-   -   Question about LED Strobe lights (http://www.tacomaworld.com/forum/lighting/276709-question-about-led-strobe-lights.html)
619Tacoma 05-06-2013 02:52 PM
Hello all,
I am looking to buy a set of amber LED 'panels'. It's for a little project on my truck. Anyway, the only LED panels that I've seen that I like are LED Strobe light panels from Ebay. They are flat, the size I want, amber & LED.
I've already asked a couple of sellers but they say no, it will only strobe. I keep thinking they are wrong and without the control box, I can make it work as I want it to.
My question is this: Can I use these lights in "always on" mode?
Since the controller that comes with the lights only has strobe functions, I won't be using the controller. If I were to cut the wires coming out of the panel & simply connect positive to a power wire and run the ground to a on/off switch, will they work?
or is there something in the controller box that is vital to the lights working at all?
http://www.ebay.com/itm/2x-48-LED-Pa...08dfde&vxp=mtr
http://i.ebayimg.com/t/2x-48-LED-Pan...BM)g~~60_3.GIF
Chris24 05-06-2013 03:58 PM
i would THINK that the control box is the only part that is making them strobe...and i would THINK that they would be constant on if they were wired directly to the 12v power
DeeKay21 05-06-2013 04:18 PM
What are you going to use them for? Even if you could get them on to stay solid I wonder how bright they would be since they are made for strobing? Might be pretty bright.
ProForce 05-06-2013 04:19 PM
I am about 99.9% sure that if you remove the box, they will function as constant on when given power and ground.
619Tacoma 05-06-2013 04:38 PM
Thanks guys. That is what I'm thinking as well. I would think the control box is the only thing that makes them 'strobe'. If I remove that from the equation, then I should be able to make them stay on.
Yeah, I don't know how bright they will be either. It's a very good and valid point. I'm thinking of using them as DTRL. If they're too bright, then of course i'll be tossing the idea out the window. I am thinking about mounting them in the two triangular voids on the front grill. I'd be cutting the back of those triangles out & replacing it with some type of black mesh material. I'd be mounting these lights behind the mesh & running them as DTRL with an on/off switch in the cab.
DeeKay21 05-06-2013 04:39 PM
I'm assuming you dont like the OEM DTRL's? Have you thought about the fog light anytime mod?
619Tacoma 05-06-2013 05:04 PM
Actually, I really like the OEM DTRL with the Anytime Fog Mod. (I already have the Anytime Fog mod)
The thing is that I drive quite a bit and I've heard other owners talking about their lenses melting and such - which I definitely don't want to happen.
So I thought about LED bulbs in the stock DTRL location. But then I'm thinking the 'look' will not be the same. I replaced my corner lights with LED lights and they are nowhere near as bright as the halogen bulbs. So I fear that LED 'bulbs' as DTRL will not look as bright or amber as I like either.
Chris24 05-06-2013 05:23 PM
Let us know how these work out if you get them
DeeKay21 05-06-2013 05:45 PM
You can get bright LED bulbs but it will cost you plus you need resistors to get rid of the hyper blink.
t_e 05-06-2013 06:53 PM
If you remove the control box they might burn out. Most of the time the flasher is where the resistors are built in and straight to 12v will burn them out.
