2012 Climate Control Lighting Issue
Discussion in 'Lighting' started by Fink44, Apr 22, 2012.
  1. Apr 22, 2012 at 8:03 AM
    Fink44
    Fink44 [OP] Active Member
    Ron
    Thornton, CO
    2016 Double Cab 4x4 - Quicksand
    I have searched but have been unable to find an answer or a similar question. I have a 2012 Tacoma, with 8k miles, and nothing backlit lights up. The only electrical mod I have done is to add Hella 500s with their own switch. Everything else works, fuses are good. I even took the the ac module out to see if I can see anything. :confused:
    I don't drive a lot at night, so I have no clue if they ever worked to be honest (pretty sure they didn't). And when looking at them, they don't even look like they should light up, although now I know that they do. Any help would be appreciated. Thanks.
  2. Apr 22, 2012 at 11:19 AM
    grizquad
    grizquad Well-Known Member
    Steve
    Massachusetts
    12 Tacoma TRD sport
    Plasmaglow Firestorm lights, Westin Bull bar, Flyzeye interior console lights
    Mine work normal with the dash lights and are tied into the dimmer control system for the dash. I did the "Flyzeye" light mod and tied into the hvac lighting control and everything works great. By the way the Flyzeye lights are great. Look at their install pictures and it shows the wires that control the hvac panel lighting.
  3. Apr 23, 2012 at 7:36 AM
    Fink44
    Ron
    Thornton, CO
    That Flyzeye product look very cool. Once I resolve this issue, I will take a closer look.
    I am feeling really dumb now. I just realized that none of my backlighting, other than my gauges (speed, temp, tach), is working. No radio, fog light or HVAC. I am wondering if there is a simple solution, considering that maybe it is all on the same circuit. Any help would be appreciated. I am really trying to avoid going to the dealer, because it is such a hassle.
  4. Apr 23, 2012 at 7:24 PM
    Fink44
    Ron
    Thornton, CO
    I'm an idiot. After reviewing other posts I want back and checked the "tail" fuse and found that it had blown. I'm wondering if it had anything to do with the brake controller I use when hauling our trailer. Anyway, problem solved.
