-   -   Help with switch (http://www.tacomaworld.com/forum/lighting/226331-help-switch.html)
fullstream 06-25-2012 07:58 PM
Help with switch
http://img.tapatalk.com/a693780f-1488-c1db.jpg
I am using this switch to power 2 hella 700's w/ 55 w HID's
The posts are 2, 3 & 4
2 is power to illuminate
3 is power from relay
4 is ground
Is this correct?
Not sure what type of switch it is but it has 0311 on the side.
http://i239.photobucket.com/albums/f...t/A733BE4A.jpg
http://i239.photobucket.com/albums/f...t/493D63EA.jpg
Pugga 06-26-2012 06:50 AM
That's typically how switches are wired but without know specifically what switch that is or having the poles labeled other than 2, 3 and 4, there's no way to know for sure without a volt meter.
Also, I'd run the power for the relay trigger through the switch, not the power for the lights. That significantly reduces the amount of power running through the switch (especially because you don't know what the switch is rated for).
fullstream 06-26-2012 09:16 PM
Thank you sir, went to a buddy's house who is an electrician, he hooked me up :). Let there be light.....
