-   -   OTRATTW switches (http://www.tacomaworld.com/forum/lighting/257273-otrattw-switches.html)
Spicy taco 01-09-2013 12:33 PM
OTRATTW switches
Here's a dumb question. I've seen a lot of pics and references to the OTRATTW switches, but I haven't seen one pic where they were mounted in the factory switch openings. Does anyone know if they'll fit? I need to order some but I want to make sure before I take the plunge.
Thanks in advance!
Sandman614 01-09-2013 12:34 PM
Thanks in advance!
The factory holes need trimming for the Carling switches to fit. You can see the trimming here.
http://i249.photobucket.com/albums/g...e/IMG_8057.jpg
http://i249.photobucket.com/albums/g...s/IMG_7683.jpg
ross123 01-09-2013 12:36 PM
The trimming is very minor. Super easy to do
Pugga 01-09-2013 12:37 PM
http://www.tacomaworld.com/gallery/d...m/SDC11549.JPG
The opening on the face of the dash is large enough, but each slot is made specifically to accept a certain OEM switch. A couple minutes with a dremel tool, and the switches fit in there very nicely! You aren't grinding anything on the face of the dash, just the returns so shave off the nubs that make that location specific to a Toyota switch (I hope that makes sense).
Spicy taco 01-09-2013 01:30 PM
Outstanding! Thanks to all 3 of you. I figured there would be some trimming but I just didn't want them to overlap the opening and look "home made" lke a lot of the cheap aftermarkets. But I also didn't want to spend $50+ per switch from Toyota either!!
Thanks again guys!
danteisme 01-09-2013 02:29 PM
just dont do what i did. i was trimming for my first switch...and i may have gotten just a hair carried away. the switch wouldnt stay put in the opening at the bottom. luckily, if you wrap one or 2 layers of electrical tape around the switch it will make up that difference easily and the switch will stay put.
Spicy taco 01-09-2013 05:25 PM
I've been known to "over adjust" things before too. I did car stereo installation for several years and nothing makes you madder than 1/16 of an inch!!:cool:
claymore 01-09-2013 10:11 PM
Minor trimming
http://www.tacomaworld.com/gallery/d.../switches4.jpg
Spicy taco 01-10-2013 09:13 AM
I ordered them last night. I wound up with the ones labeled for what they are. I needed 4 and couldn't make up my mind on the "novelty" ones so I went with the plain ones. No one sees them on the left of the steering wheel besides me anyway. Yours look nice though.
Spicy taco 01-14-2013 08:10 PM
1 Attachment(s)
Switches came in Saturday, installed them Saturday night. I hate to keep sucking knowledge out of everybody and not contributing anything, but I have another question. For the switched power lead to the switches I'm planning to add a fuse tap. My question in this...can I tap one fuse and illuminate all 3 switches, then out from there to the individual relays, or do I need to tap a different fuse for each switch? I'm using a Bluesea fuse block under the hood with a 100A CB between it and the battery.
For the record, I've been doing vehicle wiring for 20 plus years including 5 years as a car stereo installer, but that was more years ago than I like to remember and I've been struck stupid LOL! It's amazing how quickly things leave you when you don't use them everyday!
Here's a pic of the switches and thanks to all those who posted last time.
BTW, the truck and the dash are right-side up in reality. I don't know why all my pics are upside-down when I post them. Must be a built-in feature from Apple.
Wishbone Runner 01-14-2013 08:22 PM
I ran mine with two serperate power sources, one for illumination that comes from a source that goes on with the lights, and a seperate always powered for the relay feed. You will be fine running all three off the same source for either one.
Spicy taco 01-14-2013 08:59 PM
Thank you sir!! I thought that was right but it's been a while.
JWaldz 01-14-2013 11:03 PM
quit being wimps and do MOAR TRIMMING! :D
http://i130.photobucket.com/albums/p...38ADFFBF39.jpg
BBYE V8 02-02-2013 10:19 PM
You couldn't find one pic? ;)
I got a thread:
OTRATTW swithc install
I hope it helps.
Spicy taco 02-03-2013 05:51 AM
Sorry guys. I got really busy at work then came down with pneumonia. I'll get some pics up later today.
tacoma16 02-03-2013 06:12 AM
http://www.tacomaworld.com/gallery/d...liveET59tK.jpg
Hppe this helps. Had to do a bit of trimming. tHey fit snug thats for sure. Haha
DirtJumper14 02-03-2013 08:42 AM
Here are mine
http://i175.photobucket.com/albums/w...a/IMAG0134.jpg
Spicy taco 02-03-2013 10:22 AM
1 Attachment(s)
Okay here's a pic finally. They turned out great!
Spicy taco 02-03-2013 10:24 AM
1 Attachment(s)
I also made me mounting plate for the external fuse block so if it ever warms up again I'm ready to wire them up.
tacoma16 02-03-2013 10:39 AM
looks great
