How to turn instrument cluster lights off?
Discussion in 'Lighting' started by JeffreyC, Aug 1, 2011.
  1. Aug 1, 2011 at 7:52 PM
    JeffreyC
    JeffreyC [OP] New Member
    My 2006 Taco's instrument cluster lights are always on even when the headlight switch is off. This causes me to forget to turn the headlights on many times.
    What specific modification do I need to make to to turn the instrument cluster lights off except when headlights or parking lights are on (like most vehicles are)?
    Thanks,
    Jeff
    84runner likes this.
  2. Aug 1, 2011 at 7:54 PM
    ouyin2000
    ouyin2000 Well-Known Member
    Nova Scotia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
    Look for the *headlight on* symbol on the display?
  3. Aug 1, 2011 at 8:04 PM
    theredofshaw
    theredofshaw Well-Known Member
    John
    Somewhere on the East coast
    not a taco (guess that means I can be a MOD now)
    (totaled) 2011 Tacoma DC
    when i open my door after shutting off the engine and removing the key, my headlights turn off on their own=no dead battery.
    you can turn down the brightness on the left of your console on 2nd gens. it is a little wheel knob that you adjust.
  4. Aug 1, 2011 at 8:07 PM
    enjm10
    enjm10 Well-Known Member
    Eric
    NM
    2020 White Double Cab
    5% Front strip and doors, 20% wrapped around the rest of the truck.
    Headlights should turn off w key, mine do I have an 07.
  5. Aug 2, 2011 at 12:30 AM
    JeffreyC
    Thanks for the replies but none of them answered my question.
    This is not a problem with the headlights turning off or a dead battery.
    Maybe I didn't explain my problem clearly enough. When I start my '06 Tacoma and the engine is on, the dash lights are always on, regardless of whether or not I've switched on the headlights or not. I do not have daylight running lights.
    This is problematic to me because in most cars I know if the lights are on or not by noticing if the dash lights are on, specifically when it starts getting darker outside.
    Because of this odd functionality, I am frequently forgetting to turn on the headlights as it gets dark out since the dah lights are already on.
    I know there's this miniature headlight indicator light in one of the gauges, but that's not as obvious.
    My question is technical in nature: What specific electrical modification do I need to make so that the instrument cluster lights go on when I turn the headlights on and off when I turn the headlights off like most vehicles function?
    Thanks, Jeff
  6. Aug 2, 2011 at 12:52 AM
    rossk35
    rossk35 Do Work Son!
    hawaii
    07 TRD Sport Supercharged
    TRD S/C/TRD Intake/TRD Boost Gauge/DT Headers/OEM TL/ZKW retro/Pioneer DVD w/Ipod/Magnaflow/20% Tint/BHLM/JL 10" sub, JL VR components, JL 450/4 amp/Helwig Sway bar/Viper 791/ 18" limited 4runner rims
    You can't. Learn to look at the green indicator, leave the lights always on, or figure out how to turn the knob when it gets dark. If you can't do any of that...idk then
  7. Aug 2, 2011 at 11:40 AM
    ouyin2000
    Nova Scotia
    '11 DCSB TRD Sport
    Not to be rude, but this does sound like operator error. The headlight indicator symbol is green, as compared to the red/orange dash lights. It's kind of obvious as it gets darker to notice if the green light is on or not.
    the only other suggestion I can give is study up on a wiring diagram. You might be able to pick up on something. I have not seen anyone else around here do this, but there are plenty of diagrams around. If you do figure it out, be sure to do a write up!
  8. Aug 2, 2011 at 11:48 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Try searching for a wiring diagram. Someone posted one for our entire truck, if I find it i'll put up a link. I'd imagine it could be done with enough knowledge of the electrical system but would be PITA and require you to tear apart the entire dash. It'd take a relay that would only power the dash lights when the light switch is turned on.
    Like others have said, just leave the lights on all the time, they turn off with the ignition and you'll never have to remember to turn them on again. Problem solved.
  9. Aug 2, 2011 at 11:50 AM
    Who Dat Popcorn
    Who Dat Popcorn Dafuq
    Ricky
    Richmond, VA
    Sold :/
    SOLD
    You guys don't have the dimmer to the left of the steering wheel? :confused: I can turn my dash off completely with my lights on.
    EDIT: Nvm just re-read the question :eek:
  10. Aug 2, 2011 at 11:54 AM
    Pugga
    Massachusetts
    Or pay attention to the radio and A/C controls. They aren't lit up until you turn the lights on, only the clock is.
  11. Aug 2, 2011 at 12:04 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    LED Headlights, Volant CAI, 32" Duratracs
    Glow-in-the-dark gauges is the way things are moving in the automotive world. It isn't unique to the Taco. The green light indicator is there for a reason.
  12. Aug 2, 2011 at 12:48 PM
    t_e
    t_e Well-Known Member
    Erik
    miami,fl
    My 06 is the same way. its quite annoying. The cluster is lit all the time regardless if you have the headlights on or off. Only way to turn it off is by turning the dimmer all the way down.
  13. Aug 2, 2011 at 12:52 PM
    ouyin2000
    Nova Scotia
    '11 DCSB TRD Sport
    Actually, you'd be surprised how many cars up here in Canada run at night with just their DTRLs on. The orange ones on the taco are bright enough that I can see how they get confused for proper headlights (other than the orange versus white...haha). The worst ones for this are the Chevy/GMC trucks that use small white "headlights" as their DTRLs.
  14. Aug 2, 2011 at 1:21 PM
    Pugga
    Massachusetts
    I was guilty of it when I first got my Tacoma. My old Chevy had the sensor and automatically turned my lights on for me when it got dark. I had to get used to turning on my own lights again :D
