Headlight Keeps Blowing
Discussion in 'Lighting' started by ToyTaco, Oct 4, 2011.
  1. Oct 4, 2011 at 5:33 AM
    ToyTaco
    ToyTaco [OP] For the Retards, Im a Female
    Kristin
    Newark, DE
    '10 TRD Sport 4x4 modified
    I have a 2010 tacoma (i bought new) that in Feb of this year I installed the 1st gen Projector headlights in, since then i have replaced the H1 bulb on the driver side three times and now on my 4th. Any ideas of why it might be blowing? It appears the filament in the bulb is still intact but the bottom of the bulb seems to be burnt in a sense.
  2. Oct 4, 2011 at 5:58 AM
    98tacoma27
    Ben
    Not Beech Creek
    Are you touching the bulb with your fingers when you install it?
  3. Oct 4, 2011 at 6:01 AM
    Hook & Ladder
    Hook & Ladder Well-Known Member
    Maine
    16' TRD Tacoma
    The project @c4_fabrication-Sliders, HC bumper w/ swing out @kb_voodoo_fabrications-Bed rack @tepuitents-RTT @cali_raised_led-Fogs, ditch lights, bed stiffeners @prinsudesign-Roof rack @kingshocks-2.5 with adjuster @totalchaosfabrication-UCA @rcioffroad-diff skid plate Follow at @wicked_overland #nacrew
    are the bulbs at a high rating then what the truck calls for ? That or vibrations may cause power surge this being rare but possible.
  4. Oct 4, 2011 at 6:05 AM
    ToyTaco
    Kristin
    Newark, DE
    nope i use rubber gloves and clean them with rubbing alcohol before installing them every time.
    I know the first set i used was the H1 sylvania (sp?) bulbs and then this time it was a different brand. I believe the general watts for those H1 bulbs are 55. All I know is those headlights call for an H1 bulb i dont know if another type of bulb would fit those?
  5. Oct 4, 2011 at 6:19 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Any water in the headlight housing? Also, does the bulb seat into the housing nice and snug? If not, it could be vibration as someone else mentioned.
  6. Oct 4, 2011 at 6:26 AM
    ToyTaco
    Kristin
    Newark, DE
    ive had them fog up every once in a rare while but its not the whole headlight. I will check out the vibration thing when i go to change the bulb out. Im definitely getting tired of buying 30$+ bulbs every few months
  7. Oct 5, 2011 at 4:39 AM
    ToyTaco
    Kristin
    Newark, DE
    well we did some volt testing on the headlight last night and came to find out it was a blown fuse, which i was kind of surprised since the truck is "newish". Is there any thoughts around that i might need to up the fuse from a 10 to higher to compensate for the lights?
  8. Oct 5, 2011 at 5:18 AM
    98tacoma27
    Ben
    Not Beech Creek
    A 10 amp fuse should be fine for a 55W bulb. It should only use 4.5A.
  9. Oct 6, 2011 at 6:37 AM
    ToyTaco
    Kristin
    Newark, DE
    well i think my bull bar lights might run to the same fuse as my headlights so they might be getting over loaded
  10. Oct 6, 2011 at 6:51 AM
    98tacoma27
    Ben
    Not Beech Creek
    That's a big possibility. What is their wattage? Are they on with the headlights?
  11. Oct 6, 2011 at 6:55 AM
    Pugga
    Massachusetts
    Rewire your bull bar lights correctly. They should not pull power from the headlight circuit. The headlight circuit should only be the jumper to trigger a relay and the lights themselves should have their own fused power.
  12. Oct 7, 2011 at 5:57 AM
    ToyTaco
    Kristin
    Newark, DE
    tell you the truth im not sure I would have to look it up. the bull bar was bought from the dealership after i bought the truck and installed so i didnt research it before hand. They have their own switch to turn on and off, but if they are on and I turn off the headlights they will automatically turned off
    I would have to see how they are wired, i did not do the install myself
  13. Oct 7, 2011 at 6:08 AM
    Pugga
    Massachusetts
    I would check the wiring of them. The lights on the bull bar tap into the headlight circuit somewhere so you'd have to trace some wires. The simpliest method would be to start at the bull bar lights and trace the wires back. The 'hot' wire for the bull bar lights goes directly from the lights to the headlight wire, then that's your problem. They should not be taking power directly from that circuit. The hot wire should go back to a relay instead. Just because the lights turn off with the headlights doesn't necessarily mean they're pulling power from the headlights. Mine do the same thing, just a nice safety feature so you can't kill your battery.
  14. Oct 7, 2011 at 6:50 AM
    ToyTaco
    Kristin
    Newark, DE
    thanks i appreciate that info. didnt have this problem till I stuck those headlights in and started blowing bulbs left and right. They are a pain in my butt that this point.
  15. Oct 11, 2011 at 9:22 AM
    YotaMan2007
    YotaMan2007 Well-Known Member
    Brian
    where my boots and ruck lay
    07 Tacoma 2wd
    K&N Drop-in airfilter, secondary airfilter removed, Satoshi Mod, Kenwood Stereo System, Gibson catback system , Painted Steelies, Offroad Lights, Fatbob's spacer lift
    well i keep having my drivers side headlight bulb blow also, but they are the factory assembly. I put in the Silverstar ultrassince they are bright like HIDs. i had my second one blow last night on my way home through South Carolina. things got really dark.
