-   -   What do I need for these lights? (http://www.tacomaworld.com/forum/lighting/235932-what-do-i-need-these-lights.html)
12DblCab 08-24-2012 09:49 AM
What do I need to mount these lights? A (what amp?) inline fuse, (unknown) gauge wire, and a switch? I haven't put aftermarket lights on a vehicle since my Jeep over 8 years ago, and those lights came in a kit. If I mount a strip on each side under the hood, can I splice the wires together before it gets to the fuse? Thanks for the help.
http://www.amazon.com/gp/product/B00...A2YUWVZ0U5K5TO
http://ecx.images-amazon.com/images/...500_AA300_.jpg
Here are some inline fuses. Not sure what to get... :o
http://www.amazon.com/s/ref=sr_gnr_a...qid=1345826765
ProForce 08-24-2012 10:20 AM
I would not get these lights to begin with. They look very cheap and ship from China. Nothing against china, but you don't exactly get the highest quality stuff there. Hence the reason its so cheap.
That being said, if you do get them, or any other similar led strips, wire them all together, negative to negative, positive to positive. Once you have a single + and - wire for all your lights, negative gets grounded to the frame, or any metal body panel that eventually attaches to the frame in some way. Positive goes to a relay. The relay gets wired as follows:
(Instead of Fogs, it would be your led strips)
http://i889.photobucket.com/albums/a...ightsrelay.png
30 and 86 go to a fuse, then battery.
87a is not used
87 goes to + on all you led strips
85 goes to a switch, then then other side of switch goes to ground.
You can use a 10amp fuse and 16awg wire. This setup allows the lights to be tired on anytime, even with the truck off. I figure since you wanted these for under the hood work lights, that's how you would want it. If you want it to only work with key, then 30 goes to battery positive with a 10amp fuse and 86 goes to accessory + with a separate 10amp fuse.
I find this wiring to be the easiest, but if you have a switch with an indicator light, then the wiring gets changed as follows:
30- battery + w/ 10a fuse
87- to + lights
87a- not used
85- ground
86- to switch
Then the other side of the switch gets attached to either battery + or accessory + with a 10amp fuse.
Even 18awg wire is more then enough for some small led strips, but 16 is easier to work with and you can use 14 if you wanna get crazy with it, but it really doesn't matter for lights with such a small current draw. And even a 5amp fuse is probably enough, but 10 will be fine.
Check out superbrightleds.com and oznium.com
They have much higher quality lights at a good price still :thumbup:
Zombie Runner 08-24-2012 10:23 AM
for LED's you really dont need a relay since they draw next to nothing for power.
Ive always had mine fused then to a switch then to the battery.
for LED strips check out Oznium.com and superbrightleds.com
Ive had good luck with both companies
Pugga 08-24-2012 10:31 AM
Those small LED's will draw next to nothing. Get the smallest fuse you can find, probably 2.5A and any relay will be big enough to handle them.
To wire them under the hood, this is what I would do: Battery power - Inline Fuse - Inline Switch (mounted under the hood, outdoor switch) - Lights. Tie all the grounds together and ground them together. No relay required because of the low draw and I'm assuming you'd want to turn these on even when the engine is not on so no need for a 'trigger' for a relay.
ProForce 08-24-2012 10:36 AM
Both replies are correct in that a relay is not required. However, i still choose to relay all accessories for added protection and quality. Toyota systems are very sensitive and the electrical system needs to remain as isolated as possible. But to avoid the headache, I'd just say skip the relay. Still use 16awg wire, and reduce the fuse from 10 to 5. Even a 2.5 would work, but I'd stick with 5
09DBLCAB09 08-24-2012 06:43 PM
87a is not used
87- to + lights
87a- not used
85- ground
86- to switch
99.9% of light that are sold in America were made in China
12DblCab 09-06-2012 05:57 PM
I worked on the lights today. Keep in mind, this is the $5 pair of (4) LED strips I got off Amazon.
Here is the engine compartment without the lights on.
http://i45.tinypic.com/sb4oko.jpg
Here is part of the wiring showing the 10 amp fuse and switch.
http://i47.tinypic.com/33w9v95.jpg
Annnnd... the final product. I only used 2 of the 4 strips, and they supplied more than enough light for the engine compartment. They are angled inward a little bit instead of straight down. If I don't use the other strips for anything else, I might splice them in and put them next to the other strips.
http://i50.tinypic.com/2rhoa3q.jpg
Pugga 09-06-2012 05:59 PM
Loods good! I like the underhood lighting mods, very useful :thumbsup:
12DblCab 09-06-2012 06:02 PM
One last question...
I used all three prongs of the switch, using the copper colored prong for the ground as recommended on other websites. The switch LED stays lit whether it is in the OFF or ON position. Should it be doing that? I figured it would only light the LED indicator in the ON position.
This is a different switch, but with the same connections...
http://i152.photobucket.com/albums/s...1963989164.jpg
A big thank you to all of you that helped. I tried to Rep everyone.
Pugga 09-06-2012 06:36 PM
Try switching the power in and power out tabs on the switch (leave the ground and switch the other 2). Depending on the internal of the switch, that might make it so the switch is only lighted when it's in the on position.
