-   -   09 Parking Light Trouble (http://www.tacomaworld.com/forum/lighting/228120-09-parking-light-trouble.html)
BRUIN8124 07-06-2012 11:36 PM
Looking for some advice...
I noticed that my 09 passenger side front parking light was out a few weeks ago. I purchased a new bulb and went to switch it out. When I checked out the old bulb, it looked ok. I plugged it back in and it still worked when I turned the lights on.
A week or so later, the light was out again. I got it to go back on by just tapping on the headlight assembly. Then it was fine for a while.
That was happening more and more so I put the new bulb in anyways. It is still happening.
Thoughts? Loose wire maybe? As far as I can tell, it looks ok.
I dont know, it is kind of annoying. Anyone else had this problem? All other bulbs and fuses are ok. I would rather not take it in to the shop for something like this.
BRUIN8124 07-08-2012 09:00 PM
(bump) Anyone?
Rich91710 07-08-2012 09:12 PM
Connection in the harness. Possibly where the harness plugs into the bulb socket.
It can be a bit of a pain to separate, but get it apart (take your time) and put some tune-up grease on the pins.
BRUIN8124 07-10-2012 12:42 AM
Thanks Rich!
That seemed to do the trick. So far, so good anyways...
+1
