-   -   LED Bed Lighting Question (http://www.tacomaworld.com/forum/lighting/223618-led-bed-lighting-question.html)
tomcat91783 06-07-2012 08:52 PM
I need help; I want to install LED bed lights with the switch placed in one of the empty slots on the left hand side of the steering wheel. I already bought the LED strips and Rocker Switch, I just need to know where and how to connect it to from the trucks power source > switch > LED's. If anyone knows of a link or can help that would be greatly appreciated.
MJonAgs32 06-07-2012 09:58 PM
I would post the link, but I'm on my phone. Check my build for the link to how I did mine. Done exactly the way you want with a diagram that I drew out
tomcat91783 06-08-2012 01:17 AM
Thanks alot Bro, this is what exactly I was looking for
Drunknsloth 06-08-2012 01:31 AM
Check my signature
tomcat91783 06-08-2012 05:18 PM
I saw the diagram and BTW I'm completely new at electrical stuff; when you indicated that you grounded the LED strips onto the frame and Rocker Switch for illumination. What does that mean and what did you do?
Drunknsloth 06-09-2012 01:10 AM
See Step 17 and 18 of my DIY. Grounding the lights to the chassis completes the electric circuit because the negative of your battery is also connected to the chassis so you don't have to run a wire all the way back up to the battery. This allows you to ground basically anywhere metal on the truck that is bolted to the chassis. If you have a lighted switch then you need to run a wire to a ground to complete the circuit for that little light. With a basic lighted switch you shouldn't need to run a separate power source to it. It just draws the current from the original power source you have running to it.
