problem with H4 Wiring harness from TRS
Discussion in 'Lighting' started by FriscosPre, Oct 1, 2013.
  1. Oct 1, 2013 at 5:42 PM
    FriscosPre
    FriscosPre [OP] Member
    Eduardo
    SouthBay
    10 PreRunner
    3" lift,17x9 pro comp 5001 wheels,285/70 High Country Falkens,Retrofit Headlights and HID fogs.
    HI everyone I'm new here, have any of you had problems with TRS H4 wiring harness? I just did retrofit D2S projectors this past weekend & the high beams won't turn on. I tested the projectors before & after the install, they are working properly. The High beam indicator light turns on with low beams to, switched the blue & white wire & nothing happens. I don't use the high beams but would like for them to work & I don't want to bypass with the OEM harness.
  2. Oct 1, 2013 at 7:05 PM
    FriscosPre
    Eduardo
    SouthBay
    10 PreRunner
    I just installed a h4 bulb on the passenger side unused harness and started working fine but backwards, LB is HB and HB is LB now and indicator light is working right. I switched the blue and white wire on TRS harness,switched projector connector to harness backwards and nothing.
  3. Oct 6, 2013 at 1:05 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Call TRS. Sounds like a wiring problem in the harness.
  4. Oct 9, 2013 at 5:35 PM
    FriscosPre
    Eduardo
    SouthBay
    10 PreRunner
    Got the high beams to work now, TRS said to swap white and brown wires.
  5. Oct 14, 2013 at 5:50 AM
    OverPar
    OverPar Well-Known Member
    Dirt Guy
    NW CT
    09 TRD Sport
    Fold-a-Cover G4 Elite, Light bar (X3 Hella), Thule/OEM RR, Avid OR BO Sliders, TRS Projector HL (BHLM), 5100s F/Rear @ 1.75
    having same issue. Are these brown/red and white wires at the end of the 3 prong harness that plugs into factory slot? Only brown and white wires I see in this harness.
  6. Oct 14, 2013 at 5:59 AM
    OverPar
    Dirt Guy
    NW CT
    09 TRD Sport
    This one?
  7. Oct 14, 2013 at 6:11 AM
    FriscosPre
    Eduardo
    SouthBay
    10 PreRunner
    yep that's it switch the brown and white wire.
