-   -   05+ Climate control back light and face color change (http://www.tacomaworld.com/forum/lighting/137463-05-climate-control-back-light-face-color-change.html)
Jones 02-01-2011 08:26 PM
HOW TO :05+ Climate control back light and face color change
2005 to 2011 Climate control back light and face color change to black
http://www.tacomaworld.com/gallery/d...m/DSCN4140.JPG
Stock dials
05 to 08 models
http://www.tacomaworld.com/gallery/d...ax_AC_text.jpg
09 to 11 with the Max A/C text – looks the same on the inside as the 05-08 one. This one has 9 blue rectangles and Max A/C text instead of a 10th blue rectangle. Under the Max A/C it is painted black to not let light in.
http://www.tacomaworld.com/gallery/d...e_controls.jpg
Parts and Equipment list
Climate control dials
masking tape
White spray paint
Black spray paint
Clear Matte or Flat spray paint
Blue spray paint
Red spray paint
Adhesive inkjet vinyl sheets for the decals
Hair dryer
Exact-o knife or razor blades
See here for taking it apart: http://www.tacomaworld.com/forum/lig...mbly-pics.html There are 7 screws to take out.
The silver and amber layers are a plastic type overlay that will just peel right off after the silver edges are detached from the black control dial body.
Warning the silver dials are easily broken, if you plan to save them, take your time removing them.
Make a cut around the silver and black area to separate the two.
http://www.tacomaworld.com/gallery/d...f_DSCN3025.jpg
See this post for removable of the silver layer:
http://www.tacomaworld.com/forum/lig...ml#post2701163
Paint used:
http://www.tacomaworld.com/gallery/d...ium/PAINT4.JPG
Print out temporary labels to cut out for painting the outlines. Painting template for decal.psd
Use a razor blade or exact-o to cut the outlines out. Scissors will work for everything except the blue and red area, the outline will be needed for painting.
http://www.tacomaworld.com/gallery/d...decal_copy.jpg
Before putting the blue dial label on to keep it from being painted, scrap of the black paint around the area where the max a/c text will be.
Tape off all areas that do not need to be white:
http://www.tacomaworld.com/gallery/d...whitepaint.JPG
White paint layer for the icons
After the white paint is completely dry, apply the icon cut outs over the white paint. Line up the shapes with the outlines under the white paint by shining light through the dials. Do not remove the labels for the red and blue areas.
http://www.tacomaworld.com/gallery/d...blackpaint.JPG
Black paint
Red dial paint
Peel off the label hiding the red dial’s area then use the dial outline to mask the black paint. Cover all other areas.
http://www.tacomaworld.com/gallery/d.../Red_dial1.JPG
Blue paint
http://www.tacomaworld.com/gallery/d...blue_paint.JPG
Painting finished, Peel off all the labels covering up the white areas.
http://www.tacomaworld.com/gallery/d..._finished1.JPG
Ready for the vinyl:
http://www.tacomaworld.com/gallery/d...t_finished.JPG
Vinyl print out
Inkjet Clear Glossy Vinyl
http://www.texascraft.com/hps/home.php?cat=253
Printer use: Cannon MG6120
Files for printing in both Photoshop and in jpeg format.
NO Max A/C on the dial: PSD file, JPEG file
WITH Max A/C on the dial: PSD file, JPEG file
www.gimp.org is an open source program that is free that supports Photoshop files.
Print out a test page to plain paper to make sure the scaling is correct before printing on the vinyl.
http://www.tacomaworld.com/gallery/d...m/printing.JPG
After printing before installation:
The instructions from Papilo/Texascaft were to use a laminate aerosol, I use good old matte clear spray paint, to seal it up and take the gloss out. The spray didn’t stop the vinyl from stretching when heated up.
http://www.tacomaworld.com/gallery/d...lear_paint.JPG
Installing the new dial decals:
Trim the clear vinyl out to make the dial’s shape. These will be larger than the dials themselves but you need it to cover the edges.
Putting the decal on the dials:
  • Pill away the backing to the adhesive decal.
  • Hold the dials up to the light to align the icon’s background and the decal.
  • Use the hair drier to form the vinyl to the front of the dials, taking out the wrinkles and any bubbles,
  • After the front is installed:
    • Heat the vinyl up as you do this part.
    • On the inside part of the dial, make small cuts in the vinyl but not where you will see it after the knobs are on. This is so you can stick the vinyl to the inside of the dials, were the knobs will go.
    • Now stretch the vinyl around the outside edges. Smooth it out as much as possible by stretching the vinyl out and getting it to stick the outside of the dial.
  • I put a rubber band around the dials to keep pressure on the vinyl, while it cooled down and the adhesive set in.
http://www.tacomaworld.com/gallery/d..._installed.JPG
I also sprayed matte clear spray paint afterwards to give it a finished smooth look.
A/C and Air recirculation button
I followed m3zy6 write up for changing the button’s color. Thank you for posting it.
http://www.tacomaworld.com/forum/lig...t-mod-how.html
I added in the black vinyl to fit into the theme of all black and white.
http://www.tacomaworld.com/gallery/d...m/DSCN3672.JPG
Light for the dials
http://www.oznium.com/corvette-c5-led 2 of these to go in place of the stock ones. They are powered with a (+) and (-) side, if they do not light up when first put in, back out and rotate 180 degrees and put back in
The twists LED are a close fit, not exact but close enough to stay in. They can be made out of the current twist bulb with a 5mm LED and a 470ohm resistor.
http://www.tacomaworld.com/gallery/d...m/DSCN3731.JPG
Since the LED's are 120 viewing angle, that doesn’t exactly cover all the little light tunnels to get to all the icons. I added in aluminum foil to reflect the light right. Before it is basically pointing straight forward and not towards the light tunnels.
http://www.tacomaworld.com/gallery/d...ht_tunnels.jpg
Selector knobs- replacing the amber inserts
The hard way: Take EasyMold and make molds of the amber inserts, then make casts with EasyCast clear epoxy. Then lightly spray paint the outside with white paint
http://www.tacomaworld.com/gallery/d...nob_insert.JPG
The easy way:
Clear hot glue works to replace the amber inserts. Tape off the front side to get a smooth finish, and add the hot glue in from the back side. Try to get the least amount of hot glue in there to keep light being cut down.
Front side triangles
Add a little white spray paint dabbed on the outside to show up during the daytime
http://www.tacomaworld.com/gallery/d...dium/knobs.jpg
Finished product
http://www.tacomaworld.com/gallery/d.../DSCN38551.JPG
http://www.tacomaworld.com/gallery/d...k_AC_dials.JPG
Cape Codder 02-05-2011 06:39 PM
WOW
Nice Job
Thanks for the Write-Up
Jones 02-06-2011 02:32 PM
Write up for Silver stock dials backlight color change
Changing the A/C dials from being back-lite with amber to white isn't impossible.
Start with disassembling everything.
Then where the silver outer cover needs to be separated from black body of the dials.
Cut around the outside and inside where the silver meets the black plastic.
The inside can be trimmed out a little bit to help with the next step.
http://www.tacomaworld.com/gallery/d...m/DSCN3114.JPG
The silver outer cover is glued to the black plastic, and will need to be worked apart with something thin and strong. I used an end of a zip-tie. Do this on top and on the sides where the silver is. Do not stretch the silver to much or it will tear or stay deformed.
http://www.tacomaworld.com/gallery/d...m/DSCN3115.JPG
All done removing the silver outer covers of the dials.
http://www.tacomaworld.com/gallery/d...m/DSCN3118.JPG
Scrap the amber paint off the silver layer from the backside. Try to use a wide blade to not leave little scratches in the clear plastic.
http://www.tacomaworld.com/gallery/d...m/DSCN3117.JPG
Lightly paint the backside in a thin layer of white paint. This is mainly for contrast on the front side with the silver and to make it look like the radio's buttons.
http://www.tacomaworld.com/gallery/d..._-_writeup.JPG
The A/C and recirculation buttons, take acetone/nail polish remover and a q-tip to dissolve and clean off the amber paint.
http://www.tacomaworld.com/gallery/d...m/DSCN3119.JPG
Add in LED lights, I recommend these from Oznium Link
To get the light to shin evenly, I added tin foil for the lights to reflect to the light frame inside the dials. The foil needs to attach to the plastic dials then put the clear plastic light tunnels in before reassembling the electronics and backing together.
Reassembly
http://www.tacomaworld.com/gallery/d...m/DSCN3138.JPG
http://www.tacomaworld.com/gallery/d...m/DSCN3145.JPG
jdkeller 02-06-2011 02:37 PM
Wow. Nice job. That's a lot of work!
BenWA 02-07-2011 03:57 PM
Man, that looks like a pain in the @ss. But looks to be worth the trouble because the end result looks killer!
Did you do anything to mod the lighting of your gauges too?
The stock amber panel lighting is one thing I've never been a fan of with Tacos in general -- there's something cheap looking about it.
Viet2100 02-07-2011 05:35 PM
A lot of work just to have VDub interior... looks cool, though.
achirdo 02-07-2011 05:44 PM
Subbed
Jones 02-07-2011 05:56 PM
I changed everything. Gauges, auto on the window switch, steering wheel controls, radio, and the clock( picked up an 09+ with LEDs on ebay).
BenWA 02-10-2011 11:11 PM
Good call on the VW look -- I was just thinking that it looks like the lighting in my buddy's Jetta.
Do you have pix of the gauges?
Jones 03-05-2011 08:18 AM
Sorry I missed this, I would have replied sooner but I over looked it.
Here ya go.
http://www.tacomaworld.com/gallery/d...m/DSCN2202.jpg
Anyone giving this a shot out there?
Cape Codder 03-05-2011 09:56 AM
Beautiful Job !
Only thing keepin' me from doin' it is Time, Ability, and Fear :ballchain:
CC
esizzle777 03-07-2011 07:25 PM
IF you're ever in laredo hit me up id love to get this done
s10nick 03-07-2011 07:36 PM
damn thats alot of work but job well done i want to do it but thats alot of work to change it so ima leave it be
10.21 06-12-2011 02:46 PM
Jones, do you have a write or link to the light changes? I've seen dash but nothing for the digital clock, radio, etc...would much appreciate it.
Jones 06-12-2011 04:17 PM
I have some links saved over time.
Digital clock for 2009+, not really a write up but it shows the pieces. It is very similar to the LCD on the odometer.
http://www.tacomaworld.com/forum/lig...backlight.html
and the air bag, seat belt
http://www.tacomaworld.com/forum/lig...ml#post2036191
Stock head unit from an 05 to 09 radio, it is close to the same as the 10+ radio with a few more LEDs.
http://www.toyotanation.com/forum/t184748.html
Steering wheel controls
http://www.toyotanation.com/forum/sh...ing+wheel+leds
deerslayer75 07-26-2011 02:37 PM
Digital clock for 2010+, not really a write up but it shows the pieces. It is very similar to the LCD on the odometer.
How difficult would it be to just change color of the lights in the HVAC? I wanted to go blue but was told it can't be done because the amber paper is sandwiched in there. would I have to go through all of those steps just to change the color or would it be a lot simpler than I was told?
Jones 07-26-2011 06:02 PM
No other simpler way that I can image. The amber layer is to close to the top or outside of the dials, taking the amber layer out from the backside is not possible. The amber layer is directly under the silver paint and it doesn't take much sanding to get to it. Luckily the amber layer is not all the way through the dials and can be taken off.
Keeping the silver color of the dials should be possible, you just have to print the black parts in silver and then leave the white spray paint step out. Maybe a light coat of the VHT night shade for tail light tinting could be used to create the dark background for the icons and letters but still let the light in when the lights are on.
AsianAnts 08-16-2011 03:58 PM
OP, the link to DL the template no work??
Jones 08-16-2011 04:07 PM
I will fix it as soon I get back to my computer
