DTRL toggle switch mod (stealth mode)
Old 05-15-2013, 05:51 PM   #141
Greenbergler is one of the sharper tools in the shedGreenbergler is one of the sharper tools in the shedGreenbergler is one of the sharper tools in the shedGreenbergler is one of the sharper tools in the shedGreenbergler is one of the sharper tools in the shedGreenbergler is one of the sharper tools in the shedGreenbergler is one of the sharper tools in the shedGreenbergler is one of the sharper tools in the shedGreenbergler is one of the sharper tools in the shedGreenbergler is one of the sharper tools in the shedGreenbergler is one of the sharper tools in the shed
Greenbergler's Avatar
Greenbergler's Tacoma Gallery
This still won't let me have them on with my headlights??
Old 05-20-2013, 06:06 AM   #142
cdelgado14 is a splendid one to beholdcdelgado14 is a splendid one to beholdcdelgado14 is a splendid one to beholdcdelgado14 is a splendid one to beholdcdelgado14 is a splendid one to beholdcdelgado14 is a splendid one to behold
cdelgado14's Tacoma Gallery
Nice
Old 07-19-2013, 11:25 PM   #143
raymond5711 is on a distinguished road
raymond5711's Avatar
Army: Infantry Platoon Sergeant
raymond5711's Tacoma Gallery
I just cut that green/red wire and did not install the switch and tested everything, and it works. No more DTRL
Old 08-26-2013, 01:39 PM   #144
"GO DUCKS" Edition
Oregon TRD is one of the sharper tools in the shedOregon TRD is one of the sharper tools in the shedOregon TRD is one of the sharper tools in the shedOregon TRD is one of the sharper tools in the shedOregon TRD is one of the sharper tools in the shedOregon TRD is one of the sharper tools in the shedOregon TRD is one of the sharper tools in the shedOregon TRD is one of the sharper tools in the shedOregon TRD is one of the sharper tools in the shedOregon TRD is one of the sharper tools in the shedOregon TRD is one of the sharper tools in the shed
Oregon TRD's Avatar
Oregon TRD's Tacoma Gallery
SUCCESS!!!!
Got under dash, unplugged white plug, cut green/red wire, electrician taped off cut ends, plugged back in, NO MORE DTRL'S
Thanks OP
Old 04-01-2014, 01:38 PM   #147
doughboy is one of the sharper tools in the sheddoughboy is one of the sharper tools in the sheddoughboy is one of the sharper tools in the sheddoughboy is one of the sharper tools in the sheddoughboy is one of the sharper tools in the sheddoughboy is one of the sharper tools in the sheddoughboy is one of the sharper tools in the sheddoughboy is one of the sharper tools in the sheddoughboy is one of the sharper tools in the sheddoughboy is one of the sharper tools in the sheddoughboy is one of the sharper tools in the shed
doughboy's Tacoma Gallery
Originally Posted by toyoda View Post
Sorry for the confusion. I was trying to say I took out my electric test light and crawled underneath the dash, found the harness, etc. and that's where I got confused.
The reason I was confused is that the green/red wire, the one you said to cut, never had any electricity going to it so I didn't see what snipping it would accomplish. the wire next to it, being black/red, DID have electricity. when the lights were on it didn't, when they were off (and therefore the DTRL were on) it did have electricity. It also had electricity going to it (and flashing) when the blinkers were on. I knew I'd found the wire going to the DTRL/blinkers, but I also kew if I cut it I'd be cutting that light off completely and wouldn't have my turn signal.
I too want to know what the drl line exactly does. I realize this is not an engineering forum so I don't expect people to question how things work and just simply accept things as is. But I'm sure there are quite a few other curious minds out there.
I need to borrow a 12 pin flasher to reverse engineer this.
see my other thread
http://www.tacomaworld.com/forum/tec...-ecu-work.html
I took your test one step further and used an oscilloscope. I only get really low voltage readings (I think these are just noise) when I examine the drl line.
this is with headlights off
this is with headlights on
the voltage level is less than 0.5v, so I can't say for sure these are actual signals and not just noise.
Old 04-02-2014, 02:46 AM   #148
Can't re-MEMBER
ZEROPILOT is one of the sharper tools in the shedZEROPILOT is one of the sharper tools in the shedZEROPILOT is one of the sharper tools in the shedZEROPILOT is one of the sharper tools in the shedZEROPILOT is one of the sharper tools in the shedZEROPILOT is one of the sharper tools in the shedZEROPILOT is one of the sharper tools in the shedZEROPILOT is one of the sharper tools in the shedZEROPILOT is one of the sharper tools in the shedZEROPILOT is one of the sharper tools in the shedZEROPILOT is one of the sharper tools in the shed
ZEROPILOT's Avatar
ZEROPILOT's Tacoma Gallery
Originally Posted by RAPR View Post
SUCCESS!!!!
Thanks OP
+1 The end of a nightmare.
Old 04-07-2014, 07:53 PM   #149
I figured out the answer to how the drl line works.
http://www.tacomaworld.com/forum/tec...ml#post8480845
Old 04-23-2014, 05:04 PM   #150
sayboo4 is on a distinguished road
Marines:
sayboo4's Tacoma Gallery
Works like a charm! Thanks for the write up!
Old 04-26-2014, 04:14 PM   #151
Dental Floss Tycoon
Bagman is one of the sharper tools in the shedBagman is one of the sharper tools in the shedBagman is one of the sharper tools in the shedBagman is one of the sharper tools in the shedBagman is one of the sharper tools in the shedBagman is one of the sharper tools in the shedBagman is one of the sharper tools in the shedBagman is one of the sharper tools in the shedBagman is one of the sharper tools in the shedBagman is one of the sharper tools in the shedBagman is one of the sharper tools in the shed
Bagman's Avatar
Bagman's Tacoma Gallery
I HATE the DTRL's so I was pumped to find this thread. Total newb when it comes to wiring so I have a question...
After removing the coin tray I see that one of the harness plugs has a green/red striped wire, shown in my pic below. After re-reading the 1st page of this thread and see the pic, it says the wire is found in a plug on the BACK of the fuse block. The wire I found is in a front plug....please someone let me know if what I have is the correct wire or not before I cut...thx
Old 04-26-2014, 04:19 PM   #152
SpruceTaco is one of the sharper tools in the shedSpruceTaco is one of the sharper tools in the shedSpruceTaco is one of the sharper tools in the shedSpruceTaco is one of the sharper tools in the shedSpruceTaco is one of the sharper tools in the shedSpruceTaco is one of the sharper tools in the shedSpruceTaco is one of the sharper tools in the shedSpruceTaco is one of the sharper tools in the shedSpruceTaco is one of the sharper tools in the shedSpruceTaco is one of the sharper tools in the shedSpruceTaco is one of the sharper tools in the shed
SpruceTaco's Avatar
SpruceTaco's Tacoma Gallery
The wire is on the back side of the fuse block. IIRC looking at it from the rear it's on the top right, I laid on my back & looked up at the backside.
Old 04-26-2014, 07:23 PM   #153
Rand Paul 2016
Chad is one of the sharper tools in the shedChad is one of the sharper tools in the shedChad is one of the sharper tools in the shedChad is one of the sharper tools in the shedChad is one of the sharper tools in the shedChad is one of the sharper tools in the shedChad is one of the sharper tools in the shedChad is one of the sharper tools in the shedChad is one of the sharper tools in the shedChad is one of the sharper tools in the shedChad is one of the sharper tools in the shed
Chad's Avatar
Chad's Tacoma Gallery
In my 09, that wire was apart of a harness with 3 different plugs on it. I just unplugged all those and took the harness to my kitchen table and made everything a whole lot easier.
Old 04-26-2014, 07:54 PM   #154
Dental Floss Tycoon
Bagman's Avatar
Thanks guys...I knew what I found was too easy I'll see if I can pull the one from the backside. I just want to cut the darn thing to be rid of them.
Update - I am way too fat and my head is way too big to get my ass anywhere near seeing the back of that fuse panel........
2nd update....finally was able to contort myself enough to get to the wire and give it a clip. I just wanted them gone so I just taped them off - no switch for me.
Thanks OP for the info.
Old 07-14-2014, 02:30 PM   #156
rather be dubbin'
vr6pilot will become famous soon enoughvr6pilot will become famous soon enough
Army: retired Apache driver
vr6pilot's Tacoma Gallery
I read the DIY one time and understood it perfectly.
Old 08-06-2014, 06:50 PM   #157
PhD, DVM, MPH, MS, MMA, Esq, XYZ, 123, blahblah
DrFunker is one of the sharper tools in the shedDrFunker is one of the sharper tools in the shedDrFunker is one of the sharper tools in the shedDrFunker is one of the sharper tools in the shedDrFunker is one of the sharper tools in the shedDrFunker is one of the sharper tools in the shedDrFunker is one of the sharper tools in the shedDrFunker is one of the sharper tools in the shedDrFunker is one of the sharper tools in the shedDrFunker is one of the sharper tools in the shedDrFunker is one of the sharper tools in the shed
DrFunker's Avatar
Name: Dr. (I just play one on TV)
DrFunker's Tacoma Gallery
Hi Crom,
Thanks for the write up on this. I am going to get going on this mod soon.
I have a couple of questions before I start dismantling my dash and snipping wires.
I have the DRL set up along with a oznium rocker switch that I am going to splice in before plugging it in.
Once I get this done, I am planning to switch out the bulbs with some of Jumpers LEDs (switchback specifically) so I don't get the melting lens mod.
- Will the on/off switch affect anything with the switchback LEDs, that you know of? I will ask Jumper too, if you don't.
- What gauge wire would I use to splice the switch in?
- Where would one find the Molex type connector that you used, if one does not have resources in their shop?
- Do you think a place like RadioShack have this stuff?
This is my first real electrical system mod to the truck, so I am trying not to fahk anything up and I really trust and respect your work.
Thanks for the help.
Old 08-06-2014, 10:26 PM   #158
Crom [OP] Crom is online now
Must go to Mountains, Desert
Crom is one of the sharper tools in the shedCrom is one of the sharper tools in the shedCrom is one of the sharper tools in the shedCrom is one of the sharper tools in the shedCrom is one of the sharper tools in the shedCrom is one of the sharper tools in the shedCrom is one of the sharper tools in the shedCrom is one of the sharper tools in the shedCrom is one of the sharper tools in the shedCrom is one of the sharper tools in the shedCrom is one of the sharper tools in the shed
Crom's Avatar
Crom's Tacoma Gallery
Originally Posted by DrFunker View Post
Hi Crom,
No. Should not affect anything. I spliced LED's into my turn signal circuit 5 years ago. Work great to this day.
22- 26 AWG is a good guess, it's whatever gauge Toyota is using in the wiring block.
Search amazon for "2-pin connector" you'll see plenty of options. Light weight connectors are good for this project. I harvested mine from an old computer fan.
You're very welcome. I think you'll do just fine. Glad to make a positive contribution to the TW community.
Old 08-07-2014, 12:40 PM   #159
Boomtacoma01 is one of the sharper tools in the shedBoomtacoma01 is one of the sharper tools in the shedBoomtacoma01 is one of the sharper tools in the shedBoomtacoma01 is one of the sharper tools in the shedBoomtacoma01 is one of the sharper tools in the shedBoomtacoma01 is one of the sharper tools in the shedBoomtacoma01 is one of the sharper tools in the shedBoomtacoma01 is one of the sharper tools in the shedBoomtacoma01 is one of the sharper tools in the shedBoomtacoma01 is one of the sharper tools in the shedBoomtacoma01 is one of the sharper tools in the shed
Boomtacoma01's Avatar
Boomtacoma01's Tacoma Gallery
Did mine this past weekend. With I would have done it years ago. I wouldnt be on my 3rd set of headlights. At least I have some new ones coming in at the dealership for free.
Thanks to all of the previous posters. The mod was quick and simple. I put the rocker up by the fog light switch and tapped into an unused fuse on the block to power the LED in the switch.
DTRL toggle switch Crom Technical Chat 8 03-13-2014 11:31 PM
Fog Switch - 3 contact toggle switch to 4 wire Toyota female plug SirGeoff 2nd Gen. Tacomas 14 11-01-2011 06:10 AM
toggle switch for aux lights dayNnite4 Lighting 4 09-05-2011 07:46 AM
DTRL Stealth Mod BlueSteel Lighting 0 08-24-2011 03:12 PM
Toggle Switch socko3161 2nd Gen. Tacomas 3 08-15-2007 05:43 AM
