2013 Fog Light Mod... wont turn off with ignition???
Discussion in 'Lighting' started by Nicky Lam, Nov 12, 2012.
  1. Nov 12, 2012 at 2:15 PM
    Nicky Lam
    Nicky Lam [OP] Dog Face Soldier
    Nick
    Somers Point/Mount Laurel, NJ
    2013 Blk DC Off Road
    NOV12: Front windows tinted to matched to rear windows 12NOV12: Fog light anytime mod DEC12: OME 885 w/ 25912 top plate spacers for full 3" lift OME Trim packer Dakar Rear 5 Leaf Packs Total Chaos Uniball Upper Control Arms 2.5° Degree Rear Axle Shims 18JAN13: 17x9 Fuel Kranks 17x9 4.5 BS -12mm Offset 285-70-17 Goodyear Duratracs 23JAN13: OME Carrier Bearing Drop Kit 05FEB13 TRD Aluminum Skid Plate 05FEB13 TRD Stainless Steel Cat Back Exhaust (2012 modified to fit 2013) Auto Mate 5304A (Viper 5704 Equivalent) 2-Way Alarm/Remote Start with Smart Start for iPhone De-Badged All Emblems 30JUL13 Go Rhino Stainless Steel Dominator II Side Steps *not yet installed: Stainless Steel Extended Rear Brake Lines
    ok so heres a little video i made, the fog lights turn on and off with the oem button as i please now, low beams high beams, if the button i depressed, the light stays on. great. thats exactly what i wanted, but... it doesn't turn off when i exit the vehicle and lock it. any ideas? im trying to get it to turn off when i switch the ignition to off so i dont have to manually push the button to turn it off whenever i exit the vehicle. i know its just a matter of tapping into something/somewhere else. just have no idea where (im not the most savvy electrician)
    the fog light relay was bottom left pin that i bent and tapped with a wire to the trail tow which was the top right pin.
    once again this is a 2013 i know its different on previous 2011 models.
    thanks!
    heres a link to the video
    http://www.youtube.com/watch?v=kjBUCEbnAOk&feature=plcp
    and those who are wondering why my fogs are yellow, i got that amber lens repair tape and covered the housing. easy cheap mod, looks better than facotory halogen color. the tape is pretty stretchy, i took a hair dryer to it and stretched it out so there was not any creases or wrinkles.
  2. Nov 12, 2012 at 2:26 PM
    tdunc
    tdunc Well-Known Member
    Houston, TX
    2013 DCSB TRD OR
    Sounds like the relay coil is wired directly to the battery rather than to an ignition switched source. In the stock main fuse/relay box, you'll find a harness toward the engine with a light green wire coming out of it. That is what I used to tap in to an ignition switched source. I'll try to post a picture of what I'm talking about tonight. Or if you have a voltmeter, you can probe around to find the wire I'm referring to
    Edit: the harness I'm referring to is on the far right of this picture (fyi, not my picture)
  3. Nov 12, 2012 at 2:39 PM
    Nicky Lam
    Nick
    roger... so in this picture the harness with the light green wire. is furthest right, not bottom right... but directly in the middle, right? i think i can see the light green wire in this picture.
    thanks for the quik reply
  4. Nov 12, 2012 at 3:23 PM
    Nicky Lam
    Nick
    yep... light green wire did the trick. awesome. thanks. rep for you
  5. Nov 13, 2012 at 6:11 AM
    tdunc
    Houston, TX
    2013 DCSB TRD OR
    Good deal, glad it worked out for ya
