Hella 700 Strobe Lights
Discussion in 'Lighting' started by JTacoma, Sep 16, 2011.
  1. Sep 16, 2011 at 9:56 AM
    JTacoma
    JTacoma [OP] Well-Known Member
    Washington
    1995.5 2.7 4X4 5 speed
    Icon Stage 2 Coilovers, Camburg UCAs, 33x12.50x15 Dick Cepek Trail Country EXP on American Racing AR201 15x10 wheels, differential drop, carrier bearing drop, BPV bracket, Leer canopy with Rhino Racks
    I just got my Hella 700s and mounted them on the light bar I made and went out to test them. They shook so much it looked like I had strobe lights on the front of my truck. The lights are mounted as solid as I can get them and the bar feels solid. When I push on the light bar the bumper moves a little. All of the bolts on the light bar and bumper are as tight as I can get them. Anyone else have this problem? Is it the brackets on the lights themselves? Let me know if you have any ideas. Thanks
  2. Sep 16, 2011 at 10:01 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    bumpy road? Any pics of the light bar, it might not be as solid as you think. How's the truck ride in general, do your headlights seem to 'bounce' like the aftermarket lights do? If the headlights aren't bouncing then it could be something inside the light body itself rattling around, maybe the bulb isn't secured well. Just throwing a few ideas out there for you to think about :notsure:
    Nice title by the way, I thought you retrofitted Hella 700's for something like an emergency vehicle or something!
  3. Sep 16, 2011 at 10:23 AM
    JTacoma
    Washington
    A few pics. They aren't very good.
    I bolted the bracket to the bottom of the bumper and to the bar behind and welded the bar to the brackets.
  4. Sep 16, 2011 at 10:28 AM
    memario1214
    Colton
    Missoula, MT
    Mine wobble on my light bar too... Looking into solutions. I need more support somewhere, but I haven't found where yet.
  5. Sep 16, 2011 at 10:37 AM
    iroc409
    iroc409 Well-Known Member
    Washington
    A red one
    If the lights are mounted properly to the bar and you're getting vibration, either the lights themselves don't have a good mount or your light bar is not rigid enough.
    I had a N-Fab on my 2009 with Lightforce 240's and had almost no vibration from them at all, unless I was hitting washboard roads or something.
  6. Sep 16, 2011 at 10:42 AM
    Pugga
    Massachusetts
    You'll get a little spring from the bumper to the light bar because it's flat stock instead of something with a bend like angle iron but it shouldn't be that excessive I wouldn't think. Based on Memario's comment, it sounds like it's an issue with the Hella's themselves.
  7. Sep 16, 2011 at 10:46 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    Damnit, what a missleading thread name! I had 4 of the hellas 500s and they would shake pretty bad on washboard roads.
    Now go convert them into actual strobes!
  8. Sep 16, 2011 at 10:50 AM
    memario1214
    Colton
    Missoula, MT
    So are we saying that I neeto come up with a better mountig system for the hellas? That could be arranged...
  9. Sep 16, 2011 at 11:34 AM
    JTacoma
    Washington
    I bought some star washers and put them on each side between the bracket and the light. The lights also tipped forward a little while driving and I think the washers will help that.
  10. Sep 16, 2011 at 11:55 AM
    memario1214
    Colton
    Missoula, MT
    So let us know if that helps anything
  11. Sep 16, 2011 at 12:04 PM
    JTacoma
    Washington
    Will do. I have to wait until it gets dark.
  12. Sep 16, 2011 at 12:06 PM
    memario1214
    Colton
    Missoula, MT
    I doubt that something like that is solution... But hope to hell that it is
  13. Sep 16, 2011 at 1:51 PM
    JTacoma
    Washington
    Its not so much for the vibration. I was trying to stop the lights from angling down again.
  14. Sep 16, 2011 at 1:59 PM
    Pugga
    Massachusetts
    They shouldn't shift angle on you, sounds like they weren't tight enough to begin with. I've never had Hellas though either, all mine are PIAA :eek:.
