Stock function of instrument panel lighting
Discussion in 'Lighting' started by Southman, Jun 10, 2011.
  1. Jun 10, 2011 at 12:09 AM
    Southman
    Southman [OP] Member
    Carlsbad, CA
    2005 4X4 TRD O/R
    I searched first to see if this question, has been posted previously, but I don't think it has.
    I have an 05 DC TRD O/R. I notice that the instrument lights are always on whenever the ignition switch is on, even though the truck does not have DRLs. When the parking lights and headlights are on an indicator on the dash that looks kind of like this * comes on. Finally, when the fog lights are on, there does not seem to be any indicator that they are on.
    Is this the correct, or do I appear to have some type of electrical issue, as no vehicle that I have owned has ever:
    1. lit the dashboard with the lights off without DRL
    2. had fog lights on without an indicator light on either the dash or the switch.
  2. Jun 10, 2011 at 1:26 AM
    Highland Logan
    Highland Logan UBIQUE
    Frank
    Nova Scotia, Canada
    2011 Black AC TRD Off Road w/ factory tow pkg
    Icon Stage 2 w/ overload left in, SPC LR UCA, 265/75 16 BFG KO2, front and rear Weathertech floor liners, OEM (Extang) solid fold tonneau, OEM bed mat, OEM front skid plate, OEM billet oil cap, "TOYOYA" tailgate decal
    Just a thought, but I imagine they assumed you would know they were on because you would be using fog lights in foggy low viability conditions. They are fog lights after all.
    Frank
  3. Jun 10, 2011 at 5:01 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Not all double cabs have DTRL, depends on the truck itself (and where in the country you bought it seems to play into it). My double cab does not have them but I have seen a few around here with them. The green indicator lets you know your headlights are on, and the instrument panel lights will dim when you turn them on also.
  4. Jun 10, 2011 at 10:47 AM
    Southman
    Carlsbad, CA
    2005 4X4 TRD O/R
    Thanks for the info, I guess everything is working OK
  5. Jun 10, 2011 at 11:00 AM
    daggertats
    daggertats Well-Known Member
    arden nc
    2010 tacoma 4x4 reg cab
    undercover tonneau ,bug deflector, removal of all tacoma emblems added a set of component speakers behind the rear seat egr in channel window visors
    your dash lights are fine.......i have a 2010 reg cab and mine does it too......i believe toyota did this because of the depth of the gauges. they are hard to see on cloudier days.
