Reverse lighting
Discussion in 'Lighting' started by jknc, Jul 10, 2014.
  1. Jul 10, 2014 at 3:53 AM
    jknc
    jknc [OP] Well-Known Member
    Josh
    Dallas Texas
    2012 Texas Edition PreRunner SR5
    Stock
  2. Jul 10, 2014 at 4:38 AM
    BAMS
    BAMS Well-Known Member
    Ray
    New Hampshire
    2011 TX TRD Access
    I am looking for the same kind of thing. I like these and will probably buy them.
    thanks for the easy link.
  3. Jul 10, 2014 at 4:38 AM
    jknc
    Josh
    Dallas Texas
    Stock
    No problem! They look solid enough.
  4. Jul 10, 2014 at 4:46 AM
    T@co_Pr3runn3r
    T@co_Pr3runn3r XXXXXXXXXXXXXXXXXXX
    08 RC Prerunner SR5
    My only concern would be keeping them from getting submerged getting the boat in/out of water. Not sure about your boat ramp setups and such and your mounting point heights tho...........I've seen these and thought about a pr for rev or extra coupla lights for the light bar up front. I run cree LED bike lights with 1600, 1800, 2400 & 3600 lumens. Just ordered up a 4000 lumen one since the ones I have have been kickass. These for the truck should be too.
  5. Jul 10, 2014 at 4:49 AM
    jknc
    Josh
    Dallas Texas
    Stock
    I usually keep the truck out of the water lol. But yeah there are those times. I thought about getting marine grade ones but white would look bad on my MGM.
  6. Jul 10, 2014 at 5:18 AM
    MagneticTaco79
    MagneticTaco79 COLD ASS HONKY
    AARON
    WV
    Mag Grey 2012 Tacoma AC TRD Sport 4x4
    ALL KINDS OF SHIT
    These do look really cool! Might try a set, Thanks.
  7. Jul 10, 2014 at 11:14 AM
    DirtJumper14
    DirtJumper14 Well-Known Member
    SoCal
    2005 TRD OR
    5100's, BDF grills and light bracket, big 3 upgrade, ATH bed braces, snugtop xtra vision shell, (bed, shell, hood, rock, front, rear, footwell, glove box, center console led lighting), MESO Gasshole, MESO dome and map lights, Flyeyez center console light, custom fuse panel, TRD CAI, toyota bed mat, 2013 black carpet, 2015 side mirrors, BedRug, AJT key fob, ultraguage, 8 cadillac horns acdf, pop n lock tailgate lock, energy suspension bushings, spicer greasable ujoints, Rigid lights everywhere, kenwood stereo, led tube taillights (red), 2018 T4R trail wheels, rokblok mud flaps, TRD skid plate, RCi gas tank skid plate
    I bought this set from a tw group buy (jasperoffroad, don't think he is around anymore). Low profile and have launched my boat at least 20 times and have had no issues with them. They are Chinese but for $40 they are bright and still work after almost 2 years. Mounted to the hitch so they sit further forward, not to the bumper.
    Looks like jasperoffroad.com is no longer but I found these on ebay, look identical but a little more $$$.
    http://m.ebay.com/itm/151347537779?nav=SEARCH
  8. Jul 10, 2014 at 12:05 PM
    MagneticTaco79
    AARON
    WV
    ALL KINDS OF SHIT
    Yeah those look great!
  9. Jul 10, 2014 at 12:11 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I have a pr of those I didn't want to put on my lightbar up front. I think they may go on the back of the truck instead...................
  10. Jul 10, 2014 at 1:50 PM
    jknc
    Josh
    Dallas Texas
    Stock
    I'm gonna have to try them out.
  11. Jul 17, 2014 at 10:45 PM
    jknc
    Josh
    Dallas Texas
    Stock
    Getting ready to do this tomorrow. Is there an easy pathway for the wiring from the rear to the cab and fuse box?
  12. Jul 17, 2014 at 11:07 PM
    DirtJumper14
    SoCal
    2005 TRD OR
    What lights did you get? There are rubber plugs under the driver/passenger seat you can run the wires through. Easy to see when you get under the truck. Then along the frame to the lights. Just stay away from exhaust and suspension obviously.
  13. Jul 18, 2014 at 3:27 AM
    jknc
    Josh
    Dallas Texas
    Stock
  14. Jul 18, 2014 at 5:00 AM
    jknc
    Josh
    Dallas Texas
    Stock
    Platinum Burners set installed. They look decent. Can't tell for sure yet cause the sun's come up though.
  15. Jul 18, 2014 at 6:21 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Did y'all just tap the positive rev light wire by tailight and then ground them to the frame or did y'all run wires into cab and light them up with seperate switch and/or would it matter which way other than for preference?
  16. Jul 18, 2014 at 6:25 AM
    jknc
    Josh
    Dallas Texas
    Stock
    I just spliced into the reverse light for now. I opened up the drivers side light, the reverse light is on red(+) and white(-) I just spliced directly to positive and the negative. Adding an extra ground could adversely affect it.
    I'm thinking about running it up to a constant power source and using a toggle switch, after a while. Also contemplating leaving them there and adding two 4 LED pods on the top of the bed near the cab on a toggle.
    Like this:
    http://www.tacomaworld.com/forum/showthread.php?t=292754
  17. Jul 18, 2014 at 6:28 AM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
  18. Jul 18, 2014 at 6:38 AM
    jknc
    Josh
    Dallas Texas
    Stock
    Yeah I mainly used the Walmart ones because I could pick them up and do it, immediately. Wife and kid are gone and I had a night to do something.
  19. Jul 18, 2014 at 7:06 AM
    DirtJumper14
    SoCal
    2005 TRD OR
  20. Jul 18, 2014 at 7:09 AM
    jknc
    Josh
    Dallas Texas
    Stock
    Yeah I bought two of the pods like are mounted to the bed rail in that post above, for $20, from my friend. And the ones on it now (Walmart) were $24 with a wiring harness.
    I'll just return the Walmart ones if they suck.
