-   -   Mounting 30" LED bar behind grill (http://www.tacomaworld.com/forum/lighting/260022-mounting-30-led-bar-behind-grill.html)
MarkM 01-25-2013 07:22 PM
Anyone have any pics of a 30" bar behind the grill?
Glocker23 01-25-2013 10:27 PM
Not yet. Waiting for a warm up to tear into it. I can't wait to get my grillcraft put in with light in back
ToyotaKTMracing 01-25-2013 10:30 PM
:popcorn:
PCHearn 02-13-2013 08:07 PM
bump
eric3187 02-14-2013 10:58 PM
i have 2 stacked 21" behind my grill, i can snap a picture tomorrow so you can see how a 30" may or may not fit.
PCHearn 02-15-2013 10:33 AM
Eric - Great. Please post the picture. And did you wire yours up to your headlight wires? Would you explain how you hooked yours up? Thanks.
JustinL 02-15-2013 10:54 AM
Eric quit teasing and post that thing
You hook these up like you're hooking up a set of foglights, don't touch the headlight wiring. Leave them alone.
http://www.tacomaworld.com/forum/tec...et-lights.html
JustinL 02-15-2013 11:03 AM
for mounting, there's Sabre who had some custom brackets made for his:
http://www.tacomaworld.com/forum/2nd...ml#post4597682
Sabre's mounted:
http://www.tacomaworld.com/forum/2nd...ml#post4620794
I too have a 21" from BlitzPro mounted with a BAMF bracket:
http://www.tacomaworld.com/gallery/d...liveEY5GWE.jpg
eric3187 02-15-2013 11:25 AM
i wired them up the way everyone will say not to.. haha
battery-inline fuse-25amp switch-lights-ground i choose not to use a relay. pictures will be up momentarily
eric3187 02-15-2013 11:37 AM
BAMF light mount
http://i1104.photobucket.com/albums/...ps32a6d5c8.jpg
http://i1104.photobucket.com/albums/...ps932e90e2.jpg
http://i1104.photobucket.com/albums/...ps8e9f555f.jpg
PCHearn 02-16-2013 08:55 PM
"i wired them up the way everyone will say not to.. haha
battery-inline fuse-25amp switch-lights-ground i choose not to use a relay. pictures will be up momentarily"
Eric - I want to wire mine up simply like that (but no switch). I want them to come on when I turn on my headlights. Any suggestions how I wire the LEDs to work this way? Thanks.
eric3187 02-16-2013 10:09 PM
i would advise against that, as some state laws do not allow for "off road" or auxiliary lights to be on while driving on a public road.
but to safely do it, i am not sure, as it may overload the headlight switch or something.
2000GTacoma 02-16-2013 10:34 PM
Use a relay that is triggered by say your highbeams. When you flick highbeams on the relay is closed and your leds come on. Relay carries load highbeams just supply enough power to close a relay which is very little. You can also run the relay through a 3 way switch and your highbeams. One position the leds come on with highbeams. 2nd position they do not come on at all. 3rd position they come on regardless of headlights on or not or truck on or not.
