driving lights that come on with brights
Discussion in 'Lighting' started by jokerj80, Nov 20, 2012.
  1. Nov 20, 2012 at 9:58 PM
    jokerj80
    jokerj80 [OP] Well-Known Member
    Jeremy
    O..H!!
    12 tacoma quad cab
    SS bull bar, K&N air filter, Pioneer avh8400, Kicker amp and sub, window tint, bug shield, T-Rex grille, Hella Ralleye 1000 behind grille, lund genesis bed cover
    i would like to install my driving lights and i want to wire them to a switch but would also like them to come on when i hit my brights. so when the switch is on they come on when the brights are activated but when the switch is off they do not come on. any advice would help. thanks!
  2. Nov 20, 2012 at 10:38 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    High beam hot feeds power to the switch.
    Switch feeds power to the coil on a relay that switches battery power to the aux lights.
  3. Nov 21, 2012 at 8:56 AM
    jokerj80
    Jeremy
    O..H!!
    12 tacoma quad cab
    uuhhh, ok? i was hoping for more detailed info.
  4. Nov 21, 2012 at 9:44 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Here's the extended version:
    Tap into the high beam power wire.
    Run a wire from that tap to your switch as the power input.
    Run the power output from the switch to the 85 terminal on your relay
    Connect 86 on the relay to the ground
    Feed fused power to 30 on the relay
    Connect 87 on the relay to your lights
  5. Nov 21, 2012 at 11:40 AM
    Pugga
    Massachusetts
    ^^Fancy!
  6. Nov 21, 2012 at 11:44 AM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Good diagram Caribe, but IMHO, it's dangerous to be that exact on the pinouts on the switch, as there are 12 different configurations for the crap that they sell in auto parts stores here in the US... there's no telling what he will buy, and we're always reading reports of people connecting switches that include a ground and burning wiring because they somehow got the switch on the wrong side of the fuse, and hooked the ground to the wrong terminal.
    The ground-true switching is common, and really the safest way to do it, but it is not intuitive to most people here in the 48. We generally switch the hot and terminate the device at the ground.
  7. Nov 21, 2012 at 1:53 PM
    jokerj80
    Jeremy
    O..H!!
    12 tacoma quad cab
    Wow dude thanks. That's exactly what I was looking for. Awesome job!
  8. Dec 12, 2012 at 6:06 PM
    AllanJackson
    AllanJackson Member
    Allan
    Greenville, SC
    06 Tacoma X-Runner
    Bull Bar, KC off road lights
    Caribe your diagram is great! But I'm curious how exactly that fuse thing at the bottom is implemented. Could someone clarify it or post pictures?
  9. Dec 12, 2012 at 6:13 PM
    AllanJackson
    AllanJackson Member
    Allan
    Greenville, SC
    06 Tacoma X-Runner
    Also, I noticed in the diagram it says no cutting into oem wire harness.. Does that mean to get the power to the relay from the battery now? Pugga says to get the power from the high beam power wire.
  10. Dec 12, 2012 at 6:17 PM
    Chepo
    Chepo Tankoma!
    Mexico City
    '11 TRD Sport
    Lots...
    What I did was to create an independent circuit for the new lights: Fuse directly from battery and a relay (which will turn on the new lights when you hit the brights).
    Then I looked under the the relay that controls Hi & Low Lights... then, I ran a wire from the pin that is activated when you hit the brights which is the "signal" for the new relay...
    Voilá! it is very simple
    How it turned out: (Blue wires are "signal" from Fogs and Brights)
  11. Dec 12, 2012 at 7:20 PM
    AllanJackson
    AllanJackson Member
    Allan
    Greenville, SC
    06 Tacoma X-Runner
    I thought about that too so I took off the relay for my high beams and touched my new relay to the fuse panel where the high beam activator would be but it still turned on my new lights with my headlights off. That is my problem! Is my car defective? Because its getting current to it even with the car off!!
  12. Dec 12, 2012 at 7:32 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    The supply feed for the high beams is hot 24/7.
    Your truck is not defective.
  13. Dec 12, 2012 at 8:12 PM
    AllanJackson
    AllanJackson Member
    Allan
    Greenville, SC
    06 Tacoma X-Runner
    Man this is confusing.. Basically what goes into 86 (the switch) on the relay so that when my high beams are on, so are my off road lights.. I can't figure it out.. Everything I try to hook it to seems to flip the switch even if the car is off
  14. Dec 12, 2012 at 8:24 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    If you turn the headlights on, they, and whatever they trigger, will come on whether the car is on or not.
    Simplest thing is to feed the switch from the high beam wire on the back of the socket, then the switch feeds the relay on 86, 85 goes to ground.
  15. Dec 12, 2012 at 8:28 PM
    AllanJackson
    AllanJackson Member
    Allan
    Greenville, SC
    06 Tacoma X-Runner
    What I am saying is it flips the switch WITHOUT my lights, car or anything on. I can't get the relay to turn back off
  16. Dec 12, 2012 at 8:44 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Not going to be possible to troubleshoot that over the net.
    You have some kind of feedback loop wired in.
    Remove everything and find someone local that can help you in person before you burn your wiring system.
  17. Dec 12, 2012 at 8:48 PM
    AllanJackson
    AllanJackson Member
    Allan
    Greenville, SC
    06 Tacoma X-Runner
    Alright well thanks anyways!
  18. Dec 13, 2012 at 8:01 AM
    AllanJackson
    AllanJackson Member
    Allan
    Greenville, SC
    06 Tacoma X-Runner
    So you are saying for the head relay.. The switch in it doesn't matter, it is waiting to be grounded to be activated by the ECU. Btw, your diagrams are very clear! So my relay needs to follow the lines of ground it to where the head relay pin 1 is hooked to?
  19. Dec 13, 2012 at 8:10 AM
    Pugga
    Massachusetts
    Caribe and I accomplished the same end function just 2 different ways. Caribe is accustomed to using the ground as the switch where as I'm more used to switching the power side. His method is neater, mine is a little more straight forward although does require splicing into one of the OEM wires. When it comes to wiring in an aftermarket accessory, there are many ways to go about doing it, especially when it comes to 'custom' functions. I would choose the way you understand the best and you are most comfortable doing.
  20. Dec 13, 2012 at 9:16 AM
    Chepo
    Chepo Tankoma!
    Mexico City
    '11 TRD Sport
    Lots...
    Ok, Ill take some pictures later of how I wired mine! They only turn on with brights...
