-   -   1st Gen HID HELP (http://www.tacomaworld.com/forum/lighting/268818-1st-gen-hid-help.html)
YotePower 03-18-2013 01:22 PM
1st Gen HID HELP
I would like to order a set of HID headlights. I drive a lot and it seems like my headlights have a lot of room for improvement. I would like to get the brightest headlights I can for a decent price. I know nothing about HID systems so any words of wisdom yall can throw my way would be much appreciated.
Sandman614 03-18-2013 01:31 PM
1st and foremost do a lot of research on the topic. I was in the same situation and drove a lot at night, 3rd shift. HID's helped me a lot.
The higher the K rating the bluer/greener/pink the color gets, that doesn't refer to brightness. Lookup a Kelvin scale.
You have 35watt, 55watt, etc bulbs similar to normal halogen headlights, this is brightness. These wattage ratings are not the same between HID and Halogen, a 55w halogen is about as bright as a 35watt HID.
Check out Slim cubby for a plug and play kit. The proper way to put in HID's is with Projector housings and not the reflector housings that are stock.
YotePower 03-18-2013 07:22 PM
Thanks man ill check it out for sure
