recieved the ddm HID's about 20 min ago, but have a question
Discussion in 'Lighting' started by fltacoma, Apr 16, 2011.
  1. Apr 16, 2011 at 8:34 AM
    fltacoma
    fltacoma [OP] Well-Known Member
    daniel
    Shreveport, LA
    no truck as of yet :)
    when I opened the box, the HID's have a shroud around the side of them, what do I do? are they placed there for some reason?
  2. Apr 16, 2011 at 8:36 AM
    rcbs204
    rcbs204 Well-Known Member Vendor
    protection on the bulb for shipping. remove before install
  3. Apr 16, 2011 at 8:43 AM
    delrayrasta
    delrayrasta Well-Known Member
    Paul
    Delray Beach, FL
    2011 4X4 TRD OFF ROAD
    pro comp stage II lift kit, retro projection HID headlight and fog, bullbar, bed cover and afe S dry intake.
    NOOOOO!!!!! if its a metal shield that is only covering half of them then leave it alone!!!!
    i took them off and i makes your headlights uber bright and blind the shit out of people (not the right way) plus it'll make them point in every directions.
    take a picture of it first and show us because if its what i am thinking its the bulbs light shield, you twist it off and put it in first then you slip the bulb in and twist it back in.
  4. Apr 16, 2011 at 8:44 AM
    rcbs204
    Oh, i thought the man was talking about the plastic covers that come over the bulbs for shipping.
  5. Apr 16, 2011 at 9:02 AM
    fltacoma
    daniel
    Shreveport, LA
    its not the plastic shields that they use in shipping, its the metal shields right by the bulb. does anyone know, or can poiint me into wiring these bad boys up?
  6. Apr 16, 2011 at 9:27 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Differential Breather Mod Light Bar: 4 Cree LED lamps Bilstein 5100s Ride Rite Air Bags
    Wow, DDM can't even include an instruction sheet? How about their web site? Any instructions there?
    I went to their store in San Diego once... very underwhelmed with the lack of help offered.
  7. Apr 16, 2011 at 9:35 AM
    fltacoma
    daniel
    Shreveport, LA
    nope, no instructions. they have cables that are plug in, and a set of cables that have bare ends on them. which one do I use? do I use these? (pic attached)
  8. Apr 16, 2011 at 9:36 AM
    fltacoma
    daniel
    Shreveport, LA
    just to rant a little, I already have a set of fogs installed, and they wernt this much of a pain in the ass....
  9. Apr 16, 2011 at 9:37 AM
    delrayrasta
    Paul
    Delray Beach, FL
    yea its exatly what i thought. just twist them off and put the metal shields in the head light house and put the metal clips back on first. wiring is easy. if you have the relay you find a place near the battery and hook that up and connect all the wires (its pretty simple, just keep everything clean and tidy. it'll help in case you need to remove or change them) then slip the bulbs into the shields that are already in the headlight housing and twist them in. and enjoy.
  10. Apr 16, 2011 at 9:39 AM
    delrayrasta
    Paul
    Delray Beach, FL
  11. Apr 16, 2011 at 9:43 AM
    HighRise
    HighRise Active Member
    Fritz
    Portland,Oregon
    10 sport super white
    6 inch Pro comp stage 2
    Ordered the same from ddm, fogs/headlights fogs came with a plastic cover that covers the bulbs, headlights didnt, headlight bulbs look like a metal helmet covering the bulbs, do not remove it, I installed it, pain in the rear to fit had to move battery and winshield res to make em fit.
  12. Apr 16, 2011 at 9:43 AM
    Who Dat Popcorn
    Who Dat Popcorn Dafuq
    Ricky
    Richmond, VA
    Sold :/
    SOLD
    They prevent glare by focusing the light in the top portion of your headlight and not the bottom. This makes the light point down and not blind people as much.
    Wiring is easy, just plug and play.
  13. Apr 16, 2011 at 9:46 AM
    fltacoma
    daniel
    Shreveport, LA
    and I dont have the HI/LO kit, just the regular kit.
  14. Apr 16, 2011 at 9:47 AM
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    San Antonio, TX
    '23 TRD Pro Tundra; 996TT; '16 Odyssey
    #nomods
    You should have a positive and a ground. You may have 2 positives. Hook the pos up to the battery, and ground the ground. You the connecter that plugs into the OEM bulb is what plugs into the DDM plug. You only need one plug from your truck though, the other one just tape up. The small box is the relay for the highs.
  15. Apr 16, 2011 at 9:48 AM
    fltacoma
    daniel
    Shreveport, LA
    hey whippersnapper, which color ones go to which ends of the stock headlight plugs?
  16. Apr 16, 2011 at 9:49 AM
    Who Dat Popcorn
    Ricky
    Richmond, VA
    Sold :/
    SOLD
    This
    I don't know why yours came like that. These are for a taco, right? Mine had the actual switch when I bought them.
  17. Apr 16, 2011 at 9:49 AM
    fltacoma
    daniel
    Shreveport, LA
    ok. blue is positive, and the ground is black. but there are 3 places in which to stick the positive into. which one is that?
  18. Apr 16, 2011 at 9:50 AM
    fltacoma
    daniel
    Shreveport, LA
    I dont see any picture?:confused:
  19. Apr 16, 2011 at 9:54 AM
    Who Dat Popcorn
    Ricky
    Richmond, VA
    Sold :/
    SOLD
    Lol I was agreeing with whipper :p
  20. Apr 16, 2011 at 9:55 AM
    Slimwood Shady
    Linwood
    San Antonio, TX
    #nomods
    There is a plug that plugs into each ballest. The only other plugs i can think of, there is a plug with both male and femail connecters. IIRC it goes from the ballest to the bulb. The plug for the ballest should be a double female plug. Can't remember which way it goes. Just remember you wont hurt anything if it is backwards.
