HOW TO: Tinting tail lights, The right way (PICS)
Discussion in 'Lighting' started by THExBUSxDRIVER, Apr 1, 2010.
  1. Apr 1, 2010 at 5:51 PM
    THExBUSxDRIVER
    THExBUSxDRIVER [OP] Victory is reserved...
    GOO5E
    Old Man Tan!
    Not enough.
    So I used the search feature but never could find a how to thread for this, so I went ahead and made one. Hopefully it isnt a repost.
    And please be gentle as this is my first write-up:eek:
    This is easier to do in a well lit area....like outside lol.
    Tools and equipment needed:
    -- Ratchet with 10mm socket
    -- Powder free latex gloves (optional)
    -- 800 grit sandpaper
    -- 1000 grit sandpaper (optional)
    -- 2000 grit sandpaper
    -- Microfiber towel (optional as paper towels worked well also)
    -- De greaser liquid (I just used gasoline)
    ****I would like to add that if you dont have a buffing wheel, you could just purchase a headlight restore kit from 3M that is sold at autozone or any other parts store and used the buffing wheel that is included.****
    -- Now you can do your tail lights and restore luster to your headlights:D
    -- VHT NiteShades
    -- Clear coat (any one will do, I used the plain 'ol clear)
    uvresitclear_a75aa90c78005796f97982243ea31626ec43e67d.pngimages_0fedd37187e1ad0ffa3fa588d34ccbd24e360e78.jpg
    --Rubbing compound of your choice along with Meguiars PlastX
    -- Any polishing product of your choice.
    Along with a tool to apply the polish and rubbing compounds, otherwise it will have to be done by hand....time consuming.
    So we start off with the tail light, untouched in all its stock glory
    So to remove the rear light you will use the 10mm socket
    --There are only 2 bolts per side.
    --They are the highest and lowest ones, leave the other in between alone as they do not hold the light. (sorry no pic)
    Once those are removed it time to pull the light out. There are 2 prongs that hold them in and they will take some force to get them to let go.
    Then disconnect the light bulbs with some simple twists
    Next use your product to clean the light off. (I used gasoline)
    Take the 800 grit paper and start to sand the light while using water. (I recommend to let the papers soak in water while removing the lights, this makes them a bit more flexy and easier to work with)
    --Between different grits, wipe down the light and dry it to see that you have got the whole light.
    Once you are done with the 800, start to use the 1000, then drop to the 2000 grit paper
    --The 2000 will make it look like it has a flat smooth satin look.
    Once done with the sanding all together, wipe the light down with your cleaning product( Again, I used regular 'ol gasoline;)). Then let them sit to dry. Using the microfibers will help speed it up.
    -- Once they are dry try not to touch the lens surface with your fingers as this will put grease on them, powder free latex gloves come in handy.
    So the lights are dry now, good. They should both look like they have the same consistency in texture.
    --Now you are ready to apply the VHT NiteShade, remember that it will cure a bit darker than what it looks like freshly sprayed.
    **Allow 20-30 min between tint coats**
    Hold the can about 7 inches away from the light for better coverage. On the can it says like 12 inches but this will only give you a speckled look and will make you use more coats for good coverage....and more coats means darker lights (which can be a problem with local law enforcement)
    Here is the difference after one coat
    ***For best and most even results, stand the sanded lights up next to each other and spray across both to get the same coverage on both.***
    Sun's position made them look a bit different from each other but they where even:D
    Here is one after 3 coats and a test to see how it would look
    Once you are satisfied with the level of tint let the light dry to the touch, then cure in sun light for about 45-60 min.
    When the tint is dry, apply the clear coat of your choice. (I used Krylon with gloss finish)
    **It says it dries in 10 min but give it 15min between coats.**
    I recommend at least 7-13 coats of clear for better protection, and it'll keep the buffing wheel from burning through the clear to the tint. Be happy to apply more if you wish.
    Try to avoid letting the clear run at all cost.
    Here it is with 5 coats of clear. Ignore the water spots lol.
    Once COMPLETELY dried, repeat the sanding steps in the same order, but this time use more strokes with LESS FORCE. Remejber to have patience at this level.
    This sanding step will get rid of that 'orange peel' effect/texture.
    And here is the clear coat sanded.
    Now, the lights are sanded, you are ready to use the rubbing compound.
    --I mounted the light to do this because I had no other way to hold them steady, besides its only rubbing compound and polish so your truck wont get hurt.
    Apply good amounts of rubbing compound to your application tool or the rag that you will be using. If using a power drill this stuff WILL get flung all over the place so be ready for a bit of a mess.
    ((***Remember to rub it clean in between applications of the compound, the PlastX, and the final wax***))
    After you are done applying the compound, move on to using the Meguiars PlastX to take out the finer scratches.
    Then finally move on to the waxing product of your choice to seal the deal.
    Here is the finished product:D
    The looks I have gotten from other taco owners is fun, I have even bee asked to do a pair:D:D
    Hope this helps you guys out, and have fun! But most of all PATIENT!
    Sleepzombie, Jessel, Blais03 and 11 others like this.
  2. Apr 1, 2010 at 6:00 PM
    05PreRunner
    05PreRunner "Living life in the FAST lane..."
    <-(714)-> SO-CAL
    TRD intake, JBA "shorty" headers, URD y-pipe
    Great Write-Up!
    Lights look nice!! :thumbsup:
  3. Apr 1, 2010 at 6:00 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    awesome i need to do this! +1
  4. Apr 1, 2010 at 6:01 PM
    littledvl
    littledvl ride BMX!
    Eric
    Saint Leonard MD
    08 taco dc 4x4 / 15 tundra dc 4x4
    Too many to list
    Great write up, I will being doing this within the next few weeks.
  5. Apr 1, 2010 at 6:02 PM
    tacomakid96
    tacomakid96 Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
    Great write up!! Looks awesome on your truck man
  6. Apr 1, 2010 at 6:07 PM
    jodiddly33
    jodiddly33 Well-Known Member
    Jonah
    DFW
    2010 Golf TDI
    wow those look awesome!
  7. Apr 1, 2010 at 6:08 PM
    THExBUSxDRIVER
    GOO5E
    Old Man Tan!
    Not enough.
    I would like to add that if you dont have a buffing wheel, you could just purchase a headlight restore kit from 3M that is at autozone or any other parts store and used the buffing wheel that is included.
    I'll add this to the write up
  8. Apr 1, 2010 at 6:12 PM
    Oskie_78
    Oskie_78 Well-Known Member
    Texas
    1998 4Runner, 2016 4Runner, 2023 Tacoma
    GreAt job on those tail lights! I wanna to this to mine
  9. Apr 1, 2010 at 6:15 PM
    jodiddly33
    Jonah
    DFW
    2010 Golf TDI
    BTW can you let us know if they cure any darker over time?
  10. Apr 1, 2010 at 6:53 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    Outstanding!
  11. Apr 1, 2010 at 6:54 PM
    JoshR324
    JoshR324 Well-Known Member
    Garden Grove, CA
    '14 SR5 Double Cab LB
    Great write-up
  12. Apr 1, 2010 at 6:58 PM
    JM76
    JM76 Ride On
    Jon
    SC
    2016 AC SR 4x4
    bone stock save for the block lift that came on it with the open country m/t.
    too bad you are across the country, you could do mine. Nice work!:)
  13. Apr 1, 2010 at 7:04 PM
    ClemsonTacoma
    ClemsonTacoma Well-Known Member
    Cam
    Lexington, SC
    Tacoma
    Pioneer DEH-P5100UB single din HU and black dash kit, Alpine 12" sub custom inverted box bed liner'd, various interior trim painted black, 48 blue LED domelight, cheepo floor mats, hose clamp mod, Cobra CB and knock off firestik, Stock steelie rims, with 265/75/16 Sumitomo HTR Sport A/T's
    Great write up! :thumbsup:
  14. Apr 1, 2010 at 7:08 PM
    747 function > form
    1st Gen.
    Nice writeup! Lights look stealthy! Is that a '92 Mustang in the background...if so, post pics...sweetest body styling of all the stangs (imo)!
  15. Apr 1, 2010 at 7:12 PM
    Tillers_Rule
    Tillers_Rule ......................
    Jeff
    San Diego
    4x4 Sport, debadged
    Icon coil overs up front, Total Chaos UCA, Icon remote reservoir in the back with Deaver 11 pack leafs. Sunroof, Hella 500's behind grill.
    Nice! Going down your pictures I was thinking; "wow, that looks like shit" Then when I got to the last pics after it was buffed, I was like; "wow, that shit looks awesome!!":thumbsup:
  16. Apr 1, 2010 at 7:41 PM
    Simon2150
    Simon2150 Well-Known Member
    Austin, TX
    06 Tacoma DoubleCab V6 SR5
    Awesome job!
  17. Apr 1, 2010 at 8:13 PM
    TorenApart
    TorenApart Well-Known Member
    06 Double Cab SR5 TRD Sport
    Toytec Ultimate Lift Kit, OME Nitrocharger shocks and Dakar leafs, Total Chaos UCA's, 18'' Black XD Monster, 285/60R18 Cooper Zeon LTZ, Leer shell, OEM Skid Plate, Weather Tech Floor Mats, Lund Tonneau, Custom 2-tone gray leather, Aero Turbine 2525 muffler with AR25 resonator, Aero Turbine Exhaust Tip, Mr. Marv subwoofer enclosure w/ 2 JL 10W3v2's, AFE Pro Dry S, Eclipse AVN-6620, Pioneer PRS-D2100T, Hybrid Audio Clarus 6.5'' Front Components, Black Headlight Mod, Tinted tail lights, PL5300 with Eclipse BEC-109
    Sticky this... or add to cheap/free mods!
  18. Apr 1, 2010 at 8:18 PM
    skunk
    skunk what did I miss?
    Rudi
    SoCal
    2010 TRD 4x4 (STOLEN)
    YOU WILL BE MISSED Satoshi Grill, FX-R retros, husky liners, bed bolt d-rings, TRD short throw shifter, 2.5 Fox Coil overs, AP UCA's, AP Expo rear leaf with Fox 2.0 shocks, Extended SS brake lines, AP kick-out sliders, 265/75/16 on Konig Countersteers, AllPro Apex front bumper and Zip Ties.
    FRIGGIN SAH-WWWEEEEET! I have been wondering how the process went. You did a great job. I'm definitely doing this mod next!:D
  19. Apr 1, 2010 at 8:20 PM
    Cars0n`
    Cars0n` Well-Known Member
    Carson
    Alberta
    03 2.7L 4x4 5spd
    awesome job man. i needed this ;)
  20. Apr 1, 2010 at 8:25 PM
    Palmetto Pete
    Palmetto Pete Well-Known Member
    Pete
    In the Mountains
    2012 SSM TRD Sport DCSB 4x4
    3M Paint Pro Film, OEM Bed Mat, Antenna X, WeatherTech Floor Mats, Foglight Anytime Mod, 8000k HIDs, BFG AT/KOs (265/70/17), Debadged, Ultra-Gauge, Leer 100XR
    Awsome job, look and write-up! Thanks!
