-   -   Light bar install in Lower Grill Opening (http://www.tacomaworld.com/forum/lighting/251334-light-bar-install-lower-grill-opening.html)
GTABurnout 12-01-2012 03:54 PM
I ordered a light thru the okledlightbars.com GB. I went with a 20" because at the time I was planning on running a light bar. After some thinking I decided I would rather save the light bar money and mount it in the grill some how. I have no desire to change my actual grill so the next best spot is the lower Grill.
So last night I pulled the grill and took a few measurements. And test fitted the light to see where i could mount it. I was hoping I could just mount it to the aluminum crash beam but the feet for the light would have made that too tall.
The light:
http://www.desertstreetcars.com/pics...ightbar_01.jpg
I noticed that the crash cans sit slightly below the crash beam. Unfortunately since I had a 20" light the feet would not span the 35" inches between the two. I decided to get a piece of angle iron and span the gap and then just mount the light to that.
The angle iron would need to be 35" or more. I found a piece of 36" long 2"X1" L bracket.
http://www.desertstreetcars.com/pics...ightbar_02.jpg
http://www.desertstreetcars.com/pics...ightbar_03.jpg
It would just need to be notched so the bracket would fit between the crash cans....
Removing the bumper cover to get access to everything...
http://www.desertstreetcars.com/pics...ightbar_04.jpg
Testing fitting the L bracket after cutting.
http://www.desertstreetcars.com/pics...ightbar_05.jpg
http://www.desertstreetcars.com/pics...ightbar_06.jpg
Perfect....
Now to see if the light will fit ok...
http://www.desertstreetcars.com/pics...ightbar_07.jpg
http://www.desertstreetcars.com/pics...ightbar_08.jpg
And now to test fit the bumper to make sure my measurements where correct...
http://www.desertstreetcars.com/pics...ightbar_09.jpg
Light fits correctly and is pretty much centered in the lower grill....
Now I can not really access the locations where I want to bolt the L bracket to the crash beam. So Off it comes....
http://www.desertstreetcars.com/pics...ightbar_10.jpg
Crash beam...
http://www.desertstreetcars.com/pics...ightbar_11.jpg
Black painted Bracket...
http://www.desertstreetcars.com/pics...ightbar_12.jpg
So the beam is pretty much a long piece of extrusion. So its hard to get bolts in and then get nuts on to those bolts. So I went with a few self tapping fasteners.
I over did it. 4 on each side of the crash can and about 8 holding the loer part of the L to the crash beam.
Center punches
http://www.desertstreetcars.com/pics...ightbar_13.jpg
http://www.desertstreetcars.com/pics...ightbar_14.jpg
Bolted down and back on the truck.
http://www.desertstreetcars.com/pics...ightbar_15.jpg
http://www.desertstreetcars.com/pics...ightbar_16.jpg
http://www.desertstreetcars.com/pics...ightbar_17.jpg
http://www.desertstreetcars.com/pics...ightbar_18.jpg
And bumper back on....
http://www.desertstreetcars.com/pics...ightbar_19.jpg
With the bumper on I will need to remove the grill to gain access to the light but still I can re-aim if required.
http://www.desertstreetcars.com/pics...ightbar_20.jpg
http://www.desertstreetcars.com/pics...ightbar_21.jpg
http://www.desertstreetcars.com/pics...ightbar_22.jpg
And all wired up.....
http://www.desertstreetcars.com/pics...ightbar_23.jpg
All and all a successful install. The light bar is solid the mount is solid. Tonight I hope to meet us with another Tacoma who bought a 21S blitz pro light and mounted his in the same location with a different method and see how they compare.
Night pics tomorrow.
Tacomanator 12-01-2012 04:02 PM
Looks good. Can't wait to see night pics!
Leggo 12-01-2012 04:17 PM
very nice! how much?
Glocker23 12-01-2012 06:50 PM
Very cool. Want to come and do mine in CT ?
GregLee98 12-01-2012 06:55 PM
Awesome! Im' interested in the night pics and the light out put.
LowHangingFuries 12-01-2012 06:57 PM
Man I like that truck too!
60driver 12-01-2012 07:45 PM
Nice work, unfortunately I have the pesky front license plate (damn you CT). Maybe I'll take it off until I move back home from wherever the army puts me. I would rather do it your way than a bolt on light bar. And I already have a 20" led sitting around.
mattgecko 12-01-2012 07:51 PM
Looks good. I was kicking around a 40" bar in the lower grill but not sure if it would affect the cooling.
perchie15 12-01-2012 08:19 PM
this is what i wanna do!! also a good way to avoid theft of the light by a little bit anyways :D
GTABurnout 12-01-2012 08:50 PM
Plans are to get night pics tonight along with some pics of a Blitz Pro Bar mounted in the same location.
Reeves 12-02-2012 01:24 AM
Is there any shake in the Light at night?
SkullTaco2012 12-02-2012 08:03 AM
Subd
Large 12-02-2012 08:04 AM
Clean install. Any trouble aiming it while it's back there?
memario1214 12-02-2012 09:05 AM
Eh... 40 is just a bit too big for there
bjmoose 12-02-2012 09:17 AM
Nice writeup. Looks like a fine placement for a bar containing only spot/driving lights. I'd be worried that any "flood" bulbs would be impinged by the grill and have part of the "wide throw" light you look for with a flood cut off by the lower bumper.
GTABurnout 12-02-2012 11:20 AM
I took the truck down a pretty rutted dirt road and the shake is no worse then the stock lights. Maybe tonight I will strap the GoPro and and take some video.
GTABurnout 12-02-2012 11:25 AM
Night time Light Pics
All pics taken with a D7000. Settings where manual and all pics taken with same settings. No photoshop except to resize.
LED Bar Only
http://www.desertstreetcars.com/pics...acoma/20_1.JPG
Low Beams
http://www.desertstreetcars.com/pics...acoma/20_2.JPG
High Beams
http://www.desertstreetcars.com/pics...acoma/20_3.JPG
Highs and LED Bar
http://www.desertstreetcars.com/pics...acoma/20_4.JPG
05Aztacoma 12-02-2012 11:42 AM
:thumbsup:
Makes me want to buy one now........
YumaTRD 12-02-2012 11:50 AM
Originally Posted by 05Aztacoma (Post 6073300)
:thumbsup:
x2
Super clean and sturdy mounting points.
GTABurnout 12-02-2012 01:15 PM
quick Video...
http://www.youtube.com/watch?v=dRkGj...ature=youtu.be
