-   -   2012+ aftermarket headlights (http://www.tacomaworld.com/forum/lighting/276719-2012-aftermarket-headlights.html)
firetaco18 05-06-2013 04:22 PM
Anyone find aftermarket headlights for the '12+. All I can find is retrofit. I want to throw in some projector lights with BHLM but dont want to drop $800+. Any suggestions? Thanks!
DeeKay21 05-06-2013 04:25 PM
Check Ebay. I saw some on there that arent retros.
Justus 05-06-2013 04:36 PM
The correct way to "throw in some projector lights" is by doing or buying a true retrofit.
The spyder and other ebay crap (even if they do offer 2012's now) have terrible scatter and a cutoff line that helen keller could tell you is a joke. they also have always had worse halogen output than stock, and throwing hids in them is just gunna blind others, and not net u the quality of lighting u think ur paying for......also, they leak 90% of the time.
Save ur money and do a retrofit, or pay someone.......in the end u will be much happier
DeeKay21 05-06-2013 04:37 PM
X2. Good info.
firetaco18 05-06-2013 06:22 PM
ok that is what I figured, may just pay to do it right.
Monster Coma 05-06-2013 06:24 PM
D2S from TRS is pretty simple I've been told
Justus 05-06-2013 06:26 PM
in the end, u will save money.
good luck, and dont go cheap......do it right the 1st time, and u wont have to "fix" anything later.
I speak from experience with retrofits, and reading many issues right here on TW about the ebay/spyder projectors.
Moose has done some extensive work to "fix" and majorly improve on the design of a set of spyders......Ill look for a link
HIst8ofMIND 05-06-2013 06:26 PM
If you know what you're doing. And nothing wrong with aftermarket. Just change the projector and you're set.
Justus 05-06-2013 06:28 PM
http://www.tacomaworld.com/forum/lig...rojectors.html
HIst8ofMIND 05-06-2013 06:29 PM
http://i16.photobucket.com/albums/b1...psbb90d618.jpg
I saved money by getting replicas and throwing in TRS projectors.
Justus 05-06-2013 06:31 PM
so u retrofitted quality projectors into a housing that had inferior projectors.
same as moose
good job :cheers:
HIst8ofMIND 05-06-2013 06:38 PM
same as moose
good job :cheers:
Yup. Because legit JDM projectors are costly. And you still need to find LHD projectors. Unless you get ahold of EDM projectors which cost more than JDM.
Justus 05-06-2013 06:43 PM
good stinkin man
