Help with HID Kit
Discussion in 'Lighting' started by MudontheTires, Oct 29, 2008.
  1. Oct 29, 2008 at 3:44 PM
    MudontheTires
    MudontheTires [OP] Texan
    Texas
    2008 V6 PreRunner SR5
    Leather Seats, TRD Bilstein Shocks, 6000k Bi-xenon Hid Kit, Toyota Bed Mat, Suspension TSB, TRD Accessory Skid Plate
    I recently bought a xentec h4 bi-xenon HID kit. After the install only the driver side headlight works. The kit only has the 3 prong connector that hooks up with the factory harness on the driver side. It doesn't have the 3 prong connector on the passanger side. Is this the problem? or is it supposed to be bypassed someway. Please help!!
  2. Oct 29, 2008 at 3:45 PM
    TacoCo
    TacoCo Aspiring wrench monkey
    Colorado
    09 TRD Off-Road DC V6 Magnetic Gray
    Snugtop XV Shell, Yakima Rack, AFE Pro Dry Filter, Secondary Air Filter Removed, Michelin AT2's, Partially Debadged, HID conversion, Dynomax Super Turbo Muffler, Rear leaf spring TSB, Foglights always on Mod, URD Short Throw Shifter, Toytec Coilovers on the way!
    Welcome to TW. You should only have the 3 prong adapter on one side. Make sure everything is properly grounded.
  3. Oct 29, 2008 at 3:47 PM
    MudontheTires
    Texas
    Thanks for the quick reply!! so it's normal for the factory harness on the passanger harness to just be detached?
  4. Oct 29, 2008 at 3:48 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Yeah...Check you grounds and than check your fuses and the bulbs.
    If the ground was bad you might have blown out a fuse or a bulb.
  5. Oct 29, 2008 at 4:17 PM
    MudontheTires
    Texas
    well it seems like everything is connected how it should be but still only the drivers side headlight is working
  6. Oct 29, 2008 at 4:21 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Swap the bulbs...Make sure you have a good light??
  7. Oct 29, 2008 at 4:22 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    did you touch the bulb itself? ive heard that the oils on your skin can cause the bulbs to blow..?
  8. Oct 29, 2008 at 4:29 PM
    808trdsport
    808trdsport Well-Known Member
    Honolulu
    08 Tacoma TRD Sport Prerunner
    6000k HIDS, double tint in the back and tint front side windows, CGS cat back exhaust, AFE Pro Dry filter
    do you have a relay harness? you may need one, because you don't have enough juice for one of the ballast to ignite.
  9. Oct 29, 2008 at 4:44 PM
    MudontheTires
    Texas
    No the bulbs look fine.
    What is this relay harness you speak of? that sounds like it may be the problem
  10. Oct 29, 2008 at 5:20 PM
    TacoCo
    Colorado
    It should have come in the box with the ballasts... If you have a bixenon kit, there should be 2 ballasts, 2 bulbs, and a wiring harness that you connect between the two ballasts and the battery.
  11. Oct 29, 2008 at 5:27 PM
    Tail Gunner
    Tail Gunner Well-Known Member
    Kitsap, Washington
    2005 PreRunner SR5 TRD
    Aries black Bull Bar, K&N 63-series Air Intake, HID 6000K Headlights and Fogs, Redline Hood Struts, Kenwood DPX-502 headunit, JDM black headlights, black Altezza tailights, Bracketronic I-pod mount, and several more audio mods to come Debadged
    Maybe revese the 2 pin plug going into the ballast you might have it in backwards, that is what happened to me on my install.
  12. Oct 29, 2008 at 11:35 PM
    MudontheTires
    Texas
    I'm not sure if that's possible since it kinda has notches to prevent that? but anyways i'm thinking it may be the bulb. i'm going to try and reverse em tomorrow to see if the bulb works on the other side. If not, does anyone know a good place to get a good price replacement bi-xenon bulb?
  13. Oct 29, 2008 at 11:39 PM
    MudontheTires
    Texas
    ohh btw. has anyone heard of putting a bigger fuse in the headlight slot in the fuse box? one of my buddies who has hids said he did this because he wasn't getting enough power to one of his ballasts. i don't know if i believe him :crazy:
  14. Oct 29, 2008 at 11:39 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    If this was purchased from Slim on the group buy contact him. Sorry if out of place I didn't read all the previous post. I don't think switching the sides would help unless your harness is faulty. Definately worth a shot.
  15. Oct 29, 2008 at 11:40 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    I don't think that would happen on be the correct fix for his problem. Just my opinion.
  16. Oct 29, 2008 at 11:59 PM
    MudontheTires
    Texas
    nah brother it wasn't from that group buy. i shot the seller an email though. It was an ebay buy that looked legit so hopefully seller will get back to me quick. I would hate to have spent 140 or so bucks for nothin. I'm fixin' to just switch back to halogens cause i'm so fed up with this kit
  17. Oct 30, 2008 at 1:24 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    If you send them back -- check out Slimcubby's group buy... they're cheaper than 140.
  18. Oct 30, 2008 at 7:11 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    I bought my Hids from slim High/low and fogs for about 208 shipped to my house and I haven't had a problem yet, easy install less than an hour I ran the wires under the shroud.
  19. Oct 30, 2008 at 9:28 AM
    P. Bauer
    P. Bauer Well-Known Member
    San Jose
    08 Tacoma 4x4 TRD Off-Road
    TRD S/C :: Intake Camburg SwayAway Magnaflow American Racing Donahoe Racing Wheelers OffRoad
    I bet it's a grounding issue. Make sure to clean the contacts and if you connecting it to a bolt on the body, scrape the paint a bit or wire-brush the threads on the body/fender, etc.
  20. Oct 30, 2008 at 4:32 PM
    MudontheTires
    Texas
    it seems like a pretty legit grounding point. Would it be alright to ground the negative straight to battery?
