-   -   Which wire to use? DRL question. (http://www.tacomaworld.com/forum/lighting/272146-wire-use-drl-question.html)
Txfly 04-07-2013 01:24 PM
I have an '09 W/ DRL's. I want to eliminate the factory torches and add an LED strip somewhere.
I have the two wire set up, which one is for the DRL?
(And where's the ground wire?)
Or should I tap into the G/R at the relay?
THX
PS. I couldn't find info via search button, but if it's out there, I'd appreciate the link.
Txfly 04-07-2013 02:47 PM
OK, I pulled the grill and got in there.
White w/ black is the DRL.
So if I cut that wire and spice into the hot side for the new lights should I ground the (original) bulb side so the flashers still work?
I'm just a tad confused as there is no ground to the 4157 on this truck.
Don't want to fry anything.
Txfly 04-07-2013 04:09 PM
Sometimes it just helps me to write stuff down.
The white and black is the ground.
I'm gonna have to jump off the G/R at the relay.
New question, doe the G/R come through the firewall?
To access under the hood.
