-   -   Need OEM Fog Light Switch Wiring Diagram (http://www.tacomaworld.com/forum/lighting/156454-need-oem-fog-light-switch-wiring-diagram.html)
TerryS 05-11-2011 03:19 PM
I'm seriously considering swapping the OEM fog light switch for the FJ counterpart. I have the wiring diagram for the FJ switch, but not for the Tacoma switch. Life would be easier if I could find it. I have seen others use the FJ switch for new/add-on lights, but has anyone done a straight switch swap?
OZ-T 05-11-2011 03:48 PM
Interested
TerryS 05-11-2011 06:35 PM
Thanks for your reply. My problem is determining what locations the connecter pins from the Tacoma switch go to on the FJ switch. That's why I was asking for the switch wiring diagram.
I'm not sure which of the 2 FJ switches I'll need. Maybe you or someone else can clarify.
Originally Posted by caribe makaira (Post 3161055)
Your gonna need the FJ connector. You remove Tacoma fog switch, then open the lock on the connector, remove the pins then insert them into the FJ connector. Tacoma is 4 pin connector, FJ is 6 pin connector. FJ has 2 types of fog switch.
http://www.fjcruiserforums.com/forum...diagram-2.html
Tacokevin 05-11-2011 07:27 PM
THE BOTTOM TWO PINS ARE THE SWITCH ILLUMINATION (GREEN AND GREEN WHITE) TERMINAL 3 (BLUE WIRE) TO FOG LAMP RELAY COIL 4 (WHITE-BLACK WIRE) FROM JUNCTION CONNECTOR GROUND GIVE ME A FEW MINUTES ILL TRY AND UPLOAD A DIAGRAM FOR YOU
Tacokevin 05-11-2011 07:32 PM
fog light diagram
1 Attachment(s)
here is the diagram
Tacokevin 05-11-2011 07:38 PM
the the FJ switch have an indicator light?
TerryS 05-11-2011 07:38 PM
Originally Posted by Tacokevin (Post 3162101)
here is the diagram
That's kind of you, Kevin. I can't really understand it too well, but thank you.
TerryS 05-11-2011 07:43 PM
Yes, the FJ fog light switch has an indicator light, looks like all our other switches and fits the holes in the dash. Why Toyota didn't use it in the Tacoma is a mystery.
Tacokevin 05-11-2011 07:48 PM
its connector f16 on the second page.......on the first page see where it says F16 Fog Lamp SW 3 and 4 those are the wires for pin three and four on te stock switch
Tacokevin 05-11-2011 07:53 PM
circled diagram
1 Attachment(s)
circled the wires and the connector
TerryS 05-11-2011 07:55 PM
Thanks, Kevin. I do see that now.
Tacokevin 05-11-2011 07:57 PM
what year fj cruiser did switches come from?
TerryS 05-11-2011 08:05 PM
I really don't know; I've got the part numbers for the fj fog light switch and the similar fj auxiliary light switch. I don't know which to use yet, but am beginning to think that it doesn't matter.
Tacokevin 05-11-2011 08:10 PM
the picture on the aux light switch http://www.trdsparks.com/displaypart...&parts_id=1971
picture on the light bar switch http://www.trdsparks.com/displaypart...&parts_id=2024
Tacokevin 05-11-2011 08:21 PM
i didnt know that these were available....thanks.....im going to get the aux one for my fogs and the light bar one for my DTRL mod i did
TerryS 05-11-2011 08:21 PM
Nice. I hadn't seen the light bar switch before. Let me know how the fog switch turns out. I'm about ready to drop this idea until I can get more definitive information.
Originally Posted by Tacokevin (Post 3162404)
Tacokevin 05-11-2011 08:35 PM
1 Attachment(s)
from what i see here is this diagram either switch they are wired the same....the bottom 1 and 2 are the illumination of the switch when interior lights in truck go on.... 1 would goto green wire 2 to the green-white wire......3 goes to blue wire (to relay) 4 goes to white-black wire (ground).....only difference is that you have to ground terminal 6....terminals 5+6 on the fj switches are to illuminate the indicator light
TerryS 05-11-2011 08:40 PM
Excellent, Kevin. Just what I was asking for. Thanks. I'm going to order the switch and harness tomorrow. I've had enough for one day.
Tacokevin 05-11-2011 08:43 PM
i just ordered them....thanks for bringing them up....let me know how it works out
TerryS 05-11-2011 08:48 PM
You too.
