-   -   Fog Light Switch (http://www.tacomaworld.com/forum/lighting/49438-fog-light-switch.html)
kirkdbjl 08-23-2009 02:58 PM
Fog Light Switch
I just purchased my new 09 Tacoma and want to install some auxilary fog lamps 0n my Bull Bar in addition to the factory lamps.
I am trying to find a switch that will replace one of the blanks in the dash that will look factory with an on indicator light.
I have found the following FJ switch PT297-35070-AS, but am not sure if it will work. Does anyone out there know?
chris4x4 08-23-2009 03:41 PM
Not sure if thats the right one, but they sell OEM switches on Ebay.
rmb_crew 08-23-2009 04:00 PM
Radio shack has a ton of differnet styles just buy which ever one you like and cut the blank off plates to fit.
uood8 08-23-2009 04:21 PM
i got an oem switch off ebay for about 20 bucks shipped.
kirkdbjl 08-24-2009 05:35 AM
Thanks for the info but I am new to this type of thing and do not know what OEM is?
I take it from the replies there isn't a switch made you can take the blank out and replace it with except a factory toyota fog light switch($60.00)that you simply need to find a switch that will work and install it on the blank after some modification?
95SLE 08-24-2009 05:52 AM
You might want to look at one of these.
http://www.oznium.com/gsw-45-led
monrad 08-24-2009 12:06 PM
See thread:
<http://www.tacomaworld.com/forum/2nd-gen-tacomas/15476-oem-style-switch.html>
Part No. 0055035976 can be had at the dealer for about $12 or less.
longbow 08-24-2009 01:10 PM
You can go this route, $8 each at the stealership, or e-bay I believe.
http://www.tacomaworld.com/gallery/d...m/DSC04640.JPG
Plain Jane Taco 08-24-2009 06:52 PM
I went with the same switch. $10 at my local dealer.
http://img.photobucket.com/albums/v4...S/IMG_2687.jpg
jhodge83 08-24-2009 06:53 PM
got this one off amazon i believe....its made by daystar...got green to go w/ the truck...kinda big and gnarly rocker...
http://www.tacomaworld.com/gallery/d...m/S6300305.JPG
brandob9 09-03-2009 03:16 PM
Did yours require any magic to fit? I'm reluctant to use too much force here.
2007TacBorla4X4 01-10-2010 04:52 PM
http://www.4wheelparts.com/Lights-Li...3710&t_pl=3595
go look at my picks
Fish Head 01-14-2010 09:46 AM
Seriously...........I went & bought 3 through my local dealership, just shy of $100.00 for all 3 after I was taxes in - brutal considering the price point you guys are scooping them at.
They'll be going in shortly, as all my other lighting components are finally here.
Fish Head 01-14-2010 03:29 PM
Quick question now that my hands are scratched to crap from burrowing around blindly up in behind my dash - how does one access the area behind the upper 3 switches ? The lower 3 is a simple remove the tray and pop 'em out from behind.........the upper 3 are shielded from below it seems.
I'm wanting to move (re locate) the factory alarm light/sensor from the lower middle slot to the upper middle slot, leaving the lower 3 for the new auxillary lighting switches.
Any way to do this simply without yarding half the dash out ?? I've looked around a bit for links but haven't hit on the right one yet.
drmadron 01-15-2010 12:03 PM
well l just found out my 2010 tacoma v6 4x4 did not come with wiring for fog light so l have to buy aftermarket fog lights and wiring any know where to buy a nice set of aftermarket fog lights.
AZCOMA 01-15-2010 12:39 PM
I just taped in to the wire on the fogs for signal to turn on my hellas.I have a seperate power source and a relay. Works good cause I dant use the fogs any ways.
Dark Knight 01-15-2010 12:51 PM
true definition of stealership right there....
DanT 02-07-2011 01:49 PM
Access to foglight switch panel
Did anyone ever answer your question about accessing the upper switch area to add a fog light switch? I have the same question.
01GREENTACO 02-07-2011 01:59 PM
Holy thread revival Batman!
Fish Head 02-07-2011 05:59 PM
You've got mail......
