No More Foggy Headlamps!!!
Discussion in 'Lighting' started by NelsonTacoma, Oct 14, 2011.
  1. Oct 14, 2011 at 5:40 PM
    NelsonTacoma
    NelsonTacoma [OP] This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    So I had some extra time at work today and after washing & waxing the Tacoma I was staring at my headlamps and was disappointed by the fogginess. So I talked to our paint/body guy and he showed my how to do it. Just got some very fine sand paper and wet sanded the lenses by hand. Then used a power buffer and some buffing compound from Meguiars. Very happy with the results. Took about 10 mins. Been needing to do this for over a year, should have done it sooner.
    Before:
    After:
    My advice on this would be to do the headlamps before the wash. I had to re-wash the front end after I was done with them.
  2. Oct 14, 2011 at 5:50 PM
    stmpjmpr
    stmpjmpr Well-Known Member
    Jimmy
    So Orange County, Ca
    2014 Tacoma Sport MGM 4X4
    nice work. mine still good but will do as you did when I need it.
  3. Oct 14, 2011 at 5:52 PM
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    what grit did you wind up going with. planning on washing tomorrow and this needs to get done on my truck as well
  4. Oct 14, 2011 at 5:54 PM
    w8n4mud
    w8n4mud I'm back.
    Albert
    Chula Vista, CA
    2019 Tacoma Off Road DCSB
    Stock. Purchased 2/17/19. Cement!
    Looks good. I've seen many Tacomas with headlights in need of some TLC. Good call doing it now.
  5. Oct 14, 2011 at 5:54 PM
    NelsonTacoma
    Tucson, AZ
    To be honest I don't know the exact grit. It was VERY soft and smooth. Didn't really feel like sandpaper at all. And you don't have to worry about messing up the body/paint around the lens the sandpaper is way to soft to hurt it.
    Edit: I googled and found this video. Says 1600 or 600. I think it depends on how bad the fogging is.
    http://www.ehow.com/video_2327659_headlight-restoration-600-grit-sandpaper.html
    http://www.ehow.com/video_2327662_headlight-restoration-1600-grit-sandpaper.html
  6. Oct 14, 2011 at 5:55 PM
    707tothe907
    707tothe907 Superior Member
    Jake
    Chico NorCal
    05 DCSB Off Road
    So like a 1500 or 2000 grit?
  7. Oct 14, 2011 at 5:58 PM
    yotamikez
    yotamikez Street glide or die
    Valrico
    04 civic & 08 Street glide
    I need to do this... looks sharp.
  8. Oct 14, 2011 at 5:58 PM
    NelsonTacoma
    Tucson, AZ
    I was just editing my above post. Yeah, 1500 or 2000 should work. Just depends on the severity of the fogginess.
  9. Oct 14, 2011 at 6:00 PM
    NelsonTacoma
    Tucson, AZ
    Thanks guys for the positive feed back. I'm VERY happy with the results. Kind of disappointed with myself for waiting for so long to do it. The headlamps were like this when I bought it last year.
  10. Oct 14, 2011 at 6:05 PM
    scott572011
    scott572011 Well-Known Member
    SCOTT
    SO-CAL.
    THE RELENTLESS PRUIST....
    BF GOODRICH T/A ko, BILSTEIN HDs, AMERICAN RACING RAZOR`S 16X7.5, READYLIFT SST HYBRID LIFT SYSTEMS, ALTEC LANSING AUDIO,DREGS OF THE EARTH SYSTEMS,WOLF EYES,SUREFIRE ILLUMINATION TOOLS,HK-PROTECTION!!. POP LOCK, SHORTY ANTENNA, TACO TENT #3,. NITECORE ILLUMINATION, FENIX FLASHLITES. STILL PROTECTOR`S, FACTORY BED MAT, CUSTOM BED WEB, INTRO-TECH INTRO-GUARD CUSTOM TRUCK COVER, CENTER CONSOLE LOCK MOD, TECH-SHADE M1068, WEATHER-TECH CLEAR-COVER`S, OEM MINI TIE-DOWNS, TRUCK BEDZ AIR MATTRESS EXPEDITION SERIES, McGARD TOUGH NUTS WHEEL LOCK`S, DISABLE SEAT/BELT CHIME MOD, GARMIN GPS, KERSHAW BLADE`S, SKELETOOL, WEATHER-TECH FLOORLINER DIGITAL-FIT GRAY # 461781, NITE(IZE) KNOT-BONE ADJUSTABLE BUNGEE SYSTEM, WET OKole SEAT COVERS, UNDER DASH FLYZEYE BW LED LIGHT W/CUSTOM BLUE HALOS. NITECORE IFE1 INFILUX ILLUMINATION SYSTEM. JETBEAM BC-10 HANDHELD, HK VP-70Z 9mm PROTECTION!. JETBEAM PC-10 550 LUMEN ILLUMINATION SYSTEM. SUREFIRE E2D-LED-DEFENDER ULTRA 500 LUMENS KICK ASS ILLUMINATION...VIPER ALARM SYSTEM`S,ROCKFORD FOSGATE POWER COMPONENT SYSTEM`S.KENWOOD AUDIO/VIDEO,HUSHMAT SOUND DEADENING INSULATION,3M AUTOMOTIVE FILMS.
    could possibility be a wet paper what color was the paper?
  11. Oct 14, 2011 at 6:07 PM
    NelsonTacoma
    Tucson, AZ
    It was a very light green color.
