-   -   I need help ASAP (http://www.tacomaworld.com/forum/lighting/213812-i-need-help-asap.html)
SR5tacoma 04-07-2012 01:24 PM
I need help ASAP
so i just installed some aftermarket fogs and i wired them into the driving lights(the little orange bulb in the corner on the lights) and all was fine turned on the lights worked like a charm turnd off the lights put the grille back together and tried them one more time and nothing...the driving lights dont come on at all not when i have the hi/low beams on not when i put just the driving lights on and the fogs don't work now either. what could have gone wrong in that 10 minute window....
mjm540ii 04-07-2012 01:27 PM
Sounds like you blew a fuse.
SR5tacoma 04-07-2012 01:28 PM
fuck me that's what i thought it might be. where do i get a new fuse at? how much is that going to run me?
mjm540ii 04-07-2012 01:37 PM
Originally Posted by Idaholandho (Post 4876930)
less than a diet coke?
Not a diet coke, but a Sprite, maybe.
1st gen or 2nd gen?
A new fuse probably won't solve the problem. Do not buy a higher amperage fuse either to replace it. Get an "add-a-fuse" instead. Chances are, you still have a spare fuse in the fusebox somewhere. Check the fuses under the coin tray. The 3rd fuse on the top ("TAIL", 10A) should be the culprit if you did indeed wire the aux lights to the parking lights, like you said you did. This fuse also regulates your taillights. Turn your lights on and if they dont work, thats it. (Taillights, not brakelights)
SR5tacoma 04-07-2012 01:42 PM
1st gen or 2nd gen?
2nd gen. 2011.
ok i'll take look and se if that will fix the problem
SR5tacoma 04-07-2012 01:50 PM
yup tails are out. where is the extra fuse at?
mjm540ii 04-07-2012 02:53 PM
THey should be located in the fuse panel under the hood. If not, youll have to go to the parts store and get a 10amp mini fuse
SR5tacoma 04-07-2012 03:28 PM
got it thanks man i really appriciate it
