-   -   Reverse lights not working (http://www.tacomaworld.com/forum/lighting/271875-reverse-lights-not-working.html)
Kirk1589 04-05-2013 05:18 PM
Last week u blew the tail lamp fuse while driving. My dash, radio and HVAC all went out as well. Put a new fuse in and it was fine. Reverse lights worked till now. They don't work and I can't find or know what fuse they go too. Everything else works like it should. My trucks electrical is bone stock. I need some help with this. I changed my trans gear oil Saturday if that has anything to do with it (it shouldn't)
Kirk1589 04-06-2013 07:52 AM
Bump
mdep03 04-09-2013 02:48 PM
same problem no reverse lights, i've been researching it for weeks and I'll let you know if I find anything out
2000GTacoma 04-09-2013 02:54 PM
manual or auto?
Kirk1589 04-09-2013 09:13 PM
manual
Kirk1589 04-13-2013 04:01 PM
Bump
2000GTacoma 04-13-2013 06:08 PM
Check the reverse switch and see if it has burned out. The switch is on the passenger side of the transmission about middle way and has 2 wires going to it. Should be a connector there as well.
