Brightest fogs without going HIDs?
Discussion in 'Lighting' started by ToyotaKTMracing, Nov 13, 2012.
  1. Nov 13, 2012 at 8:16 PM
    ToyotaKTMracing
    ToyotaKTMracing [OP] The Blue Warrior
    Shay
    West Virginia
    2008 DCSB Ink 4WD Auto
    285 BFG ATs, Custom dual exhaust system, 4" total lift (adjustable billies with 885 coils in front and AALs with 1" block in rear), interior LED lighting, LED reverse lights, LED license plate lights, fog light anytime mod, JVC KW-R500 stereo, 20" okledlightbars.com LED light bar, coverking seat covers
    What the title says. One of my fogs went out so it's time to replace. I want to know what is good to get. Want really bright and a light that has a pure white color. Cool white, not warm white. Ideas? I'm going to probably be getting projector headlights and the beam doesn't spread real wide and I need the fogs to make up for it. (Yes, I know the fogs don't go real far either, but it's better than nothing.) I've even wondered about LEDs. Anybody run LEDs?
  2. Nov 13, 2012 at 8:23 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    There was a thread about LED fogs. They're more for show.
    Not sure what to suggest.
  3. Nov 13, 2012 at 8:25 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Ya... LEDs don't cut it.
    HID is too bright/glare.
    55w is about it. Fogs are really only supposed to cut under the fog to make you visible without blinding oncoming. Most of us use them more as "ditch lights" to provide a broader pattern.
    And a quality projector retrofit will provide a perfectly good pattern.
    Just stay away from eBay projectors.
  4. Nov 13, 2012 at 8:26 PM
    ToyotaKTMracing
    Shay
    West Virginia
    Oh. I don't want show. Just a bright white light. I've been reading and searching and pretty much have just been seeing positive and mainly negatives about everything.
  5. Nov 13, 2012 at 8:27 PM
    ToyotaKTMracing
    Shay
    West Virginia
    This. I need a wide beam. Ideas?
  6. Nov 13, 2012 at 8:28 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
  7. Nov 13, 2012 at 8:28 PM
    ToyotaKTMracing
    Shay
    West Virginia
    And the projector light I do want, I can get off ebay. One guy one here got the same one and switched the projectors. Which I would probably do down the road.
  8. Nov 13, 2012 at 8:29 PM
    Corndawg
    Corndawg Well-Known Member
    Corey
    Utah
    2007 double cab TRD off road Radiant Red
    2.5 inch pro comp lift Cobra XRS 9745 Detector 15 band scanner Pioneer DEH-P6900UB Python 991 remote start/ security. Tinted license plate covers Fog Light Mod PIAA Extreme White 4000K Replacement bulbs Red LED Dome and Map lights LED replacement tail light bulbs Black Weather Tech Floor Liners front and rear
    yellow, light is the best for fog and snow.
  9. Nov 13, 2012 at 8:31 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Be sure to look into the details of that mod... it was pretty involved.
  10. Nov 13, 2012 at 8:32 PM
    ToyotaKTMracing
    Shay
    West Virginia
    I'm mainly not going for fog and snow use. I need it for a wide brightness beam. I have my light bar, but it's illegal to use on the road here and will blind oncoming traffic.
  11. Nov 13, 2012 at 8:33 PM
    ToyotaKTMracing
    Shay
    West Virginia
    It was. He even switched the halos. After he was done, it was over a $400 project :eek:
  12. Nov 14, 2012 at 6:35 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Not just the harness, but use the stock power leads to switch a relay.
    200w is just a bit over what the 70w circuit was designed to carry.
  13. Nov 14, 2012 at 6:38 PM
    ToyotaKTMracing
    Shay
    West Virginia
    Yeah, that idea scares me. And sounds more expensive than just lights. Might as well go HID at that point.
  14. Nov 14, 2012 at 6:58 PM
    b0ules
    b0ules Fresh frame!
    Ottawa, Canada
    Speedway Blue 06 TRD Off-Road
    Leer 100XL Topper OME 885X/Nitrocharger Sport Front Dakar Leafs/Nitrocharger Sport Rear
    Not at all difficult nor expensive, but as mentioned, you may have some big heat problems with 100w bulbs. I've melted the H4 (9003?) socket right to the bulb on motorcycles back in the day when I thought brighter was better for being seen... But that was metal base into a plastic socket, not plastic to plastic like I believe we have?
  15. Nov 14, 2012 at 7:04 PM
    b0ules
    b0ules Fresh frame!
    Ottawa, Canada
    Oya, if you can get sylvania silverstars or silverstar ultras, they throw a really nice cold white light. Noticeably whiter (not blue!!!) than regular halogen, and if they make our size, it'll be stock wattage so no worries there.
  16. Nov 14, 2012 at 7:07 PM
    themuffinman619
    themuffinman619 Play stupid games, win stupid prizes
    themuffinman
    Your moms house
  17. Nov 15, 2012 at 2:09 PM
    Tuctaco
    Tuctaco Well-Known Member
    Todd
    Tucson, AZ
    2012 MGM TRD OR 4x4
    Katzkins, Redline hood struts, Pop & Lock,285/75/16 Toyo Open County ATll, 16X8 Konig Countersteer, Icon extended coilovers, Icon rear shocks, Icon progressive leaf pack, LR UCA's, extended brake lines,
    If you want to do projectors in your Fogs look into the Blazer projectors. I'm getting ready to retrofit my fogs.
  18. Nov 15, 2012 at 7:15 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    That's the way to go if you can find a set still available. TRS discontinued them.
    Fogs should have a flat, wide pattern.
    HIDs in fog housings create even worse glare for other divers than they do in H4 housings.
    PLEASE do not do this! It is extremely dangerous to other drivers.
  19. Nov 15, 2012 at 7:16 PM
    ToyotaKTMracing
    Shay
    West Virginia
    I figured that. Plus I don't have the money for that. No worries.
  20. Nov 16, 2012 at 7:25 AM
    b0ules
    b0ules Fresh frame!
    Ottawa, Canada
    Amen. I'm waiting for LE to start cracking down on drivers running HIDs in halogen reflector housings... Hasn't happened around here yet (is it being done anywhere in NA?), and I get blinded several times a day on my commute by people who really don't clue in on this... My brother-in-law even commented that before he realized the danger and removed them, the usable road illumination was crap.
    But hey, it looks really cool... :facepalm:
