How can I change which lights are DTRL's?
Discussion in 'Lighting' started by chris duby, Apr 12, 2011.
  1. Apr 12, 2011 at 9:44 AM
    chris duby
    chris duby [OP] This is where I write something clever
    Lake Jackson, TX
    2020 TRD OR Premium
    6" Lift, 22x12 Xtreme Force XF8 wheels, 33x12.50 Nitto Trail Grapplers...
    I had just purchased and installed a set of halo projector headlights with HID's. My 09 Tacoma came with DTRL's (Daytime Running Lights) stock and now, with the new headlights, I don't like the look of it durring daylight hours.
    I have been doing a little research and found that the green wire running the my DTRL's is the "jumper wire". If I cut this wire will my blinkers still work? And can I re-route it to some LED's that came in the headlight housing to have them work as my DTRL's?
    Here is a picture explaining what I'm talking about.
  2. Apr 12, 2011 at 9:55 AM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    blinkers will not work if you cut that green wire..i'm still thinking about how you could make it work..you can re-route the hot wire to the LEDs, but then they'd be your blinkers and that would be ridiculous looking
  3. Apr 12, 2011 at 10:01 AM
    CopDoctor
    08 335i
    nevermind yours is probably setup differently than mine..do you have 3 wires going to your current dtrl or 2?
  4. Apr 12, 2011 at 10:04 AM
    chris duby
    Lake Jackson, TX
    2020 TRD OR Premium
    yea, I don't want the LED's to blink and I do want to keep my amber blinkers. But I am at work right now and will look at it a little more when I get home. I'll let you know then.
  5. Apr 12, 2011 at 10:07 AM
    CopDoctor
    08 335i
    i have jerry-rigged dtrl..so originally i had two wires (red and white) going to the blinker and the third green that i added. the green turned the blinker into the dtrl. if you have three wires, i imagine you would just take that out (wouldn't cut it just yet) and re-route to the leds like you first said.
  6. Apr 12, 2011 at 10:34 AM
    chris duby
    Lake Jackson, TX
    2020 TRD OR Premium
    Thanks for the help... What I'm going to try when I get home is using a quicksplice on the 3rd wire (if there is one) and run it to the LED's. I'll let you know if it works.
  7. Apr 12, 2011 at 5:37 PM
    chris duby
    Lake Jackson, TX
    2020 TRD OR Premium
    There is no third wire on my blinkers, only two. I'm just going to have to settle with what I have now. If anyone else has any info please let me know. Thanks.
  8. Apr 18, 2011 at 7:10 AM
    chris duby
    Lake Jackson, TX
    2020 TRD OR Premium
  9. Apr 28, 2011 at 6:13 PM
    Tacokevin
    Tacokevin Well-Known Member
    Kevin
    East Hartford, CT
    Kenwood Excelon DNX9960, Hertz speakers, Extang Trifecta Tonneau, 3" Toytec Bilstien 5100 coilovers, LR UCA, Diff Drop, Rear AAL Bilstien 5100's, XD Series Bully Wheels, 285/74R16 Nitto Terra Grapplers, Yellow fog lights w/ anytime mod to FJ oem switch, DTRL custom mod w/Switchback LED and stealth switch, Smoked Headlights, Wired Streamlight Rechargable LED flashlight, Color matched grill, Color matched power mirrors w/oem switch, Heated Murth Bicolor signal mirrors w/Highlander oem heater switch, URD short shifter
    Did the switchback bulbs work? Or only the amber still?
