-   -   Daytime Running Light Burnt Out (http://www.tacomaworld.com/forum/lighting/276882-daytime-running-light-burnt-out.html)
tacom08 05-07-2013 01:32 PM
Just noticed today that my left Daytime Running Light is not working at all (burnt out). You can see that the faulty DRL is "burnt/melted".
http://www.youtube.com/watch?v=q-zPG8UZypQ
I know that DRL lens melting/cracking is a common issue on the 2nd gens. However, I couldn't find anybody on the forums mentioning DRL's ceasing to function.
Truck has ~42,000 miles and was bought new back in '08, so obviously, the warranty has expired.
My main questions here are:
Can I fix this by myself at home?
How much do repairs cost?
Any help would be appreciated.
Crom 05-07-2013 01:35 PM
It's like a $2.00 bulb at Vatozone. Extremely easy to replace.
Edit: Because I'm feeling helpful today I looked up the part for you. Looks like they're sold in pairs. You should probably replace them both.
http://www.autozone.com/autozone/par..._665333_19345_
Sylvania/Daytime Running Light Bulb
For your 2009 Toyota Truck Tacoma 4WD 4.0L EFI DOHC 6cyl
Part Number: 3157-4157NALL
Alternate Part Number: 3157NALL B2
$5.99
http://contentinfo.autozone.com/znet...7NALL/image/2/
tacom08 05-07-2013 01:45 PM
$5.99
Thanks for the help.
PinkTaco24 05-07-2013 01:53 PM
If you get 3057A, it will not generate as much heat, hence alleviating even more lens melting. I run these in mine. The appearance is the same. Have had zero issue in the year+ that I've had them.
ETAV8R 08-16-2013 09:03 PM
Good stuff here. Wish I had replaced my stock bulbs long ago.
Rich91710 08-16-2013 09:21 PM
Watch them carefully, there's less than 2 watts difference in the spec for the 3057 vs 4157.
PinkTaco24 08-17-2013 04:55 AM
Will do, thanks. I've ran these for over a year with no problem, but that was with aftermarket housings. I just recently went back to stock, so I am definitely keeping my eye on them. I hate that this is such an issue with these trucks.
