2012 foglight anytime mod ?
Discussion in 'Lighting' started by Hydrolai, Nov 8, 2011.
  1. Nov 8, 2011 at 5:07 AM
    Hydrolai
    Hydrolai [OP] Well-Known Member
    Johnny
    friendswood
    trd off road 4x4
    Firestick NGP Uniden 520 PROXL BadaBling! 6k Hid Plasti-Dip Wheels/Badges Leds Bed Lights
    does anyone know where the foglight relay is for the 2012 tacomas ? its not in the engine bay where all the other tacomas were. trying to do a foglight mod where i can have them on anytime as long as key is on acc or on.
    Dhannah likes this.
  2. Nov 8, 2011 at 5:14 AM
    redz80
    redz80 Well-Known Member
    Brampton, ON
    Tacoma SR5 TRD 4x4 SWB
    there should be something in the manual about the locations of fuses and relays......maybe under the dash somewhere
  3. Nov 8, 2011 at 5:23 AM
    T@co_Pr3runn3r
    T@co_Pr3runn3r XXXXXXXXXXXXXXXXXXX
    08 RC Prerunner SR5
    If you use add-a-circuit in the tail light fuse for fogs then they work with parking only, with lows or with highs without the need to do any hacking on your oem wiring harness and has same protection of not running the battery down if you try to leave them on.
    Dhannah likes this.
  4. Nov 8, 2011 at 7:01 AM
    munkeeboi
    munkeeboi Well-Known Member
    Burbank
    It's in the small fuse box behind the main fuse box in the engine bay. Let me know if you figure it out. I have someone looking into in the the main "foglights on with parking" thread below
  5. Nov 8, 2011 at 4:05 PM
    Hydrolai
    Johnny
    friendswood
    trd off road 4x4
    Thanks will check it later tonight. Hopefully I can get them done. I want this shit done
  6. Nov 8, 2011 at 4:49 PM
    r6hokie
    r6hokie Well-Known Member
    Virginia
    tint, fog light anytime mod, weathertech visors
    I also want to run foglights during the day with the parking lights, better visibility, let me know if you figure this out or have pics of what to do
    Dhannah likes this.
  7. Nov 15, 2011 at 8:25 PM
    "OLYMPIC VIEW"
    "OLYMPIC VIEW" Well-Known Member
    WHIDBEY ISLAND, WA
    2011 TRD SPORT D/C LB...1987 SR-5 4WD XCAB
    For the 2012 follow instructions in my OP on this thread...
    http://www.tacomaworld.com/forum/lighting/132862-fog-lights-w-parking-low-beam-high-beam.html
    I also made short video expalining fuse/relay box layout on the 2012 Tacoma--just note that I mention Tab # 1 on the FR FOG RELAY is at the top right corner of the relay...THIS IS INCORRECT--Tab # 1 will be the tab on the bottom left corner of the relay--reply back or PM me if you have any questions--OLY
    http://www.youtube.com/watch?v=Yrh9Abjmwag&feature=feedu
    Tx Taco11 likes this.
  8. Nov 15, 2011 at 10:15 PM
    munkeeboi
    Burbank
    [QUOTE="OLYMPIC VIEW";4039140]For the 2012 follow instructions in my OP on this thread...
    http://www.youtube.com/watch?v=Yrh9Abjmwag&feature=feedu[/QUOTE]
    +1 for OLYMPIC VIEW
    Follow this link to go to page 8 for pictures on a 2012. I wired it differently so that the fogs can be turned on anytime the IGN is "ON" like you requested
    http://www.tacomaworld.com/forum/li...parking-low-beam-high-beam-8.html#post4039711
    This mod only allows fogs to be on whenever the key is in. The fogs can be turned on or off on any light setting and turn off automatically when you shit off the car
  9. Nov 16, 2011 at 10:20 AM
    "OLYMPIC VIEW"
    WHIDBEY ISLAND, WA
    I like this version of MB's for the 2012's fog light on with parking/low beam/high beam...
    Reminder that Tab # 1 is at bottom left corner of the FR FOG RELAY--
    See attached thumbnails--OLY
    hankbrob likes this.
  10. Nov 17, 2011 at 10:01 PM
    munkeeboi
    Burbank
    Caribe makaira thought of even a cleaner way to wire it up for 2012 tacos.
    There is no need to run the wire out of the small fuse box where the fog relay is since there are already 2 slots that are wired to ign power. They are the #2 slot (circled in green) and turn on/off with the ignition so you don't drain your battery. Suggested you use an inline fuse (1A will do) for extra protection.
    So instead of running it to the Tail light relay in the large fuse box. just plug it into one of the available slots near the fog relay
    hankbrob, whatstcp, stvhwrd and 3 others like this.
  11. Nov 20, 2011 at 12:19 PM
    r6hokie
    Virginia
    Since this thread is specifically for 2012, I decided to post my response here.
    I have a 2012 dual cab off road package.
    The wiring is a bitch to get between boxes, I will probably drill a pilot hole through the fuse box to go between them but I did the fuse protected mod from fog relay to the trailer hot slot as described previosly I guess it is the number three slot, used 18 gauge wire
    pics below are with fog lights button always on
    First pic light knob rotated off for some reason the drl are not on anymore, looking into this for some reason I thought the drl were on when I got home last night when it was dark
    Second two pics light knob rotated to intermediate position
    Final two pics are light knob rotated all the way and the green indicator shows on my dash
    What I dont like about this mod is that when I turn on the parking lights during the day the stereo display dims
    I may try to do the mod within the small fuse box adding a 5amp fuse and see how that works, more on that later this week
  12. Nov 23, 2011 at 3:15 PM
    RV7Garage
    RV7Garage R.O.U.S.
    Paul
    Ill Annoy
    2012 DCSB Offroad, Nautical Blue
    Disable DRL, Jailbreak Fog Lights, ARE topper
    This mod worked like a charm! I used a fuse harness from Radio Shack, 3A mini blade fuse, and wired it right up. Took maybe 20 minutes, and now I have fogs whenever I want 'm! No holes to drill, no mess of wires- out.fucking.standing!! :D:p. And, the lights turn off when the ignition is off. Now I just gotta figure out how to do away with the DRLs....
    Stryker420 likes this.
  13. Dec 1, 2011 at 5:05 AM
    r6hokie
    Virginia
    I did mine like the previous post all within the small fuse box, I plugged in to the top left green circle as there was no wiring at the bottom right green circle.
    I left my truck for a few hours yesterday and came back and my fog lights had come on even though I had my key in my pocket, so I will be finding another way to do it
  14. Dec 3, 2011 at 9:32 PM
    r6hokie
    Virginia
    I have a v6 dc off road
  15. Dec 11, 2011 at 5:13 AM
    Tacoman12
    Tacoman12 New Member
    NC
    2012 SR5 4X4
    20"x9" Metal Mulisha Generals 6" Zone lift kit
    Does anyone know if the 2012 Tacoma Access cab 4 cylinders have the harness for the fog lights? I know the earlier models of the 2nd generation did. I purchased my 2012 which is a 4x4 and has the SR5 option and the dealer said only the V6 had the option for fog lights. I can't seem to see any harness to add the switch and lights. Thanks
  16. Dec 20, 2011 at 10:28 AM
    Rossi396
    Rossi396 Rossi396
    Tony
    Pittsburgh, PA
    2020 Super White TRD Off Road DCSB
    Can someone verify that the slot shown in the top left green circle will also cause the fogs to come on after engine shut down in a V6 DC O/R...? (See comment below about 4 banger with bench seat)?
    Thanks,
    Rossi
  17. Dec 31, 2011 at 10:51 AM
    SHAKE JONES
    SHAKE JONES Active Member
    Wyatt
    Western NC
    12 DCSB OR
    Listed in order of installation: OEM door sill protectors, 20% tint, Fog Light Mod, 1000w Inverter under driver seat, seat covers, vent shades, Plasti Dip front emblem and chrome grill surround
  18. Jan 13, 2012 at 12:09 AM
    mtnbiker310
    mtnbiker310 Well-Known Member
    Parker, CO
    '12 Offroad Tacoma
    TRD Cat Back Exhaust, Jumpers LED's interior, Hella 5000 behind grill, Custom grille
    im new to toyota and the tacoma, so this is all new to me and may be "dumb questions" but it seems that there really isnt a solid mod for this yet? I basically want to be able to have my fog beams on with my high beams or just run the fog lights only... please help
  19. Jan 13, 2012 at 1:43 PM
    MountainDog
    MountainDog Well-Known Member
    Aurora, CO
    2012 4x4 Double Cab Off Road
    Vinyl floor; 265/75/16 Duratracs; SnugTop Rebel
    subbed...
  20. Jan 26, 2012 at 10:15 AM
    hanrock
    hanrock Well-Known Member
    craig
    sask
    2012 nauticle blue dc lb
    is ther any more news on this mod yet the relay box cover on my 2012 states the lower right relay is for seat heaters which is open on mine has any one tried this one yet with good results all info and comments would be helpfull thanx
