TURN OFF DTRL?
Discussion in 'Lighting' started by hotrod45, Jul 4, 2013.
  1. Jul 4, 2013 at 4:30 AM
    hotrod45
    hotrod45 [OP] Well-Known Member
    paul
    sarasota fl
    16 sr 5 access cab
    anyone have the details to turn off the dtrl on an 09?
  2. Jul 4, 2013 at 4:51 AM
    HawaiiTRD
    HawaiiTRD "Some people feel the rain, others just get wet"
    Hawaii
    2022 MGM DCSB TRDOR
    Diamondback SE, FITCAMX
    You could trade the part with someone without dtrl that wants it.
    I just cut the wire. I no longer have the wiring diagram and can't remember what color wire it was.
    If I find it I'll let you know.
  3. Jul 4, 2013 at 4:58 AM
    HawaiiTRD
    Hawaii
    2022 MGM DCSB TRDOR
  4. Jul 4, 2013 at 5:21 AM
    pepper07
    pepper07 Well-Known Member
    Roger
    Tn.
    10' access cab
    I disabled mine about a week ago. It's simple to do. On the back side of the fuse block is a three wire plug . The wire to cut is green/red. Everything else works fine. Good luck.
  5. Jul 5, 2013 at 7:03 AM
    hotrod45
    paul
    sarasota fl
    16 sr 5 access cab
    thank you guys for all of the information. took 1 minute to do this. on the floor, lookup at the connector, cut the green with red wire. done! lights out!
