Fj fog switch with anytime fogs
Discussion in 'Lighting' started by t_e, Dec 8, 2011.
  1. Dec 8, 2011 at 2:44 PM
    t_e
    t_e [OP] Well-Known Member
    Erik
    miami,fl
    Just got an Fj fog switch and wired it up so that the indicator light works anytime with my anytime fog mod.
    Pin1- green
    Pin2- green/white
    Pin3- blue
    Pin4- white/blk
    Pin5- olive green= ignition power taken from unused green connector next to fog switch.
    Pin6- tapped to pin3 blue
    Part Numbers:
    Fj aux switch: pt297-35070-as
    connector: 90980-10933
  2. Dec 8, 2011 at 5:01 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Nice :thumbsup:
  3. Dec 9, 2011 at 12:30 PM
    t_e
    Erik
    miami,fl
    the blue wire is ground to the fog relay.
  4. Jan 2, 2012 at 8:03 PM
    787tester
    787tester Well-Known Member
    Steve
    Everett, wa
    11 double cab trd long bed
    What was the price for the switch and connector. Looks great!
  5. Jan 3, 2012 at 12:40 PM
    t_e
    Erik
    miami,fl
    Switch was $41 for me and the connector is like $4.
  6. Jan 3, 2012 at 12:48 PM
    holyfield19
    holyfield19 GO TIGERS!
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    Busted CV boots and lots of squeaks.
    Sub'd for part numbers. I wanted to get another stock switch for my grille lights. Damn $40 for a switch.......we must be crazy :der:!
  7. Jan 3, 2012 at 12:50 PM
    RV7Garage
    RV7Garage R.O.U.S.
    Paul
    Ill Annoy
    2012 DCSB Offroad, Nautical Blue
    Disable DRL, Jailbreak Fog Lights, ARE topper
    Parts ordered. Awesome. :thumbsup:
  8. Mar 17, 2012 at 6:03 PM
    tubesock
    tubesock Well-Known Member
    Sorry for the necro. Does the connector (90980-10933) come with the wires?
    When i bought a Toyota fog-light switch, i had to buy the switch, a connector and 4 repair wires to put into the connector
  9. Mar 17, 2012 at 6:55 PM
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Ventura, CA
    2022 Toyota Tacoma SR5 DCSB 4x4
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    nice. looks clean
  10. Oct 11, 2012 at 2:04 PM
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    I tried this but tapped my 12v ign wire from the fuse panel because I have the rear locker on the green connector that OP used.
    when I turn the key to on, my fog lights turn on without the switch engaged..the indicator light turns on as well, so i'm partially there...anyone have ideas for me to try?
    I did the anytime foglight mod in the engine bay box with bending the relay tab and running it to the green ign 12v...think that would be a problem?
  11. Oct 11, 2012 at 5:06 PM
    05RedTaco
    05RedTaco Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
  12. Oct 11, 2012 at 5:57 PM
    t_e
    Erik
    miami,fl
    sounds like you have one of the other wires mixed up, it shouldnt matter where you get 12v ignition from.
  13. Oct 11, 2012 at 11:09 PM
    luka
    Kailua, HI
    I got it working..turned out to be the U connector inside the switch was off and tripping multiple circuits...
    I wired my dtrl toggle switch into the fj roof light switch...i'll post the write-up in a bit
  14. Oct 14, 2012 at 1:28 AM
    adio
    adio Well-Known Member
    HI
    2015 INFERNO TRD PRO
    sub'd. where's the best place to get this parts from?
