-   -   LED bulb numbers from superbrightled.com (http://www.tacomaworld.com/forum/lighting/231346-led-bulb-numbers-superbrightled-com.html)
tomash66 07-26-2012 03:09 PM
I had found a write up a couple weeks ago that someone had posted the bulbs that they bought from superbrightled.com(with the part number) and now I cant find it anywhere. The reason Im not using the sites bulb finder is because i did that for my wifes car and got a wrong size bulb in the mail.
Aw9d 07-26-2012 03:14 PM
Soooooooooo what bulbs are you wanting to replace?
tomash66 07-26-2012 04:21 PM
The post I had found had everything but the headlight and turn signals and id like to do the same I've already done the dome and map lights
Aw9d 07-26-2012 04:25 PM
Here ya go. All the bulb sizes you would ever need to know for the Taco.
http://www.tacomaworld.com/forum/lig...e-posting.html
tomash66 07-26-2012 04:30 PM
Do those match up with what's on superbrightlightleds.com?
Aw9d 07-26-2012 04:34 PM
I would assume that they go by the same bulb types and numbers that the rest of the world uses. I'd check with them as I've never bought from their site.
tomash66 07-26-2012 05:30 PM
no its not the same on there site. that thread was helpful but the thread I had found earlier was a superbrightleds.com site specific one
Aw9d 08-02-2012 02:30 PM
Um, not sure what you are looking at but everything was listed here and all the numbers pretty much match up.
http://www.superbrightleds.com/vehic...ulb_finder.php
RipVanDango 08-06-2012 05:26 PM
If you replace the dtrls make sure you get the bulbs with ck wiring. The regulars will blow one of two fuses connected to them.
