacharypaul89 is one of the sharper tools in the shedzacharypaul89 is one of the sharper tools in the shedzacharypaul89 is one of the sharper tools in the shedzacharypaul89 is one of the sharper tools in the shedzacharypaul89 is one of the sharper tools in the shedzacharypaul89 is one of the sharper tools in the shedzacharypaul89 is one of the sharper tools in the shed
zacharypaul89's Avatar
zacharypaul89's Tacoma Gallery
Hate to revive this thread, but my Hella 500's came in yesterday and I plan on installing them today. My HID kit won't be here until late next week, but I'm ready to install TODAY! Will it be troublesome to go ahead and install everything today and then just take the lights out when my HID kit gets here or should I just be patient and wait?
And just to be sure, this is the HID kit I ordered from DDM. Everything look right?
DDM HID Kit With Slim Ballast - 35W or 55W (Xenon)
35W
H3 bulb
4500K bulb color
no mounting brackets
no HID harness
no error eliminator
no adapter cables
Old 11-02-2013, 02:46 PM   #367
Gus 524's Avatar
35W
H3 bulb
4500K bulb color
no HID harness
no error eliminator
no adapter cables
I made the mounting bar and painted my radiator before I received the lights. Definitely would do it this way again because it cut down time significantly. So to answer your question it would be very troublesome to do the wiring before actually being able to wire anything ha ha Looks like you ordered the correct hids. I ordered the 55 watts because they significantly brighter according to ddm's website. Also i got the mounting brackets so i didn't have to use Velcro. Good luck and post some pics for sure!
Old 11-03-2013, 06:51 AM   #368
I will! I just got started and already have run into problem #1. How the heck do I run the angle iron across without removing the hood latch? Also, if I remove the hood latch, how the heck do I keep my hood closed!? Frustrated!!!!
Old 11-03-2013, 06:58 AM   #369
Kavik
Kavik is one of the sharper tools in the shedKavik is one of the sharper tools in the shedKavik is one of the sharper tools in the shedKavik is one of the sharper tools in the shedKavik is one of the sharper tools in the shedKavik is one of the sharper tools in the shedKavik is one of the sharper tools in the shedKavik is one of the sharper tools in the shedKavik is one of the sharper tools in the shedKavik is one of the sharper tools in the shedKavik is one of the sharper tools in the shed
Kavik's Tacoma Gallery
You don't have to remove the hood latch, just the hood latch guard. Are you just using one piece of angle iron? Did you make drop down brackets?
Old 11-03-2013, 12:38 PM   #370
I got it figured out. I did it w/o drop down brackets. I'm gonna go back and put the brackets on so they'll sit in the middle of the grill. I don't like how the top of the lights are cut off
EDIT: night time
Old 03-04-2014, 01:12 PM   #371
Bruceleeroy30 is on a distinguished road
Bruceleeroy30's Avatar
Bruceleeroy30's Tacoma Gallery
Just want to say thank you Op for the write up!
Old 04-13-2014, 08:31 AM   #372
freshp0w is on a distinguished road
freshp0w's Tacoma Gallery
Where did you put the ground wire on the switch in the cab? Pic would be great!
Old 06-09-2014, 05:10 PM   #373
Talk slow, shoot fast.
DirtyDTaco is one of the sharper tools in the shedDirtyDTaco is one of the sharper tools in the shedDirtyDTaco is one of the sharper tools in the shedDirtyDTaco is one of the sharper tools in the shedDirtyDTaco is one of the sharper tools in the shedDirtyDTaco is one of the sharper tools in the shedDirtyDTaco is one of the sharper tools in the shedDirtyDTaco is one of the sharper tools in the shedDirtyDTaco is one of the sharper tools in the shedDirtyDTaco is one of the sharper tools in the shedDirtyDTaco is one of the sharper tools in the shed
DirtyDTaco's Avatar
DirtyDTaco's Tacoma Gallery
I ordered some hella 700ff's and the HID Kit from DDM, and haven't found a wiring diagram anywhere.. Is this that I've drawn up far from accurate?
Old 06-15-2014, 07:46 AM   #375
Vivid Illumination
memario1214 is one of the sharper tools in the shedmemario1214 is one of the sharper tools in the shedmemario1214 is one of the sharper tools in the shedmemario1214 is one of the sharper tools in the shedmemario1214 is one of the sharper tools in the shedmemario1214 is one of the sharper tools in the shedmemario1214 is one of the sharper tools in the shedmemario1214 is one of the sharper tools in the shedmemario1214 is one of the sharper tools in the shedmemario1214 is one of the sharper tools in the shedmemario1214 is one of the sharper tools in the shed
memario1214's Avatar
memario1214's Tacoma Gallery
Old 06-15-2014, 09:59 AM   #376
DirtyDTaco's Avatar
Originally Posted by memario1214 View Post
It worked haha. Just finished like an hour ago
Old 07-15-2014, 04:30 PM   #377
fla taco is on a distinguished road
fla taco's Avatar
fla taco's Tacoma Gallery
sub'd
Old 07-15-2014, 07:12 PM   #378
Nuke and Neuter
gipsyfetus will become famous soon enough
gipsyfetus's Avatar
gipsyfetus's Tacoma Gallery
Send a message via AIM to gipsyfetus
subba'd durka durka
Feeler: Hella 500ff & HID Conversion Muy Grande Buy / Sell / Trade 36 08-15-2011 11:29 AM
Hella 500 HID Conversion NwiTACO Lighting 22 04-13-2011 07:44 AM
Feeler: Hella 500/700 HID conversion service RelentlessTaco Buy / Sell / Trade 76 02-27-2011 08:19 AM
FS: (2) Hella 500 HID Conversion 1337Taco Buy / Sell / Trade 4 01-02-2011 05:42 PM
Hella 500 black magic hid conversion motoxmann Lighting 11 07-01-2010 08:26 AM
