-   -   Fog Harness (http://www.tacomaworld.com/forum/lighting/186978-fog-harness.html)
PEPCATCH11 11-08-2011 10:23 PM
Fog Harness
Looking for opinions on the best quality aftermarket wiring harness for fog light install on base model. I am not pre wired. Thanks!
4Wheelin4Banger 11-10-2011 02:31 AM
You don't need one. I bought the parts and wired mine to the running lights and use them as daytime running lights. Parts you need are in my write-up My Auto OEM Fog Light Mod
PEPCATCH11 11-10-2011 04:12 AM
I don't want to use them as DTRL.
4Wheelin4Banger 11-10-2011 04:21 AM
Then wire a switch to relay post 86. It's easy to do with out a harness. All you need is the plugs for the fogs, a relay, some wire & in you case a switch.
T@co_Pr3runn3r 11-10-2011 04:28 AM
The ebay fogs come with a harness/relay/switch. Ditch the switch and wire in the oem switch. You can use the tail fuse with add-a-circuit and they will work with parking lights only and with lo beams or high beams and the switch will light up properly with the parking/gauge lighting too.
BTW..........you have no pics. We're gonna need pics, that's just how it goes. We be pic ho's :D
wolftree 11-10-2011 04:58 AM
pepcatch11, You can build your own harness by going to "picowiring.com" and getting exactly the terminals and connectors you need. Use your own wire and cut it to the length you need, no splices.
