-   -   Interior courtesy lights (http://www.tacomaworld.com/forum/lighting/25184-interior-courtesy-lights.html)
jdumas54 01-27-2009 08:34 PM
Just wondering, if any of the Tacoma models have dash operated interior lights? I so miss being able to light up the cab, by rolling the guage dimmer switch.(like on most vehicles I have owned) It is a pain having to reach up behind me and fiddle to find the ceiling light switch just flash the interior light on for a few minutes.
Has anyone added a feature like this to cabs without this option? I would think adding lamps under the dash would be possible.
if this has already been addressed, I apologize...
chyknees 01-27-2009 10:49 PM
Also curious about this.
My friends new Tundra has a little amber led that is mounted on the front side of the center armrest. Thinking about trying to find that or just hit up Radio Shack for those little LEDS. But to put it on a dimmer switch would be even nicer.
monoman 01-30-2009 12:18 PM
:confused:Not sure on the later models on how they are wired up, but what I did in my '03, was hook a wire from the dome light, to the map lights to get better light in there. These Dbl cabs just don't get much light from the wimpy dome lamp alone. Only one problem doing this. I modded the map lights to where both switches are on all the time because I wanted both the map & dome to come on at the same time, so I attached a wire from the door switch (& another wire to ground) then to a toggle switch by where the cup holders are. So now I just flip the switch when I want light. Before I put in this switch, I had to open up the door to light up all three lights.
